Sleep Mode zZ
Re: Logitech k400 keyboard and v3.2
Wed Sep 05, 2012 3:46 pm
Once even my current image did not boot, then when I did wrote the file again, it did boot. So clearly the "not booting problem" is fault to my card reader, Ubuntu or Dolphin (file manager).
So I have tested only these:
Aug 7
Aug 15
Aug 19_2
Aug 21
k400 do not work, even with replugging.
No more testing for me today.
Sleep Mode zZ
Thu Sep 06, 2012 1:37 pm
I have now tested several kernel.img files, ranging from July 27 to September 3, and my k400 did not function in a single one, even with replugging. In the original kernel the k400 always comes to life with replugging. I will probably not do further testing because I suspect it is useless.
PaulCheffus
Thu Sep 06, 2012 1:50 pm
Sleep Mode zZ wrote:I have now tested several kernel.img files, ranging from July 27 to September 3, and my k400 did not function in a single one, even with replugging. In the original kernel the k400 always comes to life with replugging. I will probably not do further testing because I suspect it is useless.
Hi
I personally suspect it is the move from v3.1.9 to v3.2.27 that has caused the issue. I intend to see what date my working card has on it that hasn't been upgraded but I'm pretty sure it will be 25 July. Hopefully I will have chance this weekend.
Cheers
Paul
Procrastination - The Thief of Time.
MaxK1
Thu Sep 06, 2012 2:14 pm
The driver is different in 3.2.27 - post your logs, dmesg lsusb lsmod from when it does and doesn't work on the new kernel and whether or not it was from a power on or just a reboot. Things don't get fixed by
accident (usually). They get fixed (usually) when good problem reports are posted. And repeating that it worked in 3.1.9 and it doesn't in 3.2.27+ doesn't help much either. It just confirms the device is capable of working. I have some suspicions on what might be going wrong, but I don't have one of those keyboards to see the problem first hand.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Sleep Mode zZ
Thu Sep 06, 2012 2:44 pm
From power on, receiver came to life with replugging.
/var/log/dmesg:
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.2.27+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #102 PREEMPT Sat Sep 1 01:00:50 BST 2012
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 49152
[    0.000000] free_area_init_node: node 0, pgdat c0506a80, node_mem_map c05ae000
[    0.000000]   Normal zone: 384 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 48768 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 48768
[    0.000000] Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708.boardrev=0x1000002 bcm2708.serial=0x30591bf smsc95xx.macaddr=B8:27:EB:05:91:BF dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait sdhci-bcm2708.enable_llm=1 sdhci-bcm2708.sync_after_dma=0
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 192MB = 192MB total
[    0.000000] Memory: 189008k/189008k available, 7600k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xcc800000 - 0xe8000000   ( 440 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xcc000000   ( 192 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04bbba8   (4815 kB)
[    0.000000]       .init : 0xc04bc000 - 0xc04dc000   ( 128 kB)
[    0.000000]       .data : 0xc04dc000 - 0xc0507100   ( 173 kB)
[    0.000000]        .bss : 0xc0507124 - 0xc05adf88   ( 668 kB)
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] timer_set_mode: unhandled mode:1
[    0.000000] timer_set_mode: unhandled mode:3
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000645] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.040112] pid_max: default: 32768 minimum: 301
[    0.040447] Mount-cache hash table entries: 512
[    0.040800] Initializing cgroup subsys cpuacct
[    0.040865] Initializing cgroup subsys devices
[    0.040889] Initializing cgroup subsys freezer
[    0.040910] Initializing cgroup subsys blkio
[    0.041007] CPU: Testing write buffer coherency: ok
[    0.041258] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.042082] devtmpfs: initialized
[    0.048613] NET: Registered protocol family 16
[    0.049673] vc_mem_connected_init: called
[    0.049725] vc_mem_update: resp 0, vcbase=0 vcsize=0 armbase=0 armsize=0
[    0.049759] vc-mem: mm_vc_mem_phys_addr = 0x00000000
[    0.049781] vc-mem: mm_vc_mem_size      = 0x00000000 (0 MiB)
[    0.050136] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.050173] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.050199] mailbox: Broadcom VideoCore Mailbox driver
[    0.050265] bcm2708_vcio: mailbox at f200b880
[    0.050337] bcm_power: Broadcom power driver
[    0.050363] bcm_power_open() -> 0
[    0.050380] bcm_power_request(0, 8)
[    0.550954] bcm_mailbox_read -> 00000080, 0
[    0.550981] bcm_power_request -> 0
[    0.550999] Serial: AMBA PL011 UART driver
[    0.551110] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.875805] console [ttyAMA0] enabled
[    0.893704] bio: create slab <bio-0> at 0
[    0.898587] SCSI subsystem initialized
[    0.902489] usbcore: registered new interface driver usbfs
[    0.908133] usbcore: registered new interface driver hub
[    0.913623] usbcore: registered new device driver usb
[    0.919326] Switching to clocksource stc
[    0.923486] FS-Cache: Loaded
[    0.926569] CacheFiles: Loaded
[    0.938247] NET: Registered protocol family 2
[    0.942932] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.950663] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.958032] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.964641] TCP: Hash tables configured (established 8192 bind 8192)
[    0.971001] TCP reno registered
[    0.974171] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.980029] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.986677] NET: Registered protocol family 1
[    0.991576] RPC: Registered named UNIX socket transport module.
[    0.997638] RPC: Registered udp transport module.
[    1.002347] RPC: Registered tcp transport module.
[    1.007072] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.013723] bcm2708_dma: DMA manager at cc808000
[    1.018422] bcm2708_gpio: bcm2708_gpio_probe c04e3c18
[    1.023783] vc-mem: Videocore memory driver
[    1.028486] audit: initializing netlink socket (disabled)
[    1.033984] type=2000 audit(0.710:1): initialized
[    1.117109] VFS: Disk quotas dquot_6.5.2
[    1.121186] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.128430] FS-Cache: Netfs 'nfs' registered for caching
[    1.134435] msgmni has been set to 369
[    1.139560] io scheduler noop registered
[    1.143609] io scheduler deadline registered (default)
[    1.148861] io scheduler cfq registered
[    1.152883] BCM2708FB: registering framebuffer ([email protected])
[    1.159172] bcm2708_fb_set_par info(cb8b5000) 1920x1080 (1920x1080), 0, 16
[    1.164486] BCM2708FB: start = ccc00000,4d385000 width=1920, height=1080, bpp=16, pitch=3840 size=4177920 success=0
[    1.187339] Console: switching to colour frame buffer device 240x67
[    1.232471] BCM2708FB: register framebuffer (0)
[    1.237575] kgdb: Registered I/O driver kgdboc.
[    1.248744] brd: module loaded
[    1.255364] loop: module loaded
[    1.259212] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[    1.267248] vcos: [1]: vchiq_init_state: called
[    1.272386] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[    1.280133] usbcore: registered new interface driver smsc95xx
[    1.286101] cdc_ncm: 04-Aug-2011
[    1.289485] usbcore: registered new interface driver cdc_ncm
[    1.295282] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.500893] Core Release: 2.80a
[    1.504184] Setting default values for core params
[    1.509083] Finished setting default values for core params
[    1.714485] Using Buffer DMA mode
[    1.717865] Periodic Transfer Interrupt Enhancement - disabled
[    1.723815] Multiprocessor Interrupt Enhancement - disabled
[    1.729482] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.733942] Dedicated Tx FIFOs mode
[    1.737651] dwc_otg: Microframe scheduler enabled
[    1.737685] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.742692] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.750125] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
[    1.755842] Init: Port Power? op_state=1
[    1.759838] Init: Power Port (0)
[    1.763195] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.770154] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.777526] usb usb1: Product: DWC OTG Controller
[    1.782315] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[    1.788184] usb usb1: SerialNumber: bcm2708_usb
[    1.793494] hub 1-0:1.0: USB hub found
[    1.802829] hub 1-0:1.0: 1 port detected
[    1.812929] dwc_otg: FIQ disabled
[    1.812949] Module dwc_common_port init
[    1.813217] usbcore: registered new interface driver uas
[    1.824255] Initializing USB Mass Storage driver...
[    1.835060] usbcore: registered new interface driver usb-storage
[    1.846772] USB Mass Storage support registered.
[    1.857247] usbcore: registered new interface driver libusual
[    1.868983] mousedev: PS/2 mouse device common for all mice
[    1.880246] cpuidle: using governor ladder
[    1.889954] cpuidle: using governor menu
[    1.899563] sdhci: Secure Digital Host Controller Interface driver
[    1.911459] sdhci: Copyright(c) Pierre Ossman
[    1.921479] sdhci: Enable low-latency mode
[    1.931169] bcm_power_open() -> 1
[    1.940222] Registered led device: mmc0::
[    1.941559] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    1.955191] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    1.966825] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.979488] Registered led device: led0
[    1.979775] usbcore: registered new interface driver usbhid
[    1.990997] usbhid: USB HID core driver
[    2.006459] Indeed it is in host mode hprt0 = 00021501
[    2.019851] TCP cubic registered
[    2.031199] Initializing XFRM netlink socket
[    2.063371] NET: Registered protocol family 17
[    2.083383] Registering the dns_resolver key type
[    2.100272] mmc0: problem reading SD Status register.
[    2.111081] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.138333] registered taskstats version 1
[    2.150402] mmc0: new high speed SDHC card at address 1234
[    2.173406] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    2.186006] mmcblk0: mmc0:1234 SA04G 3.65 GiB
[    2.205089]  mmcblk0: p1 p2
[    2.313345] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.325802] Indeed it is in host mode hprt0 = 00001101
[    2.543521] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.555945] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.569479] hub 1-1:1.0: USB hub found
[    2.579059] hub 1-1:1.0: 3 ports detected
[    2.863454] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.973745] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.986348] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.002223] smsc95xx v1.0.4
[    3.068257] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:05:91:bf
[    3.163497] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[    3.313323] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c20a
[    3.326119] usb 1-1.2: New USB device strings: Mfr=4, Product=32, SerialNumber=0
[    3.339374] usb 1-1.2: Product: WingMan RumblePad
[    3.349971] usb 1-1.2: Manufacturer: Logitech Inc.
[    3.443451] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[    3.556427] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b
[    3.569204] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.582406] usb 1-1.3: Product: USB Receiver
[    3.592575] usb 1-1.3: Manufacturer: Logitech
[    6.000351] EXT4-fs warning (device mmcblk0p2): ext4_clear_journal_err:4364: Filesystem error recorded from previous mount: IO failure
[    6.018581] EXT4-fs warning (device mmcblk0p2): ext4_clear_journal_err:4365: Marking fs in need of filesystem check.
[    6.675115] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    6.693400] EXT4-fs (mmcblk0p2): recovery complete
[    6.707286] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    6.721591] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    6.734493] Freeing init memory: 128K
[    9.580224] logitech-djreceiver 0003:046D:C52B.0004: hiddev0: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.3/input2
[   10.207752] mmcblk0: r/w command failed, status = 0x80000900
[   10.233647] end_request: I/O error, dev mmcblk0, sector 7659256
[   10.246107] Buffer I/O error on device mmcblk0, logical block 957407
[   18.743967] logitech 0003:046D:C20A.0001: timeout initializing reports
[   18.863880] input: Logitech Inc. WingMan RumblePad as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
[   18.950861] logitech 0003:046D:C20A.0001: input: USB HID v1.10 Joystick [Logitech Inc. WingMan RumblePad] on usb-bcm2708_usb-1.2/input0
[   23.350319] mmcblk0: r/w command failed, status = 0x80000900
[   23.376498] end_request: I/O error, dev mmcblk0, sector 8200
[   23.389003] Buffer I/O error on device mmcblk0p1, logical block 1
[   33.259107] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   33.860215] ### snd_bcm2835_alsa_probe c04e4430 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
[   33.878185] Creating card...
[   33.888142] Creating device/chip ..
[   33.899019] Adding controls ..
[   33.909147] Registering card ....
[   33.925465] bcm2835 ALSA CARD CREATED!
[   33.945767] ### BCM2835 ALSA driver init OK ###
[   41.928317] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
PaulCheffus
Thu Sep 06, 2012 2:53 pm
MaxK1 wrote:Things don't get fixed by
Hi
I couldn't agree more but currently I don't have the time to do any testing before the weekend.
As the one of the prior posters had gone back to 27 July without success and I am pretty sure my working one is 25 July I was trying to say though probably not very well that if he went back one more he might have more success.
Cheers
Paul
MaxK1
So it works now? Good. :D Have fun with your media centers! (Assuming that's what you plan to use them for)
Sleep Mode zZ
Thu Sep 06, 2012 2:58 pm
Here is the output of these commands, after the replugging:
[email protected] ~ $ lsmod
Module                  Size  Used by
snd_bcm2835            20345  0
snd_pcm                74866  1 snd_bcm2835
snd_seq                52536  0
snd_timer              19698  2 snd_seq,snd_pcm
snd_seq_device          6300  1 snd_seq
snd                    52489  5 snd_seq_device,snd_timer,snd_seq,snd_pcm,snd_bcm2835
snd_page_alloc          4951  1 snd_pcm
evdev                   8682  1
joydev                  9102  0
hid_logitech_dj        10438  0
hid_logitech            8256  0
[email protected] ~ $ lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 046d:c20a Logitech, Inc. WingMan RumblePad
Bus 001 Device 006: ID 046d:c52b Logitech, Inc. Unifying Receiver
I'm not knowledgeable enough to know how to issue these commands without the keyboard. Another keyboard? (I have a k230, also with a unifying receiver.)
Sleep Mode zZ
Thu Sep 06, 2012 3:28 pm
Hi
Cheers
Paul
I now tested both kernels from July 25 and the one from July 22. They boot to the desktop, the K400 won't work, even after replugging. I suspect that my testing is not giving valid information about these kernels. I will wait for your results.
MaxK1
Thu Sep 06, 2012 4:32 pm
Hmm - If I understand correctly:
- The receiver is always detected.
- The keyboard / pad are not detected on a power up.
- The keyboard / pad are _usually_ but not always, detected after the receiver is re-inserted.
(might take several tries to get it)
I can't help but think something is getting in the way of the devices "pairing" with the receiver.
It could be the new USB driver, but my gut says no.
Maybe something like this in /etc/rc.local: (just for somewhere to put it so it can be tested)
rmmod hid-logitech-dj
modprobe hid-logitech-dj
Hopefully, that will re-initialize the receiver driver after things have settled down.
MaxK1
Thu Sep 06, 2012 4:56 pm
If it works reliably, you have a workaround. If not, maybe we get another data point.
LordDiGio
Thu Sep 06, 2012 5:32 pm
Linux rpi 3.1.9+ #272 PREEMPT Tue Aug 7 22:51:44 BST 2012 armv6l: dmesg, lsmod (With this kernel the keyboard always works)
Linux rpi 3.2.27+ #114 PREEMPT Tue Sep 4 00:15:33 BST 2012 armv6l: dmesg, lsmod (keyboard working after startup)
Linux rpi 3.2.27+ #114 PREEMPT Tue Sep 4 00:15:33 BST 2012 armv6l: dmesg, lsmod (keyboard NOT working after startup)
I noticed now that there isn't a proper module for the keyboard in the 3.1.9+ kernel, it uses a generic driver. So maybe is the logitech driver that is bugged?
MaxK1 wrote:Hmm - If I understand correctly:
Tested now and with this workaround seems that the keyboard works also with the new kernel!
Sleep Mode zZ
Thu Sep 06, 2012 5:44 pm
Probably yes. I can check the dmesg log from the next power ups, just to make sure.
MaxK1 wrote: - The keyboard / pad are not detected on a power up.
With my current the keyboard/pad might be detected on power up.
MaxK1 wrote: - The keyboard / pad are _usually_ but not always, detected after the receiver is re-inserted.
I'm think that re-inserting the receiver works 100%.
MaxK1 wrote: Maybe something like this in /etc/rc.local: (just for somewhere to put it so it can be tested)
I will try that tomorrow.
MaxK1
Thu Sep 06, 2012 6:11 pm
LordDiGio wrote:Linux rpi 3.1.9+ #272 PREEMPT Tue Aug 7 22:51:44 BST 2012 armv6l: dmesg, lsmod (With this kernel the keyboard always works)
Thats great! Is it a workaround you can live with? I think I would need a Logitech keyboard and I doubt they would be happy if I called them for an "engineering sample" :lol:
Sleep Mode zZ
Fri Sep 07, 2012 5:06 am
Power on, k400 works without replugging.
dmesg:
[    0.000647] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.040448] Mount-cache hash table entries: 512
[    0.040798] Initializing cgroup subsys cpuacct
[    0.040862] Initializing cgroup subsys devices
[    0.040886] Initializing cgroup subsys freezer
[    0.040906] Initializing cgroup subsys blkio
[    0.041004] CPU: Testing write buffer coherency: ok
[    0.041255] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.042077] devtmpfs: initialized
[    0.048604] NET: Registered protocol family 16
[    0.049664] vc_mem_connected_init: called
[    0.049716] vc_mem_update: resp 0, vcbase=0 vcsize=0 armbase=0 armsize=0
[    0.049750] vc-mem: mm_vc_mem_phys_addr = 0x00000000
[    0.049772] vc-mem: mm_vc_mem_size      = 0x00000000 (0 MiB)
[    0.050124] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.050162] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.050189] mailbox: Broadcom VideoCore Mailbox driver
[    0.050256] bcm2708_vcio: mailbox at f200b880
[    0.050329] bcm_power: Broadcom power driver
[    0.050354] bcm_power_open() -> 0
[    0.050372] bcm_power_request(0, 8)
[    0.550948] bcm_mailbox_read -> 00000080, 0
[    0.550974] bcm_power_request -> 0
[    0.550991] Serial: AMBA PL011 UART driver
[    0.551100] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.875795] console [ttyAMA0] enabled
[    0.893689] bio: create slab <bio-0> at 0
[    0.898563] SCSI subsystem initialized
[    0.902468] usbcore: registered new interface driver usbfs
[    0.908115] usbcore: registered new interface driver hub
[    0.913603] usbcore: registered new device driver usb
[    0.919302] Switching to clocksource stc
[    0.923461] FS-Cache: Loaded
[    0.926541] CacheFiles: Loaded
[    0.938211] NET: Registered protocol family 2
[    0.942894] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.950621] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.957982] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.964590] TCP: Hash tables configured (established 8192 bind 8192)
[    0.970949] TCP reno registered
[    0.974118] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.979975] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.986624] NET: Registered protocol family 1
[    0.991522] RPC: Registered named UNIX socket transport module.
[    0.997582] RPC: Registered udp transport module.
[    1.002291] RPC: Registered tcp transport module.
[    1.007017] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.013666] bcm2708_dma: DMA manager at cc808000
[    1.018365] bcm2708_gpio: bcm2708_gpio_probe c04e3c18
[    1.023726] vc-mem: Videocore memory driver
[    1.028428] audit: initializing netlink socket (disabled)
[    1.033925] type=2000 audit(0.710:1): initialized
[    1.116763] VFS: Disk quotas dquot_6.5.2
[    1.120839] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.128085] FS-Cache: Netfs 'nfs' registered for caching
[    1.134086] msgmni has been set to 369
[    1.139209] io scheduler noop registered
[    1.143156] io scheduler deadline registered (default)
[    1.148504] io scheduler cfq registered
[    1.152530] BCM2708FB: registering framebuffer ([email protected])
[    1.158813] bcm2708_fb_set_par info(cb8b5000) 1920x1080 (1920x1080), 0, 16
[    1.164258] BCM2708FB: start = ccc00000,4d385000 width=1920, height=1080, bpp=16, pitch=3840 size=4177920 success=0
[    1.186741] Console: switching to colour frame buffer device 240x67
[    1.231509] BCM2708FB: register framebuffer (0)
[    1.236607] kgdb: Registered I/O driver kgdboc.
[    1.247787] brd: module loaded
[    1.254404] loop: module loaded
[    1.258245] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[    1.266272] vcos: [1]: vchiq_init_state: called
[    1.271405] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[    1.279146] usbcore: registered new interface driver smsc95xx
[    1.285108] cdc_ncm: 04-Aug-2011
[    1.288489] usbcore: registered new interface driver cdc_ncm
[    1.294285] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.499889] Core Release: 2.80a
[    1.503113] Setting default values for core params
[    1.508079] Finished setting default values for core params
[    1.713481] Using Buffer DMA mode
[    1.716864] Periodic Transfer Interrupt Enhancement - disabled
[    1.722786] Multiprocessor Interrupt Enhancement - disabled
[    1.728477] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.732919] Dedicated Tx FIFOs mode
[    1.736644] dwc_otg: Microframe scheduler enabled
[    1.736678] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.741685] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.749118] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
[    1.754833] Init: Port Power? op_state=1
[    1.758826] Init: Power Port (0)
[    1.762183] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.769139] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.776509] usb usb1: Product: DWC OTG Controller
[    1.781296] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[    1.787156] usb usb1: SerialNumber: bcm2708_usb
[    1.792396] hub 1-0:1.0: USB hub found
[    1.801775] hub 1-0:1.0: 1 port detected
[    1.811828] dwc_otg: FIQ disabled
[    1.811849] Module dwc_common_port init
[    1.812112] usbcore: registered new interface driver uas
[    1.823087] Initializing USB Mass Storage driver...
[    1.833848] usbcore: registered new interface driver usb-storage
[    1.845536] USB Mass Storage support registered.
[    1.855953] usbcore: registered new interface driver libusual
[    1.867651] mousedev: PS/2 mouse device common for all mice
[    1.878867] cpuidle: using governor ladder
[    1.888547] cpuidle: using governor menu
[    1.898122] sdhci: Secure Digital Host Controller Interface driver
[    1.909980] sdhci: Copyright(c) Pierre Ossman
[    1.919966] sdhci: Enable low-latency mode
[    1.929609] bcm_power_open() -> 1
[    1.939626] Registered led device: mmc0::
[    1.940956] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    1.954555] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    1.966129] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.978737] Registered led device: led0
[    1.979025] usbcore: registered new interface driver usbhid
[    1.990247] usbhid: USB HID core driver
[    2.005682] Indeed it is in host mode hprt0 = 00021501
[    2.019016] TCP cubic registered
[    2.030316] Initializing XFRM netlink socket
[    2.063344] NET: Registered protocol family 17
[    2.083356] Registering the dns_resolver key type
[    2.099490] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.117018] mmc0: new high speed SDHC card at address 1234
[    2.144349] registered taskstats version 1
[    2.154270] mmcblk0: mmc0:1234 SA04G 3.65 GiB
[    2.173393] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    2.187276]  mmcblk0: p1 p2
[    2.215403] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    2.243604] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.257515] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.269918] Freeing init memory: 128K
[    2.313366] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.326452] Indeed it is in host mode hprt0 = 00001101
[    2.543575] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.556186] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.569819] hub 1-1:1.0: USB hub found
[    2.579559] hub 1-1:1.0: 3 ports detected
[    2.863465] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.973832] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.997834] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.027222] smsc95xx v1.0.4
[    3.108352] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:05:91:bf
[    3.223489] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[    3.370349] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c20a
[    3.397339] usb 1-1.2: New USB device strings: Mfr=4, Product=32, SerialNumber=0
[    3.423357] usb 1-1.2: Product: WingMan RumblePad
[    3.443383] usb 1-1.2: Manufacturer: Logitech Inc.
[    3.563543] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[    3.676355] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b
[    3.702306] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.727563] usb 1-1.3: Product: USB Receiver
[    3.748556] usb 1-1.3: Manufacturer: Logitech
[    4.613741] logitech-djreceiver 0003:046D:C52B.0004: hiddev0: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.3/input2
[    5.806693] input: Logitech Unifying Device. Wireless PID:400e as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0004/input/input0
[    5.918020] mmcblk0: r/w command failed, status = 0x80000900
[    5.943573] end_request: I/O error, dev mmcblk0, sector 7659256
[    5.955998] Buffer I/O error on device mmcblk0, logical block 957407
[    6.095827] logitech-djdevice 0003:046D:C52B.0005: input: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:400e] on usb-bcm2708_usb-1.3:1
[   14.663620] logitech 0003:046D:C20A.0001: timeout initializing reports
[   14.829221] input: Logitech Inc. WingMan RumblePad as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input1
[   14.942158] logitech 0003:046D:C20A.0001: input: USB HID v1.10 Joystick [Logitech Inc. WingMan RumblePad] on usb-bcm2708_usb-1.2/input0
[   17.927644] mmcblk0: r/w command failed, status = 0x80000900
[   17.953368] end_request: I/O error, dev mmcblk0, sector 8192
[   17.966064] Buffer I/O error on device mmcblk0p1, logical block 0
[   23.568656] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   24.162790] ### snd_bcm2835_alsa_probe c04e4430 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
[   24.181073] Creating card...
[   24.191209] Creating device/chip ..
[   24.202292] Adding controls ..
[   24.212621] Registering card ....
[   24.229191] bcm2835 ALSA CARD CREATED!
[   24.249695] ### BCM2835 ALSA driver init OK ###
[   31.813890] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
lsmod and lsusb:
Module                  Size  Used by
snd_bcm2835            20345  0
snd_seq                52536  0
evdev                   8682  1
joydev                  9102  0
hid_logitech            8256  0
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
The kernel is the same as in the previous - Linux raspberrypi 3.2.27+ #102 PREEMPT Sat Sep 1 01:00:50 BST 2012 armv6l GNU/Linux.
Sleep Mode zZ
Fri Sep 07, 2012 5:21 am
Added the two lines to /etc/rc.local:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
exit 0
K400 needed replugging before working.
dmesg:
[    0.000646] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.040113] pid_max: default: 32768 minimum: 301
[    0.040801] Initializing cgroup subsys cpuacct
[    0.040866] Initializing cgroup subsys devices
[    0.040890] Initializing cgroup subsys freezer
[    0.041009] CPU: Testing write buffer coherency: ok
[    0.042078] devtmpfs: initialized
[    0.048610] NET: Registered protocol family 16
[    0.049671] vc_mem_connected_init: called
[    0.049723] vc_mem_update: resp 0, vcbase=0 vcsize=0 armbase=0 armsize=0
[    0.049758] vc-mem: mm_vc_mem_phys_addr = 0x00000000
[    0.049779] vc-mem: mm_vc_mem_size      = 0x00000000 (0 MiB)
[    0.050132] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.050171] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.050197] mailbox: Broadcom VideoCore Mailbox driver
[    0.050263] bcm2708_vcio: mailbox at f200b880
[    0.050381] bcm_power_request(0, 8)
[    0.550955] bcm_mailbox_read -> 00000080, 0
[    0.550982] bcm_power_request -> 0
[    0.551000] Serial: AMBA PL011 UART driver
[    0.551109] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.875807] console [ttyAMA0] enabled
[    0.893708] bio: create slab <bio-0> at 0
[    0.898583] SCSI subsystem initialized
[    0.908136] usbcore: registered new interface driver hub
[    0.919327] Switching to clocksource stc
[    0.923491] FS-Cache: Loaded
[    0.926571] CacheFiles: Loaded
[    0.938236] NET: Registered protocol family 2
[    0.942920] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.950650] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.958018] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.964624] TCP: Hash tables configured (established 8192 bind 8192)
[    0.970985] TCP reno registered
[    0.974155] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.980013] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.986663] NET: Registered protocol family 1
[    0.991564] RPC: Registered named UNIX socket transport module.
[    0.997625] RPC: Registered udp transport module.
[    1.002335] RPC: Registered tcp transport module.
[    1.007061] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.013711] bcm2708_dma: DMA manager at cc808000
[    1.018408] bcm2708_gpio: bcm2708_gpio_probe c04e3c18
[    1.023767] vc-mem: Videocore memory driver
[    1.028471] audit: initializing netlink socket (disabled)
[    1.033968] type=2000 audit(0.710:1): initialized
[    1.117094] VFS: Disk quotas dquot_6.5.2
[    1.121170] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.128415] FS-Cache: Netfs 'nfs' registered for caching
[    1.134415] msgmni has been set to 369
[    1.139536] io scheduler noop registered
[    1.143586] io scheduler deadline registered (default)
[    1.148836] io scheduler cfq registered
[    1.152859] BCM2708FB: registering framebuffer ([email protected])
[    1.159150] bcm2708_fb_set_par info(cb8b5000) 1920x1080 (1920x1080), 0, 16
[    1.165515] BCM2708FB: start = ccc00000,4d385000 width=1920, height=1080, bpp=16, pitch=3840 size=4177920 success=0
[    1.188353] Console: switching to colour frame buffer device 240x67
[    1.233483] BCM2708FB: register framebuffer (0)
[    1.238550] kgdb: Registered I/O driver kgdboc.
[    1.249707] brd: module loaded
[    1.256338] loop: module loaded
[    1.260187] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[    1.268224] vcos: [1]: vchiq_init_state: called
[    1.273424] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[    1.281065] usbcore: registered new interface driver smsc95xx
[    1.287029] cdc_ncm: 04-Aug-2011
[    1.290413] usbcore: registered new interface driver cdc_ncm
[    1.296210] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.501824] Core Release: 2.80a
[    1.505117] Setting default values for core params
[    1.510017] Finished setting default values for core params
[    1.715418] Using Buffer DMA mode
[    1.718804] Periodic Transfer Interrupt Enhancement - disabled
[    1.724757] Multiprocessor Interrupt Enhancement - disabled
[    1.730426] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.734885] Dedicated Tx FIFOs mode
[    1.738594] dwc_otg: Microframe scheduler enabled
[    1.738627] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.743681] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.751070] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
[    1.756800] Init: Port Power? op_state=1
[    1.760798] Init: Power Port (0)
[    1.764190] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.771105] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.778482] usb usb1: Product: DWC OTG Controller
[    1.783273] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[    1.789141] usb usb1: SerialNumber: bcm2708_usb
[    1.794408] hub 1-0:1.0: USB hub found
[    1.803793] hub 1-0:1.0: 1 port detected
[    1.813895] dwc_otg: FIQ disabled
[    1.813915] Module dwc_common_port init
[    1.814180] usbcore: registered new interface driver uas
[    1.825205] Initializing USB Mass Storage driver...
[    1.835982] usbcore: registered new interface driver usb-storage
[    1.847683] USB Mass Storage support registered.
[    1.858132] usbcore: registered new interface driver libusual
[    1.869863] mousedev: PS/2 mouse device common for all mice
[    1.881110] cpuidle: using governor ladder
[    1.890806] cpuidle: using governor menu
[    1.900406] sdhci: Secure Digital Host Controller Interface driver
[    1.912194] sdhci: Copyright(c) Pierre Ossman
[    1.922303] sdhci: Enable low-latency mode
[    1.931983] bcm_power_open() -> 1
[    1.941015] Registered led device: mmc0::
[    1.942351] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    1.955975] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    1.967586] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.980223] Registered led device: led0
[    1.980510] usbcore: registered new interface driver usbhid
[    1.991750] usbhid: USB HID core driver
[    2.009515] TCP cubic registered
[    2.018632] Indeed it is in host mode hprt0 = 00021501
[    2.031532] Initializing XFRM netlink socket
[    2.045933] NET: Registered protocol family 17
[    2.073407] Registering the dns_resolver key type
[    2.103407] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.123952] registered taskstats version 1
[    2.143410] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    2.168528] Waiting for root device /dev/mmcblk0p2...
[    2.283346] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.295948] Indeed it is in host mode hprt0 = 00001101
[    2.553563] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.583311] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.604020] hub 1-1:1.0: USB hub found
[    2.623454] hub 1-1:1.0: 3 ports detected
[    2.923411] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.053700] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.083314] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.106204] smsc95xx v1.0.4
[    3.188094] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:05:91:bf
[    3.303469] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[    3.451912] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c20a
[    3.483315] usb 1-1.2: New USB device strings: Mfr=4, Product=32, SerialNumber=0
[    3.503399] usb 1-1.2: Product: WingMan RumblePad
[    3.523315] usb 1-1.2: Manufacturer: Logitech Inc.
[    3.633386] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[    3.766105] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b
[    3.793317] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.823307] usb 1-1.3: Product: USB Receiver
[    3.843317] usb 1-1.3: Manufacturer: Logitech
[    7.731625] mmc0: Controller never released inhibit bit(s).
[    7.745176] mmc0: problem reading SD Status register.
[    7.756213] mmc0: new SDHC card at address 1234
[    7.767182] mmcblk0: mmc0:1234 SA04G 3.65 GiB
[    7.779413] mmcblk0: timed out sending r/w cmd command, card status 0x400900
[    7.794819]  mmcblk0: p1 p2
[    7.958907] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    7.988184] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.002360] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    8.015132] Freeing init memory: 128K
[   13.176192] logitech-djreceiver 0003:046D:C52B.0004: hiddev0: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.3/input2
[   13.718719] input: Logitech Unifying Device. Wireless PID:400e as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0004/input/input0
[   13.906388] logitech-djdevice 0003:046D:C52B.0005: input: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:400e] on usb-bcm2708_usb-1.3:1
[   22.527836] logitech 0003:046D:C20A.0001: timeout initializing reports
[   22.607153] input: Logitech Inc. WingMan RumblePad as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input1
[   22.692912] logitech 0003:046D:C20A.0001: input: USB HID v1.10 Joystick [Logitech Inc. WingMan RumblePad] on usb-bcm2708_usb-1.2/input0
[   33.263521] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   34.103341] ### snd_bcm2835_alsa_probe c04e4430 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
[   34.128325] Creating card...
[   34.144320] Creating device/chip ..
[   34.155291] Adding controls ..
[   34.165441] Registering card ....
[   34.181681] bcm2835 ALSA CARD CREATED!
[   34.202067] ### BCM2835 ALSA driver init OK ###
[   38.178361] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[   38.192886] mmc0: DMA IRQ 6 ignored - results were reset
[   42.972048] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
lsmod and lsusb:
Module                  Size  Used by
snd_bcm2835            20345  0
snd_seq                52536  0
evdev                   8682  1
joydev                  9102  0
hid_logitech            8256  0
MaxK1
Fri Sep 07, 2012 3:07 pm
Try adding dwc_otg.fiq_fix_enable=1 and/or dwc_otg.microframe_schedule=1 to /boot/cmdline.txt (all on one line) and any others that Dom et al suggest, now or in the future. When doing that, comment out the "workaround" to see if it is really fixed by the USB driver changes or it just changes the "flavor" of the the bug...
Don't know what else to suggest. Anybody else have any thoughts?
PaulCheffus
Fri Sep 07, 2012 3:46 pm
MaxK1 wrote:Don't know what else to suggest. Anybody else have any thoughts?
Hi
I still plan on trying to upgrade my working version by copying the files from github this eekend starting with the version after the one on the card and see which one breaks it. I have backed up the card so I can always go back if it goes wrong.
I am assuming I will need to replicate what rpi-update does for each change of the firmware and it won't be enough to just overwrite kernel.img file each time.
Hopefully this will point someone at the problem area and which should enable it to be corrected especially as it used to work without issue.
Cheers
Paul
Sleep Mode zZ
Fri Sep 07, 2012 6:23 pm
MaxK1 wrote:Try adding dwc_otg.fiq_fix_enable=1 and/or dwc_otg.microframe_schedule=1 to /boot/cmdline.txt (all on one line) and any others that Dom et al suggest, now or in the future. When doing that, comment out the "workaround" to see if it is really fixed by the USB driver changes or it just changes the "flavor" of the the bug...
Tried now the cmdline.txt additions. Did not change things, k400 needed replugging.
thegr8brian
Mon Sep 10, 2012 5:47 pm
Same issue with the K400 and current kernel here. Any updates or are we just sticking with the unload reload at boot?
MaxK1
Mon Sep 10, 2012 6:50 pm
Dunno - It worked for 1 person, not for another and I haven't heard from the 3rd.
Yes, No and Maybe? If the assumed "workaround" works for you, great. The Logitech driver
hasn't changed and the USB driver is in (near) constant flux.
thegr8brian
Mon Sep 10, 2012 7:23 pm
MaxK1 wrote:Dunno - It worked for 1 person, not for another and I haven't heard from the 3rd.
hmm, well I'll give it a try later today and report back on my results.
PaulCheffus
Mon Sep 10, 2012 7:38 pm
Hi
Unfortunately things are getting in the way of me having any time with my Pi. I will get around to testing I promise.
Cheers
Paul
thegr8brian
Tue Sep 11, 2012 3:39 pm
Unloading and loading the module in rc.local works for me.
Booted/rebooted 10-20 times and never lost keyboard control.
MaxK1
Tue Sep 11, 2012 5:57 pm
2 success stories is better than 0. Sleep Mode zZ hasn't had any luck, so let me ask you to unplug any
other USB devices and see if it works then.
