Terminal OUTPUT:
Dynarec for ARM, with extension: HALF FAST_MULT EDSP NEON VFPv4 IDIVA PageSize:4096
Using default BOX86_LD_LIBRARY_PATH: ./:lib/:lib32/:x86/
Using default BOX86_PATH: ./:bin/
Counted 48 Env var
Looking for /home/pi/Documents/fidel/fidel
Using emulated libsteam_api.so
Using emulated /usr/lib/i386-linux-gnu/libstdc++.so.6
Using native(wrapped) libm.so.6
Using native(wrapped) libc.so.6
Using native(wrapped) ld-linux.so.2
Using native(wrapped) libpthread.so.0
Using native(wrapped) librt.so.1
Using emulated /usr/lib/i386-linux-gnu/libgcc_s.so.1
Using native(wrapped) libdl.so.2
Using emulated libtbb.so.2
Using emulated libpdx_online.so
Using emulated libpops_api.so
Using native(wrapped) libuuid.so.1
Using native(wrapped) libGLU.so.1
Using native(wrapped) libGL.so.1
Using native(wrapped) libSM.so.6
Using native(wrapped) libICE.so.6
Using native(wrapped) libX11.so.6
Using native(wrapped) libXext.so.6
Using native(wrapped) libxcb.so.1
Using native(wrapped) libXau.so.6
Using native(wrapped) libXdmcp.so.6
Using emulated /home/pi/Documents/fidel/libtbbmalloc.so.2
Error: Global Symbol __TBB_internal_find_original_malloc not found, cannot apply R_386_GLOB_DAT @0xb42d6ad4 ((nil)) in /home/pi/Documents/fidel/libtbbmalloc.so.2
Error: Global Symbol __TBB_malloc_proxy not found, cannot apply R_386_GLOB_DAT @0xb42d6bac ((nil)) in /home/pi/Documents/fidel/libtbbmalloc.so.2
Using native(wrapped) libXcursor.so.1
Using native(wrapped) libXinerama.so.1
Using native(wrapped) libXrandr.so.2
Using native(wrapped) libXrender.so.1
Using native(wrapped) libXxf86vm.so.1
Using native(wrapped) libpulse-simple.so.0
Using native(wrapped) libpulse.so.0
Warning: Cannot dlopen("libCSUNSAPI.so"/0x5beb878, 2)
Warning: Cannot dlopen("libswift.so"/0x5bea678, 2)
Warning: Cannot dlopen("libnfhwcrhk.so"/0x5bf2c38, 2)
Warning: Cannot dlopen("libSureWareHook.so"/0x5bf4490, 2)
Warning: Cannot dlopen("libCSUNSAPI.so"/0x5e25b80, 2)
Warning: Cannot dlopen("libaep.so"/0x5e26628, 2)
Warning: Cannot dlopen("libatasi.so"/0x5e27190, 2)
Warning: Cannot dlopen("libswift.so"/0x5e27190, 2)
Warning: Cannot dlopen("libnfhwcrhk.so"/0x5e27250, 2)
Warning: Cannot dlopen("nuronssl.so"/0x5e27988, 2)
Warning: Cannot dlopen("libSureWareHook.so"/0x5b0d210, 2)
Warning: Cannot dlopen("libubsec.so"/0x5e27970, 2)
Warning: Cannot dlopen("/home/pi/Documents/fidel/libirml.so.1"/0xb5e7b880, 1)
Warning: Cannot dlopen("/home/pi/Documents/fidel/libcilkrts.so"/0xb5e7b900, 1)
16916|SIGSEGV @0x7b0e79d8 (???) (x86pc=0xb52ca750/"???"), for accessing 0x1c (code=1), db=(nil)((nil)/???)
16915|SIGSEGV @0x7b0e79d8 (???) (x86pc=0x2e8be72/"???"), for accessing 0x1c (code=1), db=(nil)((nil)/???)
16914|SIGSEGV @0x7b0e79d8 (???) (x86pc=0xb52ca750/"???"), for accessing 0x1c (code=1), db=(nil)((nil)/???)
