QuanTrieuPCYT
hdd usb boot raspberry pi 4 problem
Sat Aug 08, 2020 1:38 pm
I successfully reflashed the EEPROM of the Raspberry Pi 4 (2gb rev 1.1) and able to boot the pi from my 1TB Toshiba 2.5inch HDD
But theres a problem:
I connected multiple devices to the pi: my 1TB HDD, 500GB HDD, my printer (which is for CUPS) and a 4GB USB Stick
When the pi4 boot with all of those devices plugged in, it wont boot (the light of all the HDDs turned on)
It only boot when i remove all hard disk (except the 1TB HDD which contains Raspbian) and when it booted successfully i plugged those devices back.
So any way to boot the pi4 without unplugging the usb cables?
Re: hdd usb boot raspberry pi 4 problem
Sat Aug 08, 2020 5:50 pm
The total from USB is 1200mA, not per port, if using the Official Power Supply:
https://www.raspberrypi.org/documentati ... /#pi-power
How many amps does your 1TB HDD draw on initial boot up ??
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
QuanTrieuPCYT
Thu Aug 13, 2020 4:53 am
about 2A-2,3A
and i try to plug only the hdd and the printer and it didnt boot :(
QuanTrieuPCYT
Thu Aug 13, 2020 4:56 am
the raspberry pi seems confused and didnt want to boot when i tried to plug another usb devices into it lol
QuanTrieuPCYT
Thu Aug 13, 2020 4:57 am
and i have external power for the HDD.
But it didnt boot either ;-;
QuanTrieuPCYT
Thu Aug 13, 2020 4:58 am
when i plug in my sd card it boot fine (with 2 HDD and USB)
bassamanator
Thu Aug 13, 2020 6:45 am
Your issue sounds like a bug. Not sure where to report it though :/
| Raspberry Pi 4-8GB | 2.0GHz | over_voltage@5 |
| Raspberry Pi OS 32bit |
| https://github.com/bassamanator/raspberrypi-scripts |
