arpi3b
Shutdown/Start and Reset buttons not working (on Devuan)
Sat May 02, 2020 4:51 pm
Hello:
I am attempting to wire shutdown/start and reset buttons using GPIO pin 5 to Ground and a header soldered to the PEN+RUN location on a Raspberry Pi 3B+ like some examples I have seen on the web.
For the Reset button I am using GPIO 14 as Ground as GPIO 6 and GPIO 4 are used to power a small 12v.
(No noise/good airflow, always @35°C with an AT of 26°C.)
But I digress ...
The shutdown/start and Reset buttons are not working.
Fortunately I have not toasted the board and it still works.
Q:
Are these functions exclusively RPi 3B+ hardware related or is the use of Raspbian as the OS needed?
I am running Devuan ascii 2.0.0.
groucho@rpidevuan:~$ uname -a
Linux rpidevuan 4.16.14-v8+ #1 SMP PREEMPT Tue Jun 5 18:50:10 CEST 2018 aarch64 GNU/Linux
groucho@rpidevuan:~$ cat /boot/config.txt
## memory shared with the GPU
gpu_mem=128
## always audio
dtparam=audio=on
## maximum amps on usb ports
max_usb_current=1
## enable hardware-accelerated graphics
dtoverlay=vc4-kms-v3d
## kernel
kernel=kernel8.img
## shutdown button pin 5 and ground
dtoverlay=gpio-shutdown
groucho@rpidevuan:~$ cat /boot/cmdline.txt
dwc_otg.fiq_fix_enable=2 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rootflags=noload net.ifnames=0
Thanks in advance,
A.
scruss
Re: Shutdown/Start and Reset buttons not working
Sat May 02, 2020 5:16 pm
Yep; Devuan's the problem. From Device Tree overlays README:
Info:   Initiates a shutdown when GPIO pin changes. The given GPIO pin
        is configured as an input key that generates KEY_POWER events.
        This event is handled by systemd-logind by initiating a
        shutdown.
You throw out systemd, you throw out the nice things.
Pronouns: he/him
arpi3b
Re: Shutdown/Start and Reset buttons not working (on Devuan)
Sat May 02, 2020 6:18 pm
Hello:
Thanks for the fast reply.
Much obliged.
... Devuan's the problem.
        This event is handled by systemd-logind by initiating a shutdown.
I see.
This with respect to gpio-shutdown functionality.
I'll look at other options I have seen using a python script.
What about RUN and PEN?
I have seen that PEN was (unnamed) Ground up to RPI3 which is why shorting RUN to it made for a soft reset.
How does it work now that the pin is labeled PEN?
I assume that PEN and RUN short to Ground and do something related to power and start/stop/reset?
I have not found official RPi documentation on how to use them.
Indeed ...
Depends on what one considers 'nice'.
Some people like to eat a bowl of fermented durian for breakfast.
In another life I clocked in a few years of, among other IT duties, end-user support for PCs running from W95SE to XP.
Previous experience had been a lot of userland DOS 5.0 to W3.11.
I recall that my worst nightmare was the obscure, undocumented and always morphing MS registry.
systemd reminds me of that, so I'll stay with Devuan. =-)
Thanks in advance,
A.
scruss
Sat May 02, 2020 9:02 pm
Not things you really want to touch. You can use RUN to bring a shutdown Raspberry Pi back to life. Lots of discussion on this board, such as: viewtopic.php?t=207961
These are emergency shutdown/startup points that go directly to the CPU. There's no way an OS can trap them.
Mmm, durian. Lovely stuff. Seriously.
Raspbian's the only OS for the Raspberry Pi with good support. There's not much help for niche OSs. I used to admin SCO systems: I do not miss init one bit.
Pronouns: he/him
arpi3b
Sat May 02, 2020 9:36 pm
Hello:
Awww ... =-)
... use RUN to bring a shutdown Raspberry Pi back to life.
Good use, reset.
Thanks for the link.
See what I meant?
Depends is a really neat word. 8^7
Hopefully that will eventually change.
In the meanwhile ...
Thanks a lot for your input.
Cheers,
A.
