blippy
Serial communication voltages
Fri Jul 24, 2020 11:33 am
I recently got an USB to TTL232 module. I suddenly realised that I have no clue about voltages. I'd like to connect the device's RX and TX pins to the appropriate GPIO pins on the Pi. I have no idea if that will fry the GPIO pins, though. What's the answer?
The chip is a CH340C. I'm assuming that VCC output is 5V, which doesn't matter, because I am powering my Pi separately anyway. The big question is what's coming out of the TX pin.
B.Goode
Re: Serial communication voltages
Fri Jul 24, 2020 12:12 pm
So you want to plug the usb end into some unspecified external device, and connect the 'other' side of the convertor to the RPi 40-way header?
"The big question is what's coming out of the TX pin."
Absolutely! And for that you need the datasheet for the convertor module and/or its chipset.
But note that as a general principle rs232 signalling is bi-polar, or 'non return to zero'. So the two signal states ( mark/space ) are represented by positive and negative going versions of the same absolute signal level. Not only will a signal level of 5v be potentially fatal to a 3.3v gpio pin, but ANY negative-going signal is also likely to cause damage.
And just in case I don't know what I am talking about:
All UARTs on the Raspberry Pi are 3.3V only - damage will occur if they are connected to 5V systems.
Ref: https://www.raspberrypi.org/documentati ... on/uart.md
hippy
Fri Jul 24, 2020 12:32 pm
Indeed. You could just measure it with a multimeter as it should be idle high to connect to a Pi's UART. Or assume it's 0V/5V and choose resistors for an appropriate divider which will likely still work if 3V3.
.----------.   .------------------< Pi TXD
|       RX |<--'    ___
| UART  TX |-------|___|---.------> Pi RXD
|       0V |---.    12K   .|.
`----------'   |          | | 22K
               |          |_|
               `-----------^------- Pi 0V (GND)
UART TX = 5V0, Pi RXD = 3V2
UART TX = 3V3, Pi RXD = 2V1
blippy
Fri Jul 24, 2020 1:42 pm
Aha, that's useful. That voltage came out at 4.05V, which I assume is still too high. Sigh, well that was a waste of a couple of quid from China!
Fortunately, I've got a Plan B. I have an ESP32, which operates on 3V3. So with a little bit of code I can use it as a "proxy" to the Pi.
Thanks for your help, guys.
hippy
Fri Jul 24, 2020 4:14 pm
Just adjust the resistor values to drop it to 3V3 or slightly less. Plenty of on-line calculators available. 10K over 30K would probably do the job.
That's got to be a lot easier than using an ESP as some sort of proxy.
FTrevorGowen
Fri Jul 24, 2020 4:19 pm
@blippy, for future reference you may find these notes/tests about/of a number of USB-to-Serial TTL devices of interest:
https://www.cpmspectrepi.uk/raspberry_p ... pters.html
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
blippy
Fri Jul 24, 2020 9:47 pm
My electronics knowledge is naff, but I can figure out voltage dividers. If I set up a voltage divider I have to set up components with a breadboard. If I use an ESP32, it's basically just three Dupont wires into the Pi.
blippy
Fri Jul 24, 2020 9:50 pm
Trev.
Many thanks.
hippy
Sat Jul 25, 2020 9:12 am
You can take your dupont wires, and solder the resistors in-line, wrap it all with insulating tape, no PCB required. Or pass it though a plastic pen body cut-off to make a nicer end-result.
But whatever you choose to do is fine.
nliviu
Sat Jul 25, 2020 4:41 pm
You can use something like this which has a jumper to select betweeen 5V/3.3V interface.
It works very well to program ESP8266 with the jumper set to 3.3V.
