thankfulN00b
Re: [Guide] Kodi on Raspbian Buster
Mon Jun 08, 2020 2:30 pm
Dear Forum,
I use the 18.6 Kodi on Debian Buster (headless) on my RP4. I adjusted all the audio settings so I could enjoy 5.1 Surround and it seems to works fine.
However, after pausing the video for a couple of seconds (or more) the center channnel suddenly switches to the right or left channel. It only happens when AAC/PCM is routed to the receiver (not with DTS, DD+... passthrough).
This can be fixed (during playback) whenever switch around between the output configuration options. There seems to be no particular setting that does the trick it just helps shuffeling back and forth between these options (best match, optimised, fixed). Eventually the center channel is back on track.
I posted this here https://forum.kodi.tv/showthread.php?tid=354589 and I seem to be not the only one that has encountered this bug.
Puck mentioned it might be fixed in 18.7 ("Fixes around multi-channel audio track support").
Do you have an idea when 18.7 will released for buster, and how likely it its to fix that?
Rascas
Mon Jun 08, 2020 2:31 pm
brunoj wrote:
Sun Jun 07, 2020 11:48 pm
Hi guys,
After 2 years of absolutely flawless functioning, after updating to Kodi 18.6.2, suddenly my Kodi install started behaving weirdly.
After a week of research of every possible aspect of my install, I've noticed that, since 18.6.2, for some reason Kodi ignores the "memorysize" line in my advancedsettings.xml, whilst properly observing the rest.
From the log:
2020-06-08 01:11:34.570 T:1900434352  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <cache>
                                                <buffermode>1</buffermode>
                                                <memorysize>‭47772160‬</memorysize>
                                                <readfactor>5</readfactor>
                                              </cache>
                                            </advancedsettings>
However, also:
2020-06-08 01:22:07.550 T:1900389296  NOTICE: cache.memorysize: 0MB
Changing these values would change Kodi behavior in expected ways, except for the memorysize value, which seems to be ignored in all cases.
Ultimately, I found that the weird behavior of Kodi (intermittent stopping of movies, strange buffering issues) was caused by filecache being used instead of RAM for buffering (memorysize=0, instead of the set amount) and then Kodi /OS running out of disk space as a result.
I have temporarily resolved the problem by cloning my SD card onto a bigger one, and mounting .kodi/userdata/temp to its own, huge partition. While this solution works just fine from a Kodi-behaviour perspective, it can't be a permanent solution due to tear and wear on the card.
Can you please verify is this is a bug, or otherwise suggest what I could do?
Which RPi version ? Works fine on RPi 3B here at least.
pi@raspberrypi:~ $ cat ~/.kodi/temp/kodi.log | grep memorysize
                                                <memorysize>31457280</memorysize>
                                                <memorysize>139460608</memorysize>
2020-06-08 15:59:00.614 T:1900405680  NOTICE: cache.memorysize: 133MB
pi@raspberrypi:~ $ cat ~/.kodi/userdata/advancedsettings.xml
<advancedsettings>
  <cache>
    <readfactor>20</readfactor>
  </cache>
</advancedsettings>
pi@raspberrypi:~ $
brunoj
Mon Jun 08, 2020 3:30 pm
Also RPi 3B, actually.
I've tried a clean install as well, and the issue persists. Any idea?
Rascas
Mon Jun 08, 2020 3:55 pm
I don't know what you consider a clean install, but if it is "just" removing and installing Kodi again, the settings will persist. To start Kodi with clean/default settings, you just need to remove your ~/.kodi folder, generally /home/pi/.kodi if you are using "pi" user.
But post your Kodi debug log, maybe we can find what's wrong with your install: https://kodi.wiki/view/Log_file
Tue Jun 09, 2020 11:21 am
Something broke today
root@ulysses:~ # apt dist-upgrade -y
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  kodi kodi-bin
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 39.9 MB of archives.
After this operation, 5,120 B of additional disk space will be used.
Err:1 http://pipplware.pplware.pt/pipplware/dists/buster/main/binary  kodi 2:18.7-1~buster
  404  Not Found [IP: 176.221.32.193 80]
Err:2 http://pipplware.pplware.pt/pipplware/dists/buster/main/binary  kodi-bin 2:18.7-1~buster
E: Failed to fetch http://pipplware.pplware.pt/pipplware/dists/buster/main/binary/./kodi_18.7-1~buster_all.deb  404  Not Found [IP: 176.221.32.193 80]
E: Failed to fetch http://pipplware.pplware.pt/pipplware/dists/buster/main/binary/./kodi-bin_18.7-1~buster_armhf.deb  404  Not Found [IP: 176.221.32.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@ulysses:~ #
Rascas
Tue Jun 09, 2020 2:57 pm
  kodi kodi-bin
root@ulysses:~ #
Yes, there was a problem with the RPi4 binary and I removed it yesterday, but I still didn't have the time to take a look at it. I will update it ASAP.
brunoj
Tue Jun 09, 2020 3:30 pm
Hi, thank you for the quick response.
Yes, I meant a clean install - remove .Kodi folder, full purge and reinstall of kodi binaries.
My log file (of the clean install) is here:
https://paste.kodi.tv/mozutoxizu.kodi
Thank you.
Tue Jun 09, 2020 4:11 pm
Thank you. If you need a guinea pig to try out your fix, just shout.
thatchunkylad198966
Wed Jun 10, 2020 1:05 pm
Any ideas why when I start Kodi I get a black screen with a cursor?
I changed the GPU ram to 128mb.
What am I doing wrong?
I installed with: sudo apt install --no-install-recommends kodi"
Cheers for your work. :D :mrgreen:
One man's trash is another man's treasure! :) Pi's I have; Pi Zero, Pi Zero W, Pi 2 x2, Pi 3 x2, Pi 4 4GB x2.
Rascas
Wed Jun 10, 2020 1:12 pm
Thank you.
Your log seems fine, I have no idea. It can be your advancedsettings.xml file formatting. Make sure you create and edit the file on the RPi, don't create it on a windows machine.
Rascas
Wed Jun 10, 2020 1:13 pm
Check first post for memory recomendations. If after that it still doesn't work, post you Kodi debug log.
thatchunkylad198966
Wed Jun 10, 2020 1:28 pm
Hmmm, it was already set to 256mb. I checked then tried to run Kodi.
Here's Kodi's log:
2020-06-10 14:18:58.817 T:2972683360  NOTICE: -----------------------------------------------------------------------
2020-06-10 14:18:58.817 T:2972683360  NOTICE: Starting Kodi (18.6 Git:20200506-40c074c06b). Platform: Linux ARM 32-bit
2020-06-10 14:18:58.817 T:2972683360  NOTICE: Using Release Kodi x32 build
2020-06-10 14:18:58.817 T:2972683360  NOTICE: Kodi compiled 2020-05-12 by GCC 8.3.0 for Linux ARM 32-bit version 4.18.20 (266772)
2020-06-10 14:18:58.818 T:2972683360  NOTICE: Running on Raspbian GNU/Linux 10 (buster), kernel: Linux ARM 32-bit version 4.19.118-v7l+
2020-06-10 14:18:58.820 T:2972683360  NOTICE: FFmpeg version/source: 4.0.4-Kodi
2020-06-10 14:18:58.821 T:2972683360  NOTICE: Host CPU: ARMv7 Processor rev 3 (v7l), 4 cores available
2020-06-10 14:18:58.821 T:2972683360  NOTICE: ARM Features: Neon enabled
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://envhome/ is mapped to: /home/pi
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://home/ is mapped to: /home/pi/.kodi
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2020-06-10 14:18:58.821 T:2972683360  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2020-06-10 14:18:58.821 T:2972683360  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8
2020-06-10 14:18:58.821 T:2972683360  NOTICE: Local hostname: raspberrypi
2020-06-10 14:18:58.821 T:2972683360  NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2020-06-10 14:18:58.822 T:2972683360  NOTICE: -----------------------------------------------------------------------
2020-06-10 14:18:58.827 T:2972683360    INFO: loading settings
2020-06-10 14:18:58.829 T:2972683360  NOTICE: special://profile/ is mapped to: special://masterprofile/
2020-06-10 14:18:58.855 T:2972683360   DEBUG: CSkinSettings: no <skinsettings> tag found
2020-06-10 14:18:58.858 T:2972683360  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2020-06-10 14:18:58.858 T:2972683360  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="UTF-8" ?>
                                            <advancedsettings>
                                              <fanartres>720</fanartres>
                                              <imageres>540</imageres>
                                              <video>
                                                <busydialogdelayms>750</busydialogdelayms>
                                              </video>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                              <cache>
                                              </cache>
                                            </advancedsettings>
2020-06-10 14:18:58.858 T:2972683360 WARNING: CSettingsManager: missing version attribute
2020-06-10 14:18:58.859 T:2972683360  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2020-06-10 14:18:58.860 T:2972683360  NOTICE: Default Video Player: VideoPlayer
2020-06-10 14:18:58.860 T:2972683360  NOTICE: Default Audio Player: paplayer
2020-06-10 14:18:58.860 T:2972683360  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2020-06-10 14:18:58.860 T:2972683360  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2020-06-10 14:18:59.888 T:2972683360  NOTICE: PulseAudio: Server found running - will try to use Pulse
2020-06-10 14:18:59.950 T:2972683360  NOTICE: Running database version Addons27
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: game.controller.default v1.0.8 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: game.controller.snes v1.0.8 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: kodi.resource v1.0.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2020-06-10 14:19:00.065 T:2972683360  NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: metadata.local v1.0.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: repository.xbmc.org v3.1.6 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.59 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: script.module.pil v1.1.7 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: skin.estouchy v2.0.28 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: skin.estuary v2.0.27 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: xbmc.addon v18.6.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: xbmc.core v0.1.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: xbmc.gui v5.14.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: xbmc.json v10.3.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: xbmc.python v2.26.0 installed
2020-06-10 14:19:00.066 T:2972683360  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2020-06-10 14:19:00.954 T:2972683360   ERROR: DBus error: org.freedesktop.DBus.Error.InvalidArgs - No such property “CanSuspend”
2020-06-10 14:19:00.955 T:2972683360   ERROR: DBus error: org.freedesktop.DBus.Error.InvalidArgs - No such property “CanHibernate”
2020-06-10 14:19:00.969 T:2951737552 WARNING: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
2020-06-10 14:19:00.971 T:2951737552  NOTICE: Found 2 Lists of Devices
2020-06-10 14:19:00.971 T:2951737552  NOTICE: Enumerated PI devices:
2020-06-10 14:19:00.971 T:2951737552  NOTICE:     Device 1
2020-06-10 14:19:00.971 T:2951737552  NOTICE:         m_deviceName      : HDMI
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_displayName     : HDMI
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_displayNameExtra:
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_channels        : FL, FR
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2020-06-10 14:19:00.972 T:2951737552  NOTICE:     Device 2
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_deviceName      : Analogue
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_displayName     : Analogue
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_sampleRates     : 48000
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_streamTypes     : No passthrough capabilities
2020-06-10 14:19:00.972 T:2951737552  NOTICE:     Device 3
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_deviceName      : Both
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_displayName     : HDMI and Analogue
2020-06-10 14:19:00.972 T:2951737552  NOTICE: Enumerated PULSE devices:
2020-06-10 14:19:00.972 T:2951737552  NOTICE:     Device 1
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_deviceName      : Default
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_displayName     : Default
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_displayNameExtra: Default Output Device (PULSEAUDIO)
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2020-06-10 14:19:00.972 T:2951737552  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
I'm using i3-wm so maybe that is why?
Rascas
Wed Jun 10, 2020 1:33 pm
It shouldn't be a problem. In which VT does it run ? Does it work if you change to another VT and run Kodi from there ? If not, what is the output ?
thatchunkylad198966
Wed Jun 10, 2020 1:35 pm
Sorry but what's "VT" ?
Rascas
Wed Jun 10, 2020 1:38 pm
Virtual Terminal. You can use CTRL+ALT+FX in which X is the VT number. For example CTRL+ALT+F2 changes to VT2.
Rascas
Wed Jun 10, 2020 1:39 pm
Virtual Terminal. You can use CTRL+ALT+FX in which X is the VT number. For example CTRL+ALT+F2 changes to VT2. Desktop Environments generally use VT7.
brunoj
Wed Jun 10, 2020 5:02 pm
Edit:
The problem is solved. It was a formatting issue, though not a line-terminator one.
What I've done is copy the advancedsettings.xml from share/kodo/system and edit that. Now cache works as it should again.
Rascas
Fri Jun 12, 2020 8:05 pm
Kodi updated to 18.7
No Raspbian specific changes, except for one 5.4 kernel fix for the RPi 2/3 (Thanks Dom aka popcornmix). For more info check the github page.
Just update and upgrade the packages has you normally do.*
*Note that this packages are not yet available on Raspberry Pi repos, only on the PiPplware repo, you have to wait a little bit.
thatchunkylad198966
Mon Jun 15, 2020 7:05 pm
It has been added to the Raspi repos now, just had an update for Kodi to 18.7...
spectrum6
Fri Jul 03, 2020 9:17 pm
@Rascas
Nice job on the Kodi build, it has been running great.
I couldn't find it mentioned anywhere in this topic, but is the Libretro cores available anywhere? I see you have kodi-game-libretro, but there are apparently no cores/emulators installed. Is that available through another repository?
If you poke over at Team Kodi's PPA, it looks like there are a bunch of other packages kodi-game-libretro-bnes, kodi-game-libretro-stella, etc.
https://launchpad.net/%7Eteam-xbmc/+arc ... &start=150
Thanks.
titou43
Re: [Guide] Kodi on Raspberry Pi OS / Raspbian Buster
Sun Jul 05, 2020 2:06 pm
Hello
I have replace my raspi PI 3 by a raspi PI 4 4Go
I have on this PI 3 Kodi who start at the reboot of raspbian
For this I have put a commandline in crontab
@reboot kodi &
This method whas gived in a post in this forum but the post is old and I have not find this....
So i put my question here....
I have downloaded the latest Raspbian and install Kodi on my Raspi PI4 4Go....
When I start the Raspi PI 4 there is no, problem....
Under the desktop Kodi run without problem with my parameter of skin....
So the next...
I need the program Kodi start at the reboot of Raspbian so I have done the same line of command
crontab -e(with nano)
I have write a new line like this on the crontab :
@reboot kodi &
So after register I reboot the PI 4 and after the boot I see a blank screen ant imposible to access at kodi and not at the desktop...
If I erase the "@reboot kodi &" on the crontab so there no problem
Rascas
Sun Jul 05, 2020 2:35 pm
Hello
@reboot kodi &
So the next...
@reboot kodi &
On the RPi 4 with Raspbian + desktop, your crontab probably won't work.
On the first post you have a better way of doing what you want.
titou43
Sun Jul 05, 2020 2:38 pm
Hello
I have read the first post and do the option with desktop
Perfect
All Is OK
Many thanks for answer
max11
Wed Jul 22, 2020 11:58 pm
Problem changing resolution in Kodi
I installed Kodi in Raspbian. (Raspbian 10 Buster (kernel: Linux 4.19.118-v7 / Kodi 18.7 Git 20200528 compiled 2020-06-12)
As Kodi in Raspbian isn’t running in windowed mode it always runs on HDMI 0 (the one besides the power adapter).
I wanted Kodi to run on both screens (not at the same time ... so either standard or TV)
My setup:
Standard Monitor (for everyday use) can handle max 1024x768.
I now added a HDMI-switch, so the output of HDMI 0 can either go to the standard monitor (1024x768) or to a tv (resolution 1920x1080).
I then created two profiles with two different resolutions (profile A and profile B).
The profiles are identic except the resolution. But switching from Profile A to Profile B doesn't change the resolution.
On profile B under system settings it says 1920x1080, but if i logon to Profile B it remains on 1024x768 (from profile A)
Is there a way to overcome this?
Thanks for reading.
Max11
Nerd3D
Fri Jul 24, 2020 4:00 am
On a clean install of Raspbian on a Pi4 I get a black screen when launching KODI from the desktop. Not no signal, a blank screen. If I power cycle the TV it's HUD says 720p which is what it should say.
If I take the Pi and connect it to a computer monitor using the same HDMI cable it works as expected.
It displays the Raspbian desktop as expected, but when KODI is launched it just goes black. Is my TV cursed or did I miss some setting for KODI?
HDMI Group = 1
HDMI Mode = 4
Some adjustment to Over scan so the desk top would fit the screen.
Tried HDMI Boot up to 11, Hot plug, Made sure "Fake GL" driver was used.
Return to “Raspberry Pi OS”
