jamesh wrote: ↑Fri Oct 23, 2020 3:23 pm
X-Gen wrote: ↑Wed Oct 21, 2020 2:40 am
I actually can't think of any benefit of using the new connector.
They say 'boards can now be lower in profile thickness', but that's a lie.
With CM3 modules, one could build a motherboard around the CM module if one wanted.
With CM4 modules, there always will be the module with an additional motherboard or fiberglass extension board sandwiched together. And those 2 are definitely not thinner than the sodimm socket of a CM3 module.
There are many benefits. More robust, more lines, easier board layout, cheaper boards, lower height (yes, not a lie at all!). When this was shown to resellers a half a year ago, they were delighted with the form factor change. Much more in keeping with their industrial customers requirements.
No, the height can never be as thin with this new design, compared to the CM3 design.
Not that it matters though, as they're mostly mounted vertically (on a horizontal motherboard) for multi units.
But like I said, the CM3 module in (retro) gaming consoles, have a Sodimm slot the CM3 fits in. The rest of the motherboard is built around the CM3 module.
Not possible with CM4, so it's not possible for it to be thinner.
Yes, if the motherboard is built underneath a CM3 module (like most RAM slots in a laptop) it might take up more space.
But if thin-ness is an issue, the CM3 units can actually go thinner than the CM4 units (I know this, without ever needing to have seen one in person), due to the fact that the CM3 modules can be mounted not just parallel, but on the same plane as a motherboard.
I remember seeing 2 designs, one which had a cutout where the CM3 module would fit in (motherboard is built around the CM3 module, O-shaped),
And the other one was just a CM3 module in a sodimm slot, with 2 separate boards on each side (motherboard U-shaped).
