but as i live in Maine, USA, temps have been known to get down to -40*, and colder. will the Rpi still function?
if not, my next thought would be to use an XBEE S1, to bring the Rpi into the house.
Thanks in advance for any help.
~Travis
Keep in mind that the Xbee would have to function down to that temperature also.travisfarmer wrote: ↑Sun Mar 29, 2020 11:06 amok, thank you. i will proceed with the project, and see what happens.
if worst comes to worst, i could try the XBEE option.
~Travis
DougieLawson wrote: ↑Sun Mar 29, 2020 10:57 amI think someone has had an original RPi1B down to temps lower than -40°F (which is, curiously, -40°C).
Unless things are different in Australia to the rest of the world, it isn't.
In the test at Cern, the Pi failed around -100'C. They *wanted* to see if it would run at -200'C (basically, liquid Nitorgen temperature). However, the capacitors on the board went so far out of spec at -100'C that the Pi quit working at that point.Imperf3kt wrote: ↑Sun Mar 29, 2020 8:32 pmDougieLawson wrote: ↑Sun Mar 29, 2020 10:57 amI think someone has had an original RPi1B down to temps lower than -40°F (which is, curiously, -40°C).Unless things are different 15,000km away, -40°F is 4.4^°C in Australia.
I recall slmebody using a Pi in Antarctica just fine. Also there was some project at CERN where the Pi was used in up to -200°C environments.
The specs for the Pi say the LAN chip is only rated for 0°C to 70°C, but the rest of the Pi is rated for - 40°C to 80°C
ok, thank you. i may still heat the Rpi enclosure, just to maintain reliability, in case i get a super cold spell. in the least, it won't cost me anything extra to use the battery heater mat, or i can even buy an extra. i don't think they cost a huge amount, on eBay (used). the Rpi needs an enclosure anyway, so i may as well insulate it.W. H. Heydt wrote: ↑Sun Mar 29, 2020 9:43 pmFor the OP...doubt you're going to have a thermal problem with the Pi. You'll be out of spec, so not relying on a given board until you've tested it would be a really good idea. If you can position the Pi so it's on the house-facing side of the generator, it'll probably be a bit warmer than on the other side due to IR leakage from your house.
Just a thought - if you put the Pi in a really well-insulated enclosure, it should stay considerably warmer than ambient as a result of its own heat dissipation. You might have to open the enclosure during the summer, though.travisfarmer wrote: ↑Sun Mar 29, 2020 9:57 pmok, thank you. i may still heat the Rpi enclosure, just to maintain reliability, in case i get a super cold spell. in the least, it won't cost me anything extra to use the battery heater mat, or i can even buy an extra. i don't think they cost a huge amount, on eBay (used). the Rpi needs an enclosure anyway, so i may as well insulate it.W. H. Heydt wrote: ↑Sun Mar 29, 2020 9:43 pmFor the OP...doubt you're going to have a thermal problem with the Pi. You'll be out of spec, so not relying on a given board until you've tested it would be a really good idea. If you can position the Pi so it's on the house-facing side of the generator, it'll probably be a bit warmer than on the other side due to IR leakage from your house.
currently i am waiting for an adapter plug to arrive so i can interface with the generator controller. well, that and propane for the generator...
~Travis
Hmm, i do tend to overthink my projects quite often...lpsw wrote: I live in central Maine and have had 6 Pis deployed outside 365 (sometimes 366) days a year, for approx 3 winter seasons. All but one are Pi0Ws, in small Styrofoam boxes with a rectangular hole cut in the bottom, covered by a screen to keep out little heat seeking critters. The other Pi is a 4B4G that is on my deck, not as exposed to the elements as the Pi0s. They all connect to an outdoor long range WiFi access point. None have had any issues whatsoever in the winter. No 3B+ but I would expect a 3B+ to be OK.
You must live in the County? -40F country for sure . I'm from up there. Love it.
let me know how it works out. i get deer feeding in my yard from time to time. a Pi game camera would be neat, if my WiFi reaches that far, that is. ( i can check with my tablet)lpsw wrote: This summer I'm planning to install a solar powered Pi as a game camera at my camp in Eustis. Next winter should be interesting.
Love it there too.
