Raspberry Pi Micro
Python on RPiOS
Mon Jun 22, 2020 8:14 pm
Can you install Python on RPiOS. If this is possible, which version do you need to download.
python.org/downloads/
Re: Python on RPiOS
Mon Jun 22, 2020 8:16 pm
All versions of Raspbian (since Wheezy) and RaspiOS already include an appropriate (and current when built) version of python2 and python3.
What are you attempting to do?
Raspberry Pi Micro
Re: Python on RPiOS
Mon Jun 22, 2020 8:26 pm
I have downloaded a couple of books on learning Python and how to write some basic programs.
How do you start Python on RPiOS.
Re: Python on RPiOS
Mon Jun 22, 2020 8:30 pm
There's an interactive development evironment (IDE) called Thonny in the menu. That's your best starting point for python.
Otherwise open an LXTerminal window, use nano /home/pi/mypythonprogram.py to edit your code then use python3 /home/pi/mypythonprogram.py and it will run. Trust me, Thonny is easier for beginners.
https://magpi.raspberrypi.org/articles/thonny
pfletch101
Re: Python on RPiOS
Mon Jun 22, 2020 8:35 pm
Enter
python
at the system command line for Python 2, or
python3
at the system command line for Python 3. These will give you the relevant version of python's command line.
If you like (or your book uses) IDEs, Thonny and Geany are part of the non-lite packages and can be found on the 'Programming' tab of the main menu.
Raspberry Pi Micro
Re: Python on RPiOS
Tue Jun 30, 2020 2:09 pm
Enter
python
python3
Finally looks like I now have Python3 installed. I start Terminal and then type python 3 and then the following information is displayed.
Python 3.7.3 (default, Dec 20 2019, 18:57:59)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "licence" for more information.
There are many pages of python code in many of the Pi Magazines like in the screenshot below, In this example how do I start to type in some of this code by starting python3, or would I need to start using Thorny Python IDE. But still not 100% sure how to start entering code using python3.
I have also downloaded MagPi Issue 53 which may also be a starting point as well.
The MagPi Essentials Make Games with Python, does interest me a lot, as I would also like to convert some simple BBC Micro games to python once I have a good understanding.
The graphics in this game are simple enough, with the design of the screens.
Any help here will be most welcome.
rpiMike
Re: Python on RPiOS
Tue Jun 30, 2020 2:21 pm
As mentioned use Thonny.
Raspberry Pi Micro
Re: Python on RPiOS
Tue Jun 30, 2020 2:33 pm
Ok thank you, is this the same or slightly different version of python.
From the Thorny View menu, what should I have selected or shown.
rpiMike
Re: Python on RPiOS
Tue Jun 30, 2020 2:36 pm
Thonny uses Python3
klricks
Re: Python on RPiOS
Tue Jun 30, 2020 3:33 pm
The Thonny IDE is not itself Python.....It is a tool to help you write and debug your Python code. As mentioned any text editor such as nano or mousepad could be used to write Python code, but an IDE has a lot more features to help you write and debug your code.
Once your code is written and working, in most cases, the IDE is no longer needed and you just run your code from the command line or desktop like any other app or command.
jahboater
Re: Python on RPiOS
Tue Jun 30, 2020 4:50 pm
Firstly please forget mentions of Python2. It was officially end-of-life six months ago.
Python3 is the only version of Python you need think about, and henceforth "Python" refers to Python3.
Python is a programming language much like any other. You write your program in an english like language that a human can understand, and it gets translated into a different language that only the computer can understand.
The program you write is just a simple text file that you can produce with any text editor. It is called "source" code.
You give the program to the Python translator (called an interpreter) which reads the english like text in, converts it into the machine language, and executes it. The interpreter is a computer program called "python3".
Python is slightly unusual in that you can enter an interactive mode (just by typing "python3") where you may type in commands and expressions directly and it will translate and execute them immediately. Makes a nifty calculator ....
 $ python3
Python 3.7.2 (default, Jan  9 2019, 15:51:37)
[GCC 8.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> 2 + 2
4
>>> print("Hello world!")
Hello world!
Normally however, you would create a text file typically suffixed with ".py" such as "hello.py" with an editor. The file contains your program.
Then you type "python3 hello.py" and it will run your program. (You can avoid typing the initial python3 all the time).
As noted above, you can use literaly any text editor you like, there are many to choose from. Nano on the Pi is fine and simple to use.
There are also various IDE's where you edit your program, run it, debug it etc all in the same place (that's why they are called Integrated Development Environments - IDE). The editors within these IDE's may offer better facilities for Python source such as highlighting keywords in different colours etc.
Pi4 8GB and Pi4 4GB running Raspberry Pi OS 64-bit
Raspberry Pi Micro
Re: Python on RPiOS
Tue Jun 30, 2020 5:00 pm
Thank you. Think I will start with Thorny Python IDE, from the menu at the top, you select View, this it gives you a number of views options, what should I best select here to start with.
Assistance
Exception
Files
Heap
Help
Notes
Object Inspector
Outline
Program Tree
Shell
Stack
Variables
Program Arguments
Plotter
Increase Font Size
Decrease Font Size
Focus Editor
Focus Shell
Only options I have selected are;
Shell
Varables
Raspberry Pi Micro
Re: Python on RPiOS
Tue Jun 30, 2020 6:45 pm
What options are there for taking a screenshot on RPiOS, if it's the whole screen or just an active window.
On Mac OS it's CMD + SHIFT + 3 and CMD + SHIFT + 4
klricks
Re: Python on RPiOS
Tue Jun 30, 2020 7:07 pm
Pressing the [Print Screen] key will capture the entire screen and save a .png image in the current directory.
For more options you can run scrot from the command line.
For details see:
scrot -h
and
man scrot
For me I connect remotely with VNC and do the [Alt] [Print Screen] from Windows 10. You should be able to do something similar with the MAC.
Raspberry Pi Micro
Re: Python on RPiOS
Tue Jun 30, 2020 7:41 pm
How do you connect remotely with VNC.
klricks
Re: Python on RPiOS
Tue Jun 30, 2020 9:07 pm
Documented on RPi website:
https://www.raspberrypi.org/documentati ... /README.md
Return to “Beginners”
