MacTzu wrote:Soldier,
I'm happy to help, could you supply more information ?
The situation: I buy a raspi board, and collect some stuff. Have a power supply (phone charger, 5V/780mA), a 2G SD card, keyboard, LAN cable to my router (DHCP worked), keyboard and a HDMI cable to my tv.
Progress:
- download the
official image
- dd to sd card (sudo dd bs=1M if=archlinuxarm-13-06-2012.img of=/dev/sdd) [/list]
- boot from sd card
- login with root, everything ok
- run the recommended method,
pacman -Syu --ignore glibc
pacman -Su
After the first command, this is the output:
[root@alarmpi ~]# pacman -Syu --ignore glibc
:: Synchronizing package databases...
core is up to date
extra is up to date
community is up to date
alarm is up to date
aur is up to date
:: The following packages should be upgraded first :
pacman
:: Do you want to cancel the current operation
:: and upgrade these packages now? [Y/n] n
:: Starting full system upgrade...
warning: glibc: ignoring package upgrade (2.15-10 => 2.16.0-4)
:: Replace systemd-tools with core/systemd? [Y/n]
resolving dependencies...
warning: ignoring package glibc-2.16.0-4
warning: cannot resolve "glibc>=2.16", a dependency of "binutils"
warning: cannot resolve "glibc>=2.16", a dependency of "gcc-libs"
warning: cannot resolve "glibc>=2.16.0", a dependency of "pacman"
:: The following packages cannot be upgraded due to unresolvable dependencies:
binutils cryptsetup dbus-core device-mapper gcc-libs glib2 grep initscripts
less lvm2 mkinitcpio pacman pcre syslog-ng systemd wpa_supplicant
Do you want to skip the above packages for this upgrade? [y/N] y
looking for inter-conflicts...
Targets (56): bash-4.2.037-1 ca-certificates-20120623-1 coreutils-8.17-3
cracklib-2.8.19-1 cronie-1.4.8-3 dhcpcd-5.6.0-1 e2fsprogs-1.42.5-1
filesystem-2012.8-1 fuse-2.9.1-1 gzip-1.5-1 hwids-20120831-1
iana-etc-2.30-3 inetutils-1.9.1-4 iproute2-3.5.1-1 iputils-20101006-4
kbd-1.15.3-3 keyutils-1.5.5-3 kmod-10-1 krb5-1.10.3-1
libedit-20120601_3.0-1 libgssglue-0.4-1 libidn-1.25-1 libldap-2.4.32-1
libnl-3.2.11-1 libpcap-1.3.0-1 libusb-compat-0.1.4-2 libusbx-1.0.12-2
linux-api-headers-3.5.1-1 linux-firmware-20120625-1
linux-headers-raspberrypi-3.2.27-5 linux-raspberrypi-3.2.27-5
logrotate-3.8.2-1 man-db-2.6.2-1 man-pages-3.42-1
net-tools-1.60.20120804git-2 openntpd-3.9p1-19 openssh-6.1p1-2
pacman-mirrorlist-20120826-1 pam-1.1.5-4 pambase-20120701-1
pciutils-3.1.10-1 perl-5.16.1-1 ppp-2.4.5-4 procps-ng-3.3.3-3
psmisc-22.19-1 raspberrypi-firmware-20120914-1 readline-6.2.004-1
run-parts-4.3.2-1 shadow-4.1.5.1-1 sysvinit-2.88-7 sysvinit-tools-2.88-7
tzdata-2012e-1 usbutils-006-1 util-linux-2.21.2-5 wget-1.14-1 xz-5.0.4-1
Total Download Size: 72.70 MiB
Total Installed Size: 284.29 MiB
Net Upgrade Size: -15.32 MiB
Proceed with installation? [Y/n]
Choose yes. After download and checking, this error:
(56/56) checking package integrity [##############################] 100%
(56/56) loading package files [##############################] 100%
(56/56) checking for file conflicts [##############################] 100%
error: failed to commit transaction (conflicting files)
filesystem: /etc/profile.d/locale.sh exists in filesystem
Errors occurred, no packages were upgraded.
Allright, "solve" this, and try again:
[root@alarmpi ~]# mv /etc/profile.d/locale.sh /etc/profile.d/locale.sh.old
core is up to date
extra is up to date
alarm is up to date
aur is up to date
pacman
Press "Y" again. Completed witout problem.
Rebooting (because firmware update), and login again. (ssh not work from this point) Then run:
[root@alarmpi ~]# pacman -Su
pacman
Targets (14): binutils-2.22-10 dbus-core-1.6.4-1 gcc-libs-4.7.1-6 glib2-2.32.4-1
glibc-2.16.0-4 grep-2.14-1 less-451-1 mkinitcpio-0.10-1 pacman-4.0.3-3
pcre-8.31-1 syslog-ng-3.3.6-1 systemd-189-4 systemd-tools-185-1 [removal]
wpa_supplicant-1.0-1
Total Download Size: 16.82 MiB
Total Installed Size: 82.92 MiB
Net Upgrade Size: 5.76 MiB
Press "Y" again. This is the end of the story, when downloading and checking the packages, bring the famous "glibc: /lib exists in the filesystem" message.
So, what is the right method?
Edited: Sorry the longest post, and thank you.
