is there a good Mutli crypto wallet for the
Raspberry Pi OS available? On my Suse PC I use exodus and atomicwallet. Thats the only thing that I´m missing on my Raspberry Desktop.
Thx and Regards
ronnih
Good Multi Crypto Wallet for Raspberry Pi OS
https://techguru.lima-city.de
Re: Good Multi Crypto Wallet for Raspberry Pi OS
Or i must build a container, a VM or emulation for the x86 Programm to run on the Raspberry Pi 4
Does anyone have any experience with running x86 programs on the ARM architecture? Or is this impossible
Thx had finally test the TwisterOS, but this can only execute x86 32Bit Programms. But I see that the Programms what I need use 64Bit
https://downloads.exodus.io/releases/ex ... _amd64.deb
Had buy a new Raspberry Pi 400 but I can not execute/install this Programm because it is amd64Bit. Can I emulate or build a VirtualMachine with 64Bit AMD/Intel CPU on the Raspberry Pi 4 /400?
Has anyone ever successfully run an x68-64Bit application on the Raspberry?
