encryption
Is there a good summary of available options for Raspbian full-disk encryption for the Pi 4's SD card, and for any attached hard drives (e.g. for an NAS server)?
Re: encryption
I think there are two evaluable options; dm-crypt with LUKS, and fscrypt.
For performance reasons, I recommend using Adiantum in both cases:
/etc/fscrypt.conf:
CONFIG_CRYPTO_ADIANTUM=m
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_NHPOLY1305_NEON=m
CONFIG_FS_ENCRYPTION=y
> sudo cryptsetup luksFormat --type=luks2 --sector-size=4096 -c xchacha12,aes-adiantum-plain64 -s 256 -h sha512 --use-urandom /dev/device-or-partition
"source": "custom_passphrase",
"hash_costs": {
"time": "5",
"memory": "131072",
"parallelism": "4"
"compatibility": "",
"options": {
"padding": "32",
"contents": "Adiantum",
"filenames": "Adiantum",
"policy_version": "2"
"use_fs_keyring_for_v1_policies": true
> sudo tune2fs -O encrypt /dev/partition
> sudo fscrypt encrypt /directory/path
Re: encryption
Worth noting that there's no hardware crypto on any Pi SoC, so it'll all be done in software and may have quite a hit on performance. CPU-intensive workloads may be hit hard if anything is doing disc IO at the same time, for example.
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
Re: encryption
The Adiantum performs perfectly well here.
Re: encryption
True but apparently the latest PIOS has this accelerated using NEON, so should be a bit quicker -would be interesting to see results.
Re: encryption
Good news. Any idea which algorithms, and is there any attempt to port that to userland libraries?
It'll still have an impact, of course.
Re: encryption
No idea, Eben mentioned it in the blog post, that's all I know.
Re: encryption
I must've missed that. I'll look.
Ta.
Ta.
