tried to debug using gdb and I get the following messages:
gdb ./linphonec
run --verbose
(gdb) run -C
Starting program: /home/pi/linphone-desktop/OUTPUT/no-ui/bin/linphonec -C
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0x70c7d320 (LWP 1683)]
[New Thread 0x602ff320 (LWP 1684)]
[New Thread 0x602ff320 (LWP 1685)]
[Thread 0x602ff320 (LWP 1684) exited]
[Thread 0x602ff320 (LWP 1685) exited]
[New Thread 0x602ff320 (LWP 1686)]
linphonec> 2019-03-01 16:44:53:344 belle-sip-error-stream connect failed Network is unreachable
2019-03-01 16:44:53:344 belle-sip-error-Cannot connect to [TLS://sip.linphone.org:5223]
linphonec>
linphonec> call myusername
Establishing call id to sip:myusername@sip.linphone.org, assigned id 1
[New Thread 0x6407b320 (LWP 1688)]
[New Thread 0x6387a320 (LWP 1689)]
linphonec> Call 1 to sip:myusername@sip.linphone.org in progress.
[New Thread 0x62cff320 (LWP 1690)]
[New Thread 0x624fe320 (LWP 1691)]
Call 1 to sip:myusername@sip.linphone.org ringing.
Thread 1 "linphonec" received signal SIGSEGV, Segmentation fault.
__GI_strcmp (p1=<optimized out>, p2=<optimized out>) at strcmp.c:39
39 strcmp.c: No such file or directory.
(gdb) bt
#0 __GI_strcmp (p1=<optimized out>, p2=<optimized out>) at strcmp.c:39
#1 0x7661c3d4 in _belle_sip_dialog_match () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#2 0x7663eb50 in belle_sip_client_transaction_notify_response () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#3 0x76638b90 in belle_sip_provider_dispatch_message () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#4 0x76617114 in belle_sip_channel_process_stream () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#5 0x76619000 in belle_sip_channel_process_data () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#6 0x76641570 in tls_process_data () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#7 0x7660b33c in belle_sip_main_loop_run () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#8 0x7660b834 in belle_sip_main_loop_sleep () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/libbellesip.so.0
#9 0x76f1ea88 in linphone_core_iterate () from /home/pi/linphone-desktop/OUTPUT/no-ui/lib/liblinphone.so.9
#10 0x00015fb4 in linphonec_idle_call ()
#11 0x00016148 in linphonec_readline ()
#12 0x00014d88 in main ()
