Mon Dec 12, 2011 10:28 pm
I'm sorry if I didn't explain myself clearly in my previous post.
As a rule of thumb, then VHF and UHF receivers are designed with different priorities, compared to those for shortwave. Price point has little to do with it. At VHF and higher you generally want wide tuning range, high sensitivity and low receiver amplifier noise (as that is likely to be the dominant factor for weak signal reception). Additionally, as a consequence of the laws of nature, an oscillator running at a higher frequency will have higher phase noise compared to a low frequency counterpart. This problem is compounded by requirements of small physical size and low power consumption. Higher phase noise in an oscillator ruins a receiver's ability to separate closely spaced transmitters.
All of this is because signals tend to be both weak and well spaced out at VHF and up. The antennas themselves are frequently very directional, in addition to being frequency selective, acting as front-end filters for the receiver. So a wide-band front-end is rarely a problem. An omni-directional wide-band antenna, like a discone, would not give very strong signals, so that isn't much of an issue either.
Conversely, for shortwave below 30 MHz, your receiver oscillator(s) are inherently less noisy, cheap or otherwise, simply because they run at a lower frequency and through the use of physically larger components (high Q). Even beginner receivers tend to have a 'strong' (or at least stronger) front end through the omission of super sensitive pre-amps (one of the rare cases of having your cake and eating it too - no preamp being better than having one), compared to an average VHF receiver. Narrow bandpass filters in the front-end are also very common, like the manually tuned, high-Q preselector on receivers of yesteryear. You often also see fixed tuned bandpass filters switched in at need in general coverage receivers.
This is because of the wall-to-wall signals you will find on shortwave, especially below 12-14MHz on the broadcast bands. Noise (figure) in amplifiers is not the limiting factor, oscillator noise and dynamic range is, as the atrocious signal levels will crush many a receiver not prepared for the onslaught. Here in Europe you can actually rectify the antenna signal from a reasonably sized wire antenna, and having it move a needle on a moving coil meter.
Yet for at least 25 years, ever since wideband synthesized VHF rigs became commonplace, people have been trying to add an up-converter to their VHF receiver, generally giving a very poor result for the reasons just outlined. They wish to gain an general coverage receiver, and that they get: They can receive all of shortwave, at once. Simultaneously.
If you want a simple SDR receiver for shortwave, then I'd suggest you go look for one designed for the job, cheap or otherwise. If you insist on using the FunCube plus an up-converter, then do at least consider giving it a sharply tuning, high Q preselector instead of a low-pass filter in the front-end. Otherwise the pre-amp is very likely to be crushed, causing spurious mixer products all over the place.
