is there a good Mutli crypto wallet for the
Raspberry Pi OS available? On my Suse PC I use exodus and atomicwallet. Thats the only thing that I´m missing on my Raspberry Desktop.
Thx and Regards
ronnih
Good Multi Crypto Wallet for Raspberry Pi OS
https://techguru.lima-city.de
Re: Good Multi Crypto Wallet for Raspberry Pi OS
Or i must build a container, a VM or emulation for the x86 Programm to run on the Raspberry Pi 4
Does anyone have any experience with running x86 programs on the ARM architecture? Or is this impossible
My other Linux machine is a ChromeBox
Thx had finally test the TwisterOS, but this can only execute x86 32Bit Programms. But I see that the Programms what I need use 64Bit
https://downloads.exodus.io/releases/ex ... _amd64.deb
Had buy a new Raspberry Pi 400 but I can not execute/install this Programm because it is amd64Bit. Can I emulate or build a VirtualMachine with 64Bit AMD/Intel CPU on the Raspberry Pi 4 /400?
Has anyone ever successfully run an x68-64Bit application on the Raspberry?
