Rcayot
how to add to PATH
Wed Sep 30, 2020 4:46 pm
I recently tried to add a board to my Arduino IDE, it apparently needed an NRFutil program which I installed, and got the following message:
"The script adafruit-nrfutil is installed in '/home/pi/.local/bin' which is not on PATH."
Also when I tried to install the board, the Arduino IDE gave the following message:
nrfutil not available on this operating system.
So, the board installation page has this advice:
"Add pip3 installation dir to your PATH if it is not added already. Make sure adafruit-nrfutil can be executed in terminal by running"
anyway, how do I add this to PATH?
Roger
jahboater
Re: how to add to PATH
Wed Sep 30, 2020 4:50 pm
If you want it first on the search path:
PATH=/home/pi/.local/bin:$PATH
or last on the search path:
PATH=$PATH:/home/pi/.local/bin
Pi4 8GB running PIOS64 Lite
Rcayot
Wed Sep 30, 2020 5:23 pm
Thanks, that partially worked!
When I run from terminal
:pi@raspberrypi:~ $ adafruit-nrfutil version
adafruit-nrfutil version 0.5.3.post12
pi@raspberrypi:~ $
nrfutil file is found, but when I try to install the board on the Arduino IDE, I get the following message:
"Tool nrfprog is not available for your operating system"
Still stuck, will go back to Adafruit customer support... but anything anyone here can help with would be great!
Roger
dbrion06
Wed Sep 30, 2020 5:30 pm
Did you have a look at:
https://github.com/adafruit/Adafruit_nR ... issues/225
(that is not a very good new: Nordic seems to ship nfrprog for x86....https://infocenter.nordicsemi.com/pdf/n ... s_v1.0.pdf p7)
GlowInTheDark
Wed Sep 30, 2020 5:31 pm
Note that there are at least 3 different questions being asked here:
1) How do I add something (temporarily) to my $PATH variable in the shell?
2) How do I do the above in a way that is permanent (i.e., will persist across different invocations of the shell and/or reboots) ?
3) What is wrong with my Arduino IDE installation? Why doesn't it "just work" like it should?
#1 has been answered above.
I suspect #3 is the one the OP is actually interested in.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
Rcayot
Wed Sep 30, 2020 5:46 pm
well yes, #1 has been answered.
I suspect that I need to have #2 answered. Then I can see if that will help with #3 as the guide on Adafruit for the board says that testing the path by running a simple 'version' argument will result in an an error free version, and it does, but still does not get me past the board install.
Thanks,
Roger
jahboater
Wed Sep 30, 2020 6:11 pm
That's easy.
There is a file in your home directory called ".bashrc"
You may edit it with "nano ~/.bashrc" and add the PATH= stuff there.
It will then always be available.
GlowInTheDark
Wed Sep 30, 2020 6:57 pm
Actually, it is better to set PATH in .profile than .bashrc (or other places).
By the way, I often see references to .local/bin or maybe .config/bin or whatever. Where do these comes from? I always just use ~/bin (which is what the code in the .profile supports).
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
jahboater
Wed Sep 30, 2020 8:06 pm
See .profile as you suggested above ...
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
    PATH="$HOME/bin:$PATH"
fi
if [ -d "$HOME/.local/bin" ] ; then
    PATH="$HOME/.local/bin:$PATH"
fi
Return to “Beginners”
