I've had a look around and I can't see anything directly that looks like this problem.
I have a raspberry pi (what a surprise) that I want to back up the SD card to as a hot backup. To do this I have a mount on an ASUSTOR NAS that is mounted to \mnt\backups\
The FSTab entry is this:-
//xxx.xxx.xxx.xxx/Backups /mnt/backup cifs username=xxxxxx,password=xxxxxxxx,vers=3.0,users,auto,user_xattr,sfu 0 0
rsync: symlink "/mnt/backup/piserver/lib/systemd/system/fuse.service" -> "/dev/null" failed: Operation not supported (95)
rsync -avH --delete-during --delete-excluded --exclude-from=/usr/bin/rsync-exclude.txt / /mnt/backup/$HOSTNAME/
Also, is there a way that I can force fstab to use the IPV4 address rather than the IPV6 one? I can resolve both, but the IPV6 is external so routing becomes an issue.
Many thanks,
David
