Derty
Re: [Guide] Kodi on Raspbian Buster
Sun Apr 26, 2020 9:03 pm
Thanx a lot !!
georgyous
Sun May 03, 2020 12:35 pm
Hi Guys,
After some years of using Jessie and Kodi 17.3 on my raspberry pi v2(first release of it), I though I would give it a go update to Raspbian 10 (Booster) and latest kodi available(18.6). I am mostly using kodi for sopcast and acestream (using plexus and sopcastro plugins)
I am seeing a strange behaviour that I have no clue how to debug as there is nothing in the logs(even with debug enabled) to go by.
In a nutshell this is what it is happening:
- kodi is starting from systemd and starting normally
- opening up sopcastro plugin try to play a video (that I know for sure it will not work as the channel is offline)
- the interface will freeze right after showing the notifications coming from plexus "Channel notifications failed".
The strange thing is, if I try to use the remove (HDMI CEC), I do see the log lines related to my pressing of the buttons, so this tells me that Kodi is not completely frozen.
Worth saying that also raspberry itself is working and seems to not be even near close to max in regards to memory usage or cpu.
Does anyone have any idea to try out to debug it or get a better idea of what exactly is happening?
Relevant log lines as I can't seem to be able to attach the full log(invalid extension)
2020-05-03 12:18:21.738 T:1900453904   DEBUG: RunScriptWithParams - calling plugin SopcastRO('plugin://plugin.video.sopcastro/','-1','?url=148256&mode=2&name=Tlc&iconimage=%2Fhome%2Fpi%2F.kodi%2Faddons%2Fplugin.video.sopcastro%2Fresources%2Fcore%2Fsopparsers%2Falbanet%2Ficon.png','resume:false')
2020-05-03 12:18:21.739 T:1610617056   DEBUG: Thread LanguageInvoker start, auto delete: false
2020-05-03 12:18:21.740 T:1610617056    INFO: initializing python engine.
2020-05-03 12:18:21.740 T:1610617056   DEBUG: CPythonInvoker(4, /home/pi/.kodi/addons/plugin.video.sopcastro/default.py): start processing
2020-05-03 12:18:21.910 T:1644712160   DEBUG: PushCecKeypress - received key  b duration 213 (rep:0 size:0)
2020-05-03 12:18:21.910 T:1644712160   DEBUG: PushCecKeypress - ignored key  b
2020-05-03 12:18:22.237 T:1610617056   DEBUG: -->Python Interpreter Initialized<--
2020-05-03 12:18:22.237 T:1610617056   DEBUG: CPythonInvoker(4, /home/pi/.kodi/addons/plugin.video.sopcastro/default.py): the source file to load is "/home/pi/.kodi/addons/plugin.video.sopcastro/default.py"
2020-05-03 12:18:22.239 T:1610617056   DEBUG: CPythonInvoker(4, /home/pi/.kodi/addons/plugin.video.sopcastro/default.py): setting the Python path to /home/pi/.kodi/addons/plugin.video.sopcastro:/home/pi/.kodi/addons/script.module.beautifulsoup/lib:/home/pi/.kodi/addons/script.module.certifi/lib:/home/pi/.kodi/addons/script.module.chardet/lib:/home/pi/.kodi/addons/script.module.idna/lib:/home/pi/.kodi/addons/script.module.mechanize/lib:/home/pi/.kodi/addons/script.module.pytz/lib:/home/pi/.kodi/addons/script.module.requests/lib:/home/pi/.kodi/addons/script.module.urllib3/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages
2020-05-03 12:18:22.240 T:1610617056   DEBUG: CPythonInvoker(4, /home/pi/.kodi/addons/plugin.video.sopcastro/default.py): entering source directory /home/pi/.kodi/addons/plugin.video.sopcastro
2020-05-03 12:18:22.241 T:1610617056   DEBUG: CPythonInvoker(4, /home/pi/.kodi/addons/plugin.video.sopcastro/default.py): instantiating addon using automatically obtained id of "plugin.video.sopcastro" dependent on version 2.1.0 of the xbmc.python api
2020-05-03 12:18:24.139 T:1610617056   DEBUG: Mode: 2
2020-05-03 12:18:24.140 T:1610617056   DEBUG: URL: 148256
2020-05-03 12:18:24.140 T:1610617056   DEBUG: Name: Tlc
2020-05-03 12:18:24.140 T:1610617056   DEBUG: Iconimage: /home/pi/.kodi/addons/plugin.video.sopcastro/resources/core/sopparsers/albanet/icon.png
2020-05-03 12:18:24.140 T:1610617056   DEBUG: Parser: None
2020-05-03 12:18:24.140 T:1610617056   DEBUG: Parserfunction: None
2020-05-03 12:18:24.140 T:1610617056   DEBUG: Call sopstreams with name: Tlc sop = 148256
2020-05-03 12:18:24.144 T:1610617056   DEBUG: CAddonSettings[plugin.video.sopcastro]: loading setting definitions
2020-05-03 12:18:24.144 T:1610617056   DEBUG: CAddonSettings[plugin.video.sopcastro]: trying to load setting definitions from old format...
2020-05-03 12:18:24.149 T:1610617056   DEBUG: CAddonSettings[plugin.video.sopcastro]: loading setting values
2020-05-03 12:18:24.150 T:1610617056   DEBUG: CSettingsManager: requested setting (first_run) was not found.
2020-05-03 12:18:24.150 T:1610617056   DEBUG: CAddonSettings[plugin.video.sopcastro]: failed to find definition for setting first_run. Creating a setting on-the-fly...
2020-05-03 12:18:24.154 T:1610617056   DEBUG: Executing: PlayMedia("plugin://program.plexus/?url=148256&mode=2&name=Tlc&iconimage=%2Fhome%2Fpi%2F.kodi%2Faddons%2Fplugin.video.sopcastro%2Fresources%2Fcore%2Fsopparsers%2Falbanet%2Ficon.png")
2020-05-03 12:18:24.154 T:1610617056 WARNING: Attempt to use invalid handle -1
2020-05-03 12:18:24.154 T:1610617056    INFO: CPythonInvoker(4, /home/pi/.kodi/addons/plugin.video.sopcastro/default.py): script successfully run
2020-05-03 12:18:24.154 T:1610617056   DEBUG: onExecutionDone(4, /home/pi/.kodi/addons/plugin.video.sopcastro/default.py)
2020-05-03 12:18:24.205 T:1900453904   DEBUG: StartScript - calling plugin Plexus('plugin://program.plexus/','4','?url=148256&mode=2&name=Tlc&iconimage=%2Fhome%2Fpi%2F.kodi%2Faddons%2Fplugin.video.sopcastro%2Fresources%2Fcore%2Fsopparsers%2Falbanet%2Ficon.png','resume:false')
2020-05-03 12:18:24.208 T:1653104864   DEBUG: Thread LanguageInvoker start, auto delete: false
2020-05-03 12:18:24.208 T:1653104864    INFO: initializing python engine.
2020-05-03 12:18:24.208 T:1653104864   DEBUG: CPythonInvoker(5, /home/pi/.kodi/addons/program.plexus/default.py): start processing
2020-05-03 12:18:24.229 T:1592783072   DEBUG: Thread scriptobs start, auto delete: false
2020-05-03 12:18:24.235 T:1610617056    INFO: Python interpreter stopped
2020-05-03 12:18:24.236 T:1610617056   DEBUG: Thread LanguageInvoker 1610617056 terminating
2020-05-03 12:18:24.429 T:1900453904   DEBUG: ------ Window Init (DialogBusy.xml) ------
2020-05-03 12:18:24.721 T:1653104864   DEBUG: -->Python Interpreter Initialized<--
2020-05-03 12:18:24.722 T:1653104864   DEBUG: CPythonInvoker(5, /home/pi/.kodi/addons/program.plexus/default.py): the source file to load is "/home/pi/.kodi/addons/program.plexus/default.py"
2020-05-03 12:18:24.723 T:1653104864   DEBUG: CPythonInvoker(5, /home/pi/.kodi/addons/program.plexus/default.py): setting the Python path to /home/pi/.kodi/addons/program.plexus:/home/pi/.kodi/addons/script.module.certifi/lib:/home/pi/.kodi/addons/script.module.chardet/lib:/home/pi/.kodi/addons/script.module.idna/lib:/home/pi/.kodi/addons/script.module.requests/lib:/home/pi/.kodi/addons/script.module.urllib3/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages
2020-05-03 12:18:24.724 T:1653104864   DEBUG: CPythonInvoker(5, /home/pi/.kodi/addons/program.plexus/default.py): entering source directory /home/pi/.kodi/addons/program.plexus
2020-05-03 12:18:24.725 T:1653104864   DEBUG: CPythonInvoker(5, /home/pi/.kodi/addons/program.plexus/default.py): instantiating addon using automatically obtained id of "program.plexus" dependent on version 2.1.0 of the xbmc.python api
2020-05-03 12:18:27.835 T:1653104864   DEBUG: CAddonSettings[program.plexus]: loading setting definitions
2020-05-03 12:18:27.835 T:1653104864   DEBUG: CAddonSettings[program.plexus]: trying to load setting definitions from old format...
2020-05-03 12:18:27.843 T:1653104864   DEBUG: CAddonSettings[program.plexus]: loading setting values
2020-05-03 12:18:28.157 T:1653104864   DEBUG: Mode: 2
2020-05-03 12:18:28.157 T:1653104864   DEBUG: URL: 148256
2020-05-03 12:18:28.157 T:1653104864   DEBUG: Name: Tlc
2020-05-03 12:18:28.157 T:1653104864   DEBUG: Iconimage: /home/pi/.kodi/addons/plugin.video.sopcastro/resources/core/sopparsers/albanet/icon.png
2020-05-03 12:18:28.158 T:1653104864   DEBUG: Parser: None
2020-05-03 12:18:28.158 T:1653104864   DEBUG: Parserfunction: None
2020-05-03 12:18:28.158 T:1653104864   DEBUG: Starting Player Sop URL: sop://broker.sopcast.com:3912/148256
2020-05-03 12:18:28.264 T:1653104864   DEBUG: CSettingsManager: requested setting (jynxbox_arm7) was not found.
2020-05-03 12:18:28.265 T:1653104864   DEBUG: [u'/home/pi/.kodi/userdata/addon_data/program.plexus/sopcast/qemu-i386', u'/home/pi/.kodi/userdata/addon_data/program.plexus/sopcast/lib/ld-linux.so.2', '--library-path', u'/home/pi/.kodi/userdata/addon_data/program.plexus/sopcast/lib', u'/home/pi/.kodi/userdata/addon_data/program.plexus/sopcast/sp-sc-auth', 'sop://broker.sopcast.com:3912/148256', '9000', '9001']
2020-05-03 12:18:29.404 T:1653104864   DEBUG: DialogProgress::Open called
2020-05-03 12:18:29.404 T:1653104864   DEBUG: ------ Window Init (DialogConfirm.xml) ------
2020-05-03 12:18:29.404 T:1653104864    INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2020-05-03 12:18:29.840 T:1653104864   DEBUG: Other instance of sopcast is still running
2020-05-03 12:18:39.375 T:1775210720   DEBUG: Thread JobWorker 1775210720 terminating (autodelete)
2020-05-03 12:18:39.376 T:1763709152   DEBUG: Thread JobWorker 1763709152 terminating (autodelete)
2020-05-03 12:18:39.376 T:1755316448   DEBUG: Thread JobWorker 1755316448 terminating (autodelete)
2020-05-03 12:18:39.376 T:1696567520   DEBUG: Thread JobWorker 1696567520 terminating (autodelete)
2020-05-03 12:18:49.908 T:1653104864   DEBUG: ('detect MTU=4c4\nConnection=10\tConnection=10\nConnection=10\tConnection=10\nConnection=11\tConnection=11\ni=2   61\nipExternal:42a94d52  Internal:effaa8c0  portLocal:37344    portExternal1:18856    External2:4509  linkType:61\ntm1.sopserv.com proto=17\ntm2.sopserv.com proto=17\nadv=500\nTD2=4294966044-1252:  1588504718:500:3661786528\ntm1.sopserv.com proto=17\ntm2.sopserv.com proto=17\nadv=500\nTD2=4294966345-951:  1588504720:500:3661788227\nAverage difference=4294966194\n4294966194\n4294966194\n3dbedaf0 28ba0b0d\nNot valid ID\n4c2bf54c d7ff5b54\nsop://broker.sopcast.com:3912/99\nsystem channelID=99\ndetect MTU=4c4\nlocaladdr:\tc0a8faef:22653, externaladdr:524da942:22653\nhook_broker_connect:msgType=2\nreason=1\nbroker connection closed retv=-31\nSO_QUIT\nretv = -104\n\tspsc_cleanup_sysch\nsopch2_schedule_sc_misc_sysch retv=-104\nCHLST blockSize=0\n3661787356:3661787186\nNREDIRECT=3\nchannel ID=148256\ntk:00000000 00000000\nstreamID=24320\ndetect MTU=4c4\nADDRESSU = 83b7ab9\nStart cache thread.\nREQUEST[9:9001\r\nConnection: close\r\nUser-Agent: Python-urllib/2.7\r\n\r\n]\nsply->hook:-17\nhook_broker_connect:msgType=2\nreason=1\nSO_QUIT\nretv = -104\n\tspsc_cleanup\n', '')
2020-05-03 12:18:50.006 T:1900453904   DEBUG: ------ Window Init (DialogNotification.xml) ------
2020-05-03 12:18:50.420 T:1653104864   DEBUG: Player ended at last
2020-05-03 12:18:50.421 T:1653104864    INFO: CPythonInvoker(5, /home/pi/.kodi/addons/program.plexus/default.py): script successfully run
2020-05-03 12:18:50.421 T:1653104864   DEBUG: onExecutionDone(5, /home/pi/.kodi/addons/program.plexus/default.py)
2020-05-03 12:18:50.433 T:1900453904   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2020-05-03 12:18:50.434 T:1592783072   DEBUG: Thread scriptobs 1592783072 terminating
2020-05-03 12:18:50.435 T:1900453904   DEBUG: StartScript - calling plugin Plexus('plugin://program.plexus/','5','?url=148256&mode=2&name=Tlc&iconimage=%2Fhome%2Fpi%2F.kodi%2Faddons%2Fplugin.video.sopcastro%2Fresources%2Fcore%2Fsopparsers%2Falbanet%2Ficon.png','resume:false')
2020-05-03 12:18:50.437 T:1592783072   DEBUG: Thread LanguageInvoker start, auto delete: false
2020-05-03 12:18:50.438 T:1592783072    INFO: initializing python engine.
2020-05-03 12:18:50.438 T:1592783072   DEBUG: CPythonInvoker(6, /home/pi/.kodi/addons/program.plexus/default.py): start processing
2020-05-03 12:18:50.459 T:1763709152   DEBUG: Thread scriptobs start, auto delete: false
2020-05-03 12:18:50.530 T:1653104864    INFO: Python interpreter stopped
2020-05-03 12:18:50.530 T:1653104864   DEBUG: Thread LanguageInvoker 1653104864 terminating
2020-05-03 12:18:50.585 T:1900453904   DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2020-05-03 12:18:51.047 T:1592783072   DEBUG: -->Python Interpreter Initialized<--
2020-05-03 12:18:51.047 T:1592783072   DEBUG: CPythonInvoker(6, /home/pi/.kodi/addons/program.plexus/default.py): the source file to load is "/home/pi/.kodi/addons/program.plexus/default.py"
2020-05-03 12:18:51.049 T:1592783072   DEBUG: CPythonInvoker(6, /home/pi/.kodi/addons/program.plexus/default.py): setting the Python path to /home/pi/.kodi/addons/program.plexus:/home/pi/.kodi/addons/script.module.certifi/lib:/home/pi/.kodi/addons/script.module.chardet/lib:/home/pi/.kodi/addons/script.module.idna/lib:/home/pi/.kodi/addons/script.module.requests/lib:/home/pi/.kodi/addons/script.module.urllib3/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages
2020-05-03 12:18:51.049 T:1592783072   DEBUG: CPythonInvoker(6, /home/pi/.kodi/addons/program.plexus/default.py): entering source directory /home/pi/.kodi/addons/program.plexus
2020-05-03 12:18:51.050 T:1592783072   DEBUG: CPythonInvoker(6, /home/pi/.kodi/addons/program.plexus/default.py): instantiating addon using automatically obtained id of "program.plexus" dependent on version 2.1.0 of the xbmc.python api
2020-05-03 12:18:54.112 T:1592783072   DEBUG: CAddonSettings[program.plexus]: loading setting definitions
2020-05-03 12:18:54.112 T:1592783072   DEBUG: CAddonSettings[program.plexus]: trying to load setting definitions from old format...
2020-05-03 12:18:54.119 T:1592783072   DEBUG: CAddonSettings[program.plexus]: loading setting values
2020-05-03 12:18:54.945 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
2020-05-03 12:18:54.945 T:1644712160   DEBUG: PushCecKeypress - added key a7
2020-05-03 12:18:55.068 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 123 (rep:0 size:1)
2020-05-03 12:18:55.068 T:1644712160   DEBUG: PushCecKeypress - replaced key a7
2020-05-03 12:18:55.921 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:1)
2020-05-03 12:18:55.921 T:1644712160   DEBUG: PushCecKeypress - added key a7
2020-05-03 12:18:56.070 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 149 (rep:0 size:2)
2020-05-03 12:18:56.071 T:1644712160   DEBUG: PushCecKeypress - replaced key a7
2020-05-03 12:18:56.667 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:2)
2020-05-03 12:18:56.667 T:1644712160   DEBUG: PushCecKeypress - added key a7
2020-05-03 12:18:56.839 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 172 (rep:0 size:3)
2020-05-03 12:18:56.839 T:1644712160   DEBUG: PushCecKeypress - replaced key a7
2020-05-03 12:18:57.202 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:3)
2020-05-03 12:18:57.202 T:1644712160   DEBUG: PushCecKeypress - added key a7
2020-05-03 12:18:57.369 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 167 (rep:0 size:4)
2020-05-03 12:18:57.369 T:1644712160   DEBUG: PushCecKeypress - replaced key a7
2020-05-03 12:18:58.165 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:4)
2020-05-03 12:18:58.165 T:1644712160   DEBUG: PushCecKeypress - added key a7
2020-05-03 12:18:58.339 T:1644712160   DEBUG: PushCecKeypress - received key a7 duration 175 (rep:0 size:5)
2020-05-03 12:18:58.340 T:1644712160   DEBUG: PushCecKeypress - replaced key a7
Rascas
Sun May 03, 2020 3:33 pm
Hi Guys,
Plexus and Sopcastro are third party plugins, so unsupported. From what I know, Plexus doesn't work on the RPi for some time now, you have ask the guys who are maintaining the addons that you are using.
derders
Sun May 03, 2020 3:52 pm
Hi Guys,
I don't think that you will get help here because you are using Banned_add-ons
If you can reproduce your problem without these Banned add-ons post a full log.
georgyous
Mon May 04, 2020 2:41 pm
Hi guys,
Did not even know there is such a thing as banned addons.
The strange thing is that switching back to the old card works fine, guess I will keep using 17.3 (by the way plexus is still working fine at least on on 17.3).
Mon May 04, 2020 3:00 pm
Hi guys,
Yes the Kodi Developers are very strict regarding 3rd Party add-ons and piracy is not to discussed in these forums, if it is not on Kodi's list you have to request from the specific add-on developer:
https://kodi.tv/addons
Rascas
Tue May 12, 2020 2:59 pm
Kodi updated to 18.6-2
-https://github.com/PIPplware/xbmc/commi ... 0a7c32f840
-inputstream.adaptive addon updated to 2.4.4 for Disney+ addon support
Just update and upgrade the packages has you normally do.*
*Note that this packages are not yet available on Raspberry Pi repos, only on the PiPplware repo, you have to wait a little bit.
P09
Tue May 12, 2020 6:30 pm
After upgrade to Kodi 18.6~2 (from 18.6~1) Kodi is not starting - crash log:
https://pastebin.com/0nri830i
RPi4 4GB RAM, Raspbian Buster
Linux raspberrypi 5.4.40-v7l+ #1316 SMP Tue May 12 13:10:42 BST 2020 armv7l GNU/Linux
Help needed :(
I tried:
- remove kodi, purge, fresh install
- delete whole ./.kodi dir without success - still same error
- install pulseaudio (I was not using it) without success - still same error
- rpi-update without success - still same error
I tried to run kodi-standalone manually:
kodi-standalone
* failed to add service - already in use?
free(): double free detected in tcache 2
Aborted (core dumped)
Crash report available at /home/pi/kodi_crashlog-20200512_203406.log
[E] Invalid arguments ' '
Crash report available at /home/pi/kodi_crashlog-20200512_203417.log
Crash report available at /home/pi/kodi_crashlog-20200512_203426.log
/usr/bin/kodi --standalone  has exited in an unclean state 3 times in the last 29 seconds.
Something is probably wrong
edit: So I returned to previous version which is OK:
sudo apt-get remove kodi
sudo apt-get autoclean
sudo apt-get autoremove
sudo apt-get install kodi=2:18.6-1~buster kodi-bin=2:18.6-1~buster
I can not recommend to do the upgrade to 18.6~2 ...
edit 2: Everything is fixed now - see below.
amilino
Tue May 12, 2020 7:23 pm
Latest version of Kodi is missing on pipplware.
The following packages will be upgraded:
  kodi kodi-bin libpam-systemd libsystemd0 libudev1 pcmanfm raspi-config
  systemd systemd-sysv udev
10 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 36.7 MB/42.2 MB of archives.
After this operation, 3,072 B of additional disk space will be used.
Do you want to continue? [Y/n]
Err:1 http://pipplware.pplware.pt/pipplware/dists/buster/main/binary  kodi 2:18.6-2~buster
  404  Not Found [IP: 176.221.32.193 80]
Err:2 http://pipplware.pplware.pt/pipplware/dists/buster/main/binary  kodi-bin 2:18.6-2~buster
E: Failed to fetch http://pipplware.pplware.pt/pipplware/dists/buster/main/binary/./kodi_18.6-2~buster_all.deb  404  Not Found [IP: 176.221.32.193 80]
E: Failed to fetch http://pipplware.pplware.pt/pipplware/dists/buster/main/binary/./kodi-bin_18.6-2~buster_armhf.deb  404  Not Found [IP: 176.221.32.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
P09
Tue May 12, 2020 7:25 pm
Yes now it is removed. Maybe there is some bug - see my post above.
Rascas
Tue May 12, 2020 7:26 pm
Yes, there was some problem building, I am taking a look at it now.
amilino
Tue May 12, 2020 7:27 pm
Cool man, you are the best!
P09
Tue May 12, 2020 7:29 pm
Rascas wrote: Yes, there was some problem building, I am taking a look at it now.
Thanks Rascas ... let us know ;)
Rascas
Tue May 12, 2020 9:52 pm
Ok, updated, should be good now.
P09
Wed May 13, 2020 6:21 am
Everything ok now. Thanks Rascas.
max11
Fri May 22, 2020 4:50 pm
i have a problem with the Terratec H6 (identified as Terratec H5 MKii) - Driver: dvb-usb-terratec-h5-drxk.fw.
I have 2 Raspis (Raspi3b+/Stretch) and Raspi4-4GB/Buster.
Problem is the different handling of the driver for the USB-TV stick (Terratec H6 or
H5MkII ).
With stretch/Leia 18.2/Raspi3b+ no errors
With buster/Leia 18.6/Raspi4 4GB always and never ending errors when TV playing
Below see dmesg when I connect the stick to the different Raspis:
Raspberry Pi 3B+
Raspbian Stretch (Kernel: Linux 4.19.66-v7+)
Kodi Leia 18.2 Git:20190428-a94ccc8ba5 - compiled 2019-04-30
Driver dvb-usb-terratec-h5-drxk.fw.
[ 327.813566] usb 1-1.3.3: new high-speed USB device number 21 using dwc_otg
[ 327.945084] usb 1-1.3.3: New USB device found, idVendor=0ccd, idProduct=10b2, bcdDevice= 1.00
[ 327.945095] usb 1-1.3.3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 327.945100] usb 1-1.3.3: Product: TERRATCE H5 MKII
[ 327.945105] usb 1-1.3.3: Manufacturer: TERRATEC
[ 327.945110] usb 1-1.3.3: SerialNumber: 123456789ABCD
[ 327.945878] em28xx 1-1.3.3:1.0: New device TERRATEC TERRATCE H5 MKII @ 480 Mbps (0ccd:10b2, interface 0, class 0)
[ 327.945889] em28xx 1-1.3.3:1.0: Audio interface 0 found (Vendor Class)
[ 327.945895] em28xx 1-1.3.3:1.0: Video interface 0 found: isoc
[ 327.945900] em28xx 1-1.3.3:1.0: DVB interface 0 found: isoc
[ 328.013804] em28xx 1-1.3.3:1.0: chip ID is em2884
[ 328.090977] em28xx 1-1.3.3:1.0: EEPROM ID = 26 00 00 00, EEPROM hash = 0xbcd5a8cf
[ 328.090986] em28xx 1-1.3.3:1.0: EEPROM info:
[ 328.090991] em28xx 1-1.3.3:1.0: microcode start address = 0x0004, boot configuration = 0x00
[ 328.097948] em28xx 1-1.3.3:1.0: I2S audio, 5 sample rates
[ 328.097958] em28xx 1-1.3.3:1.0: 500mA max power
[ 328.097972] em28xx 1-1.3.3:1.0: Table at offset 0x27, strings=0x2298, 0x1c6a, 0x1286
[ 328.163517] em28xx 1-1.3.3:1.0: Identified as Terratec Cinergy H6 rev. 2 (card=101)
[ 328.163534] em28xx 1-1.3.3:1.0: Currently, V4L2 is not supported on this model
[ 328.163541] em28xx 1-1.3.3:1.0: dvb set to isoc mode.
[ 328.163719] em28xx 1-1.3.3:1.0: Binding audio extension
[ 328.163724] em28xx 1-1.3.3:1.0: em28xx-audio.c: Copyright (C) 2006 Markus Rechberger
[ 328.163729] em28xx 1-1.3.3:1.0: em28xx-audio.c: Copyright (C) 2007-2016 Mauro Carvalho Chehab
[ 328.163839] em28xx 1-1.3.3:1.0: Endpoint 0x83 high-speed on intf 0 alt 7 interval = 8, size 196
[ 328.163846] em28xx 1-1.3.3:1.0: Number of URBs: 1, with 64 packets and 192 size
[ 328.169691] em28xx 1-1.3.3:1.0: Audio extension successfully initialized
[ 328.169708] em28xx 1-1.3.3:1.0: Binding DVB extension
[ 328.263488] usb 1-1.3.4: new high-speed USB device number 22 using dwc_otg
[ 328.400889] usb 1-1.3.4: New USB device found, idVendor=0461, idProduct=037b, bcdDevice= 1.01
[ 328.400902] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 328.400907] usb 1-1.3.4: Product: USB Scanner
[ 328.750619] drxk: status = 0x439260d9
[ 328.750642] drxk: detected a drx-3926k, spin A2, xtal 20.250 MHz
[ 332.766944] drxk: DRXK driver version 0.9.4300
[ 332.796015] drxk: frontend initialized.
[ 332.796054] tda18271 4-0060: creating new instance
[ 332.797813] tda18271: TDA18271HD/C2 detected @ 4-0060
[ 333.254709] dvbdev: DVB: registering new adapter (1-1.3.3:1.0)
[ 333.254739] em28xx 1-1.3.3:1.0: DVB: registering adapter 0 frontend 0 (DRXK DVB-C DVB-T)...
[ 333.257065] em28xx 1-1.3.3:1.0: DVB extension successfully initialized
[ 333.257087] em28xx 1-1.3.3:1.0: Registering input extension
[ 333.257479] Registered IR keymap rc-nec-terratec-cinergy-xs
[ 333.258173] rc rc0: 1-1.3.3:1.0 IR as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/rc/rc0
[ 333.258538] input: 1-1.3.3:1.0 IR as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/rc/rc0/input6
[ 333.259012] rc rc0: lirc_dev: driver em28xx registered at minor = 0, scancode receiver, no transmitter
[ 333.259034] em28xx 1-1.3.3:1.0: Input extension successfully initialized
[ 333.357610] tda18271: performing RF tracking filter calibration
[ 335.932682] tda18271: RF tracking filter calibration complete
[ 335.932775] em28xx 1-1.3.3:1.0: DVB: adapter 0 frontend 0 frequency 0 out of range (47000000..864000000)
pi@raspberrypi3:~ $
Starting Kodi/TV there are no errors shown in dmesg.
Raspberry Pi4 4GB
Raspbian Buster
Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l
Kodi Leia 18.6 Git:20200506-40c074c06b
[ 1160.629549] usb 1-1.4: new high-speed USB device number 19 using xhci_hcd
[ 1160.761053] usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
[ 1160.761069] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1160.761083] usb 1-1.4: Product: USB2.0 Hub
[ 1160.765356] hub 1-1.4:1.0: USB hub found
[ 1160.766371] hub 1-1.4:1.0: 4 ports detected
[ 1161.079550] usb 1-1.4.3: new high-speed USB device number 20 using xhci_hcd
[ 1161.210660] usb 1-1.4.3: config 1 interface 0 altsetting 1 endpoint 0x82 has invalid wMaxPacketSize 0
[ 1161.211106] usb 1-1.4.3: New USB device found, idVendor=0ccd, idProduct=10b2, bcdDevice= 1.00
[ 1161.211112] usb 1-1.4.3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1161.211118] usb 1-1.4.3: Product: TERRATCE H5 MKII
[ 1161.211123] usb 1-1.4.3: Manufacturer: TERRATEC
[ 1161.211128] usb 1-1.4.3: SerialNumber: 123456789ABCD
[ 1161.212631] em28xx 1-1.4.3:1.0: New device TERRATEC TERRATCE H5 MKII @ 480 Mbps (0ccd:10b2, interface 0, class 0)
[ 1161.212638] em28xx 1-1.4.3:1.0: Audio interface 0 found (Vendor Class)
[ 1161.212643] em28xx 1-1.4.3:1.0: Video interface 0 found: isoc
[ 1161.212648] em28xx 1-1.4.3:1.0: DVB interface 0 found: isoc
[ 1161.279604] em28xx 1-1.4.3:1.0: chip ID is em2884
[ 1161.355969] em28xx 1-1.4.3:1.0: EEPROM ID = 26 00 00 00, EEPROM hash = 0xbcd5a8cf
[ 1161.355975] em28xx 1-1.4.3:1.0: EEPROM info:
[ 1161.355980] em28xx 1-1.4.3:1.0: microcode start address = 0x0004, boot configuration = 0x00
[ 1161.362742] em28xx 1-1.4.3:1.0: I2S audio, 5 sample rates
[ 1161.362748] em28xx 1-1.4.3:1.0: 500mA max power
[ 1161.362754] em28xx 1-1.4.3:1.0: Table at offset 0x27, strings=0x2298, 0x1c6a, 0x1286
[ 1161.439550] em28xx 1-1.4.3:1.0: Identified as Terratec Cinergy H6 rev. 2 (card=101)
[ 1161.439557] em28xx 1-1.4.3:1.0: Currently, V4L2 is not supported on this model
[ 1161.439562] em28xx 1-1.4.3:1.0: dvb set to isoc mode.
[ 1161.439890] em28xx 1-1.4.3:1.0: Binding audio extension
[ 1161.439895] em28xx 1-1.4.3:1.0: em28xx-audio.c: Copyright (C) 2006 Markus Rechberger
[ 1161.439900] em28xx 1-1.4.3:1.0: em28xx-audio.c: Copyright (C) 2007-2016 Mauro Carvalho Chehab
[ 1161.439944] em28xx 1-1.4.3:1.0: Endpoint 0x83 high-speed on intf 0 alt 7 interval = 8, size 196
[ 1161.439950] em28xx 1-1.4.3:1.0: Number of URBs: 1, with 64 packets and 192 size
[ 1161.440140] em28xx 1-1.4.3:1.0: Audio extension successfully initialized
[ 1161.440146] em28xx 1-1.4.3:1.0: Binding DVB extension
[ 1162.026440] drxk: status = 0x439260d9
[ 1162.026454] drxk: detected a drx-3926k, spin A2, xtal 20.250 MHz
[ 1166.093774] drxk: DRXK driver version 0.9.4300
[ 1166.128472] drxk: frontend initialized.
[ 1166.128501] tda18271 8-0060: creating new instance
[ 1166.130489] tda18271: TDA18271HD/C2 detected @ 8-0060
[ 1166.581015] dvbdev: DVB: registering new adapter (1-1.4.3:1.0)
[ 1166.581037] em28xx 1-1.4.3:1.0: DVB: registering adapter 0 frontend 0 (DRXK DVB-C DVB-T)...
[ 1166.585327] em28xx 1-1.4.3:1.0: DVB extension successfully initialized
[ 1166.585345] em28xx 1-1.4.3:1.0: Registering input extension
[ 1166.585674] Registered IR keymap rc-nec-terratec-cinergy-xs
[ 1166.586085] rc rc0: 1-1.4.3:1.0 IR as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/rc/rc0
[ 1166.586306] input: 1-1.4.3:1.0 IR as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4.3/1-1.4.3:1.0/rc/rc0/input17
[ 1166.586718] rc rc0: lirc_dev: driver em28xx registered at minor = 0, scancode receiver, no transmitter
[ 1166.586740] em28xx 1-1.4.3:1.0: Input extension successfully initialized
[ 1166.684004] tda18271: performing RF tracking filter calibration
[ 1169.340176] tda18271: RF tracking filter calibration complete
[ 1169.340259] em28xx 1-1.4.3:1.0: DVB: adapter 0 frontend 0 frequency 0 out of range (47000000..864000000)
Starting Kodi/TV:
pi@raspberrypi:~ $ dmesg
[ 1634.827663] em28xx 1-1.4.3:1.0: write to i2c device at 0x52 failed with unknown error (status=1)
[ 1634.827669] drxk: i2c read error at addr 0x29
[ 1664.824224] drxk: ERROR: -32000
while sending cmd 0x0205 with params:
[ 1664.824232] drxk: 05 02 ..
[ 1664.824243] drxk: Error -22 on get_qam_lock_status
[ 1664.824251] drxk: Error -22 on get_lock_status
[ 1665.720279] drxk: i2c read error at addr 0x29
[ 1681.826525] em28xx 1-1.4.3:1.0: write to i2c device at 0x52 failed with unknown error (status=200)
[ 1681.826533] drxk: i2c read error at addr 0x29
[ 1683.826949] drxk: ERROR: -32768
[ 1683.826956] drxk: 05 02 ..
[ 1683.826967] drxk: Error -22 on get_qam_lock_status
[ 1683.826975] drxk: Error -22 on get_lock_status
[ 1688.827630] em28xx 1-1.4.3:1.0: write to i2c device at 0x52 failed with unknown error (status=200)
[ 1688.827641] drxk: i2c read error at addr 0x29
pi@raspberrypi:~ $
This Error-procedure goes on as long as the TV (Terratec H6) is playing and stops only when I stop TV
Rascas
Fri May 22, 2020 7:07 pm
H5MkII ).
Raspberry Pi 3B+
pi@raspberrypi3:~ $
Raspberry Pi4 4GB
Raspbian Buster
Starting Kodi/TV:
pi@raspberrypi:~ $
This looks like a kernel or kernel + module/driver for that tuner. Not something in Kodi itself.
I recommend that you open a new topic about that or maybe better, post an issue on Raspberry Pi kernel github page.
max11
Sat May 23, 2020 1:31 am
Thanks, i opened an issue on Github.
Now i have another problem: sometimes i cannot change the resolution in Kodi.
i.e, I change in System/Display the resolution from 1200x800 to 1024x768p
Kodi then changes the resolution and asks if i want to keep it. And there i am stuck. I cannot click No and i cannot click Yes. The mouse is
either stuck or invisible. The only solution to this is a reboot via putty.
Is the Kodi resolution somehow dependend on the HDMI1 or HDMI2 resolution? I made about 15 reboots today. But: sometimes it is possible to change, but so far i couldn't find out why it is sometimes possible, but mostly impossible.
andrum99
Sat May 23, 2020 3:12 pm
@Rascas: I've noticed that your Pi-accelerated build of Kodi for Raspbian has left the Kodi update notification setting on, which means it is coming up tell me there is an update available, but there is no update package available yet. It might be worth disabling this, to stop folk pestering you for an update. It's not a problem for me, I just thought it was worth mentioning as it might make your life a bit easier :)
Rascas
Sat May 23, 2020 3:18 pm
That's an addon that comes preinstalled in Kodi. It only warns you 1 time, when a new version comes out. Since Kodi does not provide pré-compiled bins for the Raspberry, which is what I do, it may take some time for me to build it and to become available. If it bothers you, you can disable that addon which is called "Version check".
andrum99
Sun May 24, 2020 1:58 pm
It doesn't bother me. Like I said, it was just to try and make your life a bit easier. Thanks for the quick reply.
stickman1309
Sun May 31, 2020 6:02 pm
Hey guys,
I am a noob so please bear with me. I have my raspberri pi 2 running the lastest version of rasbian, which is buster. while i try to stay in this with the desktop and launch kodi, i get a black screen with nothing on it thn after couple seconds the desktop reappears with a new crash log. I followed this guide did everything it said and still nothing, running my pi with 320 mb to the gpu and having it overclocked.
Thank you in advance.
Date: Sat 30 May 2020 07:20:09 PM HDT
Kodi Options:
Arch: armv7l
Kernel: Linux 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020
Release: Raspbian GNU/Linux 10 (buster)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/pi/core (2020-05-30 19:20:09.798116646 -0900)
[New LWP 973]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/arm-linux-gnueabihf/kodi/kodi.bin_v8 --lircdev /var/run/lirc/lircd'.
Program terminated with signal SIGILL, Illegal instruction.
#0 0x00873118 in CThread::CThread(char const*) ()
Thread 1 (Thread 0x712cdc60 (LWP 973)):
#1 0x0087aa70 in MEDIA_DETECT::CDetectDVDMedia::CDetectDVDMedia() ()
#2 0x00a0b444 in CApplication::CApplication() ()
#3 0x005a235c in xbmcutil::GlobalsSingleton<CApplication>::getInstance() ()
#4 0x0051a37c in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
############# END STACK TRACE ###############
################# LOG FILE ##################
Logfile not found in the usual place.
Please attach it separately.
Use pastebin.com or similar for forums or IRC.
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
sismeiro
Mon Jun 01, 2020 5:00 pm
Hi All,
I'm in the process of upgrading to Buster my Raspberry Pi 3B used for light desktop tasks and mainly used for Kodi. I'm using a new sdcard and I'm making the changes when I have the time but I'm still using the Stretch Raspbian version for now in the old sdcard.
The RP3B is connected to a 2012 Samsung SmartTV and all is ok when using Stretch, the resolution is 1920x1080@60Hz with Raspian and when I start Kodi the resolution is the same 1920x1080@60Hz.
The problem is when I'm using Buster (fully updated), the Raspbian desktop works with the resolution 1920x1080@60Hz but when I start Kodi it changes to 1920x1080@50Hz. Also when I leave Kodi it stays at 1920x1080@50Hz and the Raspbian desktop is over-scanning.
The Samsung TV has the HDMI port configured as PC as this solved the overscan problem when running at 1920x1080@60Hz either with Stretch or Buster. I tried many configuration combinations and for I had to do the Video Calibration to correctly setup Kodi screen.
Is the fact of the refresh rate change when I start Kodi on Buster desktop expected? Shouldn't the refresh stay at the same rate when using Raspbian desktop? I'm using all software from the Raspbian official sources.
I searched through the net but I didn't found an answer I could relate to my problem. Thank you for any pointer on how to solve this issue.
Regards,
Luis Sismeiro
Rascas
Mon Jun 01, 2020 5:08 pm
Hey guys,
Kodi Options:
Arch: armv7l
[New LWP 973]
Cannot do much with only that. Please post a full debug log: https://kodi.wiki/view/Log_file
brunoj
Sun Jun 07, 2020 11:48 pm
Hi guys,
After 2 years of absolutely flawless functioning, after updating to Kodi 18.6.2, suddenly my Kodi install started behaving weirdly.
After a week of research of every possible aspect of my install, I've noticed that, since 18.6.2, for some reason Kodi ignores the "memorysize" line in my advancedsettings.xml, whilst properly observing the rest.
From the log:
2020-06-08 01:11:34.570 T:1900434352  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <cache>
                                                <buffermode>1</buffermode>
                                                <memorysize>‭47772160‬</memorysize>
                                                <readfactor>5</readfactor>
                                              </cache>
                                            </advancedsettings>
However, also:
2020-06-08 01:22:07.550 T:1900389296  NOTICE: cache.memorysize: 0MB
Changing these values would change Kodi behavior in expected ways, except for the memorysize value, which seems to be ignored in all cases.
Ultimately, I found that the weird behavior of Kodi (intermittent stopping of movies, strange buffering issues) was caused by filecache being used instead of RAM for buffering (memorysize=0, instead of the set amount) and then Kodi /OS running out of disk space as a result.
I have temporarily resolved the problem by cloning my SD card onto a bigger one, and mounting .kodi/userdata/temp to its own, huge partition. While this solution works just fine from a Kodi-behaviour perspective, it can't be a permanent solution due to tear and wear on the card.
Can you please verify is this is a bug, or otherwise suggest what I could do?
Return to “Raspberry Pi OS”
