$ dtc -@ -I dts -O dtb -o sdio-overlay-final.dtbo sdio-overlay-final.dts
Ok thank you.PhilE wrote: ↑Fri May 17, 2019 7:38 amYou can compile with:However, I would make the name something more meaningful like wilc_sdio.dtbo. Whatever name you choose, copy the .dtbo to /boot/overlays and add "dtoverlay=your_name.dtbo" to config.txt.Code: Select all
Can wilc-sdio.ko be anywhere or does it have to be in /lib/modules/<kernel_version>/kernel/drivers/staging/ ?# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
wilc-sdio
dtoverlay=sdio,poll_once=off,bus_width=4
pi@raspberrypi:~$ sudo cat /sys/kernel/debug/mmc1/ios
clock: 0Hz
vdd: 0 (invalid)
bus mode: 2 (push-pull)
chip select: 0 (don't care)
power mode: 0 (off)
bus width: 0 (1 bits)
timing spec: 0 (legacy)
signal voltage: 0 (3.30 V)
driver type: 0 (driver type B)
I have followed this tutorial : https://www.raspberrypi.org/documentati ... s-point.mdkaushalyas wrote: ↑Tue May 21, 2019 2:45 amHey Antoine,
Thats good news. Congrats.
I think the wiring is a big contributor to the oops, but also I think there is a bug in the driver that does not gracefully handle a CMD52 read operation failure. I will try to contact the maintainers to get it sorted.
I am trying to get the SoftAP working. I am refering to "http://ww1.microchip.com/downloads/en/D ... rGuide.pdf" but not clear about S80dhcp-server stuff. Could you please shed some light?
Cheers,
kaushalyas
Does the cmd52 & cmd53 prevent you from running the module? I often have the "Failed cmd53, read reg.." error that prevent me to set up the wlan..kaushalyas wrote: ↑Tue May 21, 2019 2:45 amHey Antoine,
Cheers,
kaushalyas
mon.wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
unspec 00-00-00-00-00-00-30-30-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
inet 10.110.11.5 netmask 255.255.0.0 broadcast 10.110.255.255
inet6 fe80::faf0:5ff:fee5:46c5 prefixlen 64 scopeid 0x20<link>
ether f8:f0:05:e5:46:c5 txqueuelen 1000 (Ethernet)
RX packets 48172 bytes 4760911 (4.5 MiB)
TX packets 47552 bytes 4689913 (4.4 MiB)
[ 602.086826] wilc_sdio mmc1:0001:1 wlan0: INFO [debug_thread]*** Debug Thread Running ***
[ 608.486877] wilc_sdio mmc1:0001:1 wlan0: INFO [debug_thread]*** Debug Thread Running ***
[ 613.457670] wilc_sdio mmc1:0001:1 wlan0: INFO [add_key]Adding key with cipher suite = fac04
[ 613.457685] wilc_sdio mmc1:0001:1 wlan0: INFO [add_key]b80881a0 b9cc0000 2
[ 613.457697] wilc_sdio mmc1:0001:1 wlan0: INFO [add_key]key d3 28 61
[ 613.457765] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 613.470506] pgd = 2857ec76
[ 613.475466] [00000000] *pgd=00000000
[ 613.481269] Internal error: Oops: 17 [#1] SMP ARM
Message from syslogd@raspberrypi at May 22 06:03:05 ...
kernel:[ 613.481269] Internal error: Oops: 17 [#1] SMP ARM
[ 613.488773] Modules linked in: ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 snd_bcm2835(C) bcm2835_codec(C) v4l2_mem2mem bcm2835_v4l2(C) v4l2_common bcm2835_mmal_vchiq(C) raspberrypi_hwmon snd_pcm videobuf2_vmalloc videobuf2_dma_contig hwmon snd_timer videobuf2_memops snd videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) fixed uio_pdrv_genirq uio wilc_sdio sha256_generic cfg80211 rfkill ip_tables x_tables ipv6
[ 613.544732] CPU: 0 PID: 45 Comm: kworker/u8:1 Tainted: G C 4.19.42-v7+ #2
[ 613.557975] Hardware name: BCM2835
[ 613.564032] Workqueue: WILC_wq handle_key [wilc_sdio]
[ 613.571748] PC is at handle_key+0x218/0x80c [wilc_sdio]
[ 613.578311] LR is at (null)
[ 613.582582] pc : [<7f18feec>] lr : [<00000000>] psr: 60000013
[ 613.590205] sp : b9f71e70 ip : b657f680 fp : b9f71f0c
[ 613.596790] r10: 00000000 r9 : 00000000 r8 : b657f640
[ 613.603377] r7 : b5848b20 r6 : 00000001 r5 : b9cc0500 r4 : b96bfb70
[ 613.611241] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : b657f650
[ 613.619060] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 613.627534] Control: 10c5383d Table: 358f806a DAC: 00000055
[ 613.634646] Process kworker/u8:1 (pid: 45, stack limit = 0xf14412c0)
[ 613.642389] Stack: (0xb9f71e70 to 0xb9f72000)
What do you mean ? Did you add this in /etc/dhcpcd.conf ?kaushalyas wrote: ↑Wed May 22, 2019 4:59 amHi,
I dont see any failure of CMD52/53 no in my case. I am not 100% sure what causes the CMD52/53 failure.
Also I cant get the AP mode running after following the raspberry Pi document.
I can see following network interfaces.The IP for the wlan0 is from dhcpcd. Should I disable dhcp on wlan0 and assign a static IP?Code: Select all
mon.wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 unspec 00-00-00-00-00-00-30-30-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.110.11.5 netmask 255.255.0.0 broadcast 10.110.255.255 inet6 fe80::faf0:5ff:fee5:46c5 prefixlen 64 scopeid 0x20<link> ether f8:f0:05:e5:46:c5 txqueuelen 1000 (Ethernet) RX packets 48172 bytes 4760911 (4.5 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 47552 bytes 4689913 (4.4 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
interface wlan0
static ip_address=192.168.4.1/24
nohook wpa_supplicant
source-directory /etc/network/interfaces.d
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
[FAILED] Failed to start Advanced IEEE 802.11… 802.1X/WPA/WPA2/EAP Authenticator.
sudo rpi-update
sudo reboot
sudo apt-get install git bc bison flex libssl-dev libncurses5-dev -y
git clone --depth=1 https://github.com/linux4wilc/driver
git clone --depth=1 https://github.com/linux4wilc/firmware
git clone --depth=1 https://github.com/raspberrypi/linux
rm linux/drivers/staging/wilc1000/*
cp driver/wilc/* linux/drivers/staging/wilc1000/
cd linux
KERNEL=kernel7
make bcm2709_defconfig
make menuconfig
>>add device drivers -> staging drivers -> wilc sdio module
make prepare
make modules_prepare
make modules SUBDIRS=drivers/staging/wilc1000/
sudo cp drivers/staging/wilc1000/wilc-sdio.ko /lib/modules/<kernel_version>/kernel/drivers/staging/
sudo nano /boot/config.txt
>>add this line at the end : dtoverlay=sdio,poll_once=off
sudo reboot
sudo mkdir /lib/firmware/mchp
sudo cp firmware/wilc1000_wifi_firmware.bin /lib/firmware/mchp/
sudo apt-get -y install hostapd
sudo insmod /lib/modules/<kernel_version>/kernel/drivers/staging/wilc/wilc-sdio.ko
Linux raspberrypi 4.19.97-v7+ #1293 SMP Wed Jan 22 17:10:55 GMT 2020 armv7l GNU/Linux
[ 0.829411] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.832343] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.383855] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.392169] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 2.471285] mmc1: new high speed SDIO card at address 0001
[ 2.479388] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.623220] mmc0: new high speed MMC card at address 0001
[ 2.632043] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB
[ 2.639584] mmcblk0boot0: mmc0:0001 BJTD4R partition 1 4.00 MiB
[ 2.648734] mmcblk0boot1: mmc0:0001 BJTD4R partition 2 4.00 MiB
[ 2.657223] mmcblk0rpmb: mmc0:0001 BJTD4R partition 3 4.00 MiB, chardev (246:0)
[ 2.668643] mmcblk0: p1 p2
clock: 25000000 Hz
actual clock: 25000000 Hz
vdd: 21 (3.3 ~ 3.4 V)
power mode: 2 (on)
bus width: 2 (4 bits)
timing spec: 2 (sd high-speed)
[ 142.017127] wilc_sdio: no symbol version for module_layout
[ 142.017149] wilc_sdio: loading out-of-tree module taints kernel.
[ 142.017164] wilc_sdio: module is from the staging directory, the quality is unknown, you have been warned.
[ 142.027248] Registering wifi device
[ 142.027265] Max scan ids= 10,Max scan IE len= 1000,Signal Type= 1,Interface Modes= 844
[ 142.027736] Initializing Locks ...
[ 142.042027] wifi_pm : 0
[ 142.042118] wilc_sdio mmc1:0001:1: succesfully got gpio_reset
[ 142.042160] wilc_sdio mmc1:0001:1: succesfully got gpio_chip_en
[ 142.042186] wifi_pm : 1
[ 142.042226] wilc_sdio mmc1:0001:1: succesfully got gpio_reset
[ 142.042266] wilc_sdio mmc1:0001:1: succesfully got gpio_chip_en
[ 142.049829] wilc_sdio mmc1:0001:1: Driver Initializing success
[ 142.185807] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.185855] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.185891] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.185926] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.185960] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.185994] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186029] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186064] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186098] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186135] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186172] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186209] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186244] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186277] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186311] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186346] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186380] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186415] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186449] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186484] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186519] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.186553] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed
[ 142.187109] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]MAC OPEN[d2ad150e] wlan0
[ 142.187113] WILC POWER UP
[ 142.187121] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_init_host_int]Host[d2ad150e][c2d6543d]
[ 142.187130] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]*** re-init ***
[ 142.187136] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_wlan_init]Initializing WILC_Wlan
[ 142.187143] wilc_sdio mmc1:0001:1: SDIO speed: 25000000
[ 147.556378] wilc_sdio mmc1:0001:1: wilc_sdio_cmd53..failed, err(-110)
[ 147.556391] wilc_sdio mmc1:0001:1: Failed cmd53, read reg (003b0000)...
[ 147.556398] [wilc start]: fail read reg 0x3b0000
[ 152.925325] wilc_sdio mmc1:0001:1: wilc_sdio_cmd53..failed, err(-110)
[ 152.925339] wilc_sdio mmc1:0001:1: Failed cmd53, read reg (00001000)...
[ 152.925349] wilc_sdio mmc1:0001:1: Unsupported chipid: 0
[ 152.925366] wilc_sdio mmc1:0001:1 wlan0: ERR [wilc_wlan_initialize:905] Initializing WILC_Wlan FAILED
[ 152.925377] wilc_sdio mmc1:0001:1 wlan0: ERR [wilc_mac_open:1029] Failed to initialize wilc
[ 152.927221] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]MAC OPEN[d2ad150e] wlan0
[ 152.927234] power up request for already powered up source Wifi
[ 152.927240] Device already up. request source is Wifi
[ 152.927255] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_init_host_int]Host[d2ad150e][c2d6543d]
[ 152.927271] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]*** re-init ***
[ 152.927283] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_wlan_init]Initializing WILC_Wlan
[ 152.927295] wilc_sdio mmc1:0001:1: SDIO speed: 25000000
[ 158.296843] wilc_sdio mmc1:0001:1: wilc_sdio_cmd53..failed, err(-110)
[ 158.296910] wilc_sdio mmc1:0001:1: Failed cmd53, read reg (003b0000)...
[ 158.296917] [wilc start]: fail read reg 0x3b0000
Scprt wrote: ↑Thu Jan 30, 2020 11:07 amHi ,
Sorry for bumping this topic but i am trying to work with atwilc1000. i read this topic and i did everything that was spoken.
I have CM3+ and RPi3b+ ,This is my results for mmc;Code: Select all
[ 0.829411] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe [ 0.832343] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe [ 2.383855] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0 [ 2.392169] mmc-bcm2835 3f300000.mmc: DMA channel allocated [ 2.471285] mmc1: new high speed SDIO card at address 0001 [ 2.479388] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1) [ 2.623220] mmc0: new high speed MMC card at address 0001 [ 2.632043] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB [ 2.639584] mmcblk0boot0: mmc0:0001 BJTD4R partition 1 4.00 MiB [ 2.648734] mmcblk0boot1: mmc0:0001 BJTD4R partition 2 4.00 MiB [ 2.657223] mmcblk0rpmb: mmc0:0001 BJTD4R partition 3 4.00 MiB, chardev (246:0) [ 2.668643] mmcblk0: p1 p2
and cat ;
and it's my errors ;Code: Select all
clock: 25000000 Hz actual clock: 25000000 Hz vdd: 21 (3.3 ~ 3.4 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 2 (4 bits) timing spec: 2 (sd high-speed) signal voltage: 0 (3.30 V) driver type: 0 (driver type B)
I have printed pcb , and module alone and both have same err.Code: Select all
[ 142.017127] wilc_sdio: no symbol version for module_layout [ 142.017149] wilc_sdio: loading out-of-tree module taints kernel. [ 142.017164] wilc_sdio: module is from the staging directory, the quality is unknown, you have been warned. [ 142.027248] Registering wifi device [ 142.027265] Max scan ids= 10,Max scan IE len= 1000,Signal Type= 1,Interface Modes= 844 [ 142.027736] Initializing Locks ... [ 142.042027] wifi_pm : 0 [ 142.042118] wilc_sdio mmc1:0001:1: succesfully got gpio_reset [ 142.042160] wilc_sdio mmc1:0001:1: succesfully got gpio_chip_en [ 142.042186] wifi_pm : 1 [ 142.042226] wilc_sdio mmc1:0001:1: succesfully got gpio_reset [ 142.042266] wilc_sdio mmc1:0001:1: succesfully got gpio_chip_en [ 142.049829] wilc_sdio mmc1:0001:1: Driver Initializing success [ 142.185807] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.185855] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.185891] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.185926] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.185960] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.185994] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186029] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186064] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186098] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186135] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186172] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186209] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186244] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186277] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186311] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186346] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186380] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186415] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186449] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186484] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186519] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.186553] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mgmt_frame_register]Return since mac is closed [ 142.187109] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]MAC OPEN[d2ad150e] wlan0 [ 142.187113] WILC POWER UP [ 142.187121] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_init_host_int]Host[d2ad150e][c2d6543d] [ 142.187130] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]*** re-init *** [ 142.187136] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_wlan_init]Initializing WILC_Wlan [ 142.187143] wilc_sdio mmc1:0001:1: SDIO speed: 25000000 [ 147.556378] wilc_sdio mmc1:0001:1: wilc_sdio_cmd53..failed, err(-110) [ 147.556391] wilc_sdio mmc1:0001:1: Failed cmd53, read reg (003b0000)... [ 147.556398] [wilc start]: fail read reg 0x3b0000 [ 152.925325] wilc_sdio mmc1:0001:1: wilc_sdio_cmd53..failed, err(-110) [ 152.925339] wilc_sdio mmc1:0001:1: Failed cmd53, read reg (00001000)... [ 152.925349] wilc_sdio mmc1:0001:1: Unsupported chipid: 0 [ 152.925366] wilc_sdio mmc1:0001:1 wlan0: ERR [wilc_wlan_initialize:905] Initializing WILC_Wlan FAILED [ 152.925377] wilc_sdio mmc1:0001:1 wlan0: ERR [wilc_mac_open:1029] Failed to initialize wilc [ 152.927221] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]MAC OPEN[d2ad150e] wlan0 [ 152.927234] power up request for already powered up source Wifi [ 152.927240] Device already up. request source is Wifi [ 152.927255] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_init_host_int]Host[d2ad150e][c2d6543d] [ 152.927271] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_mac_open]*** re-init *** [ 152.927283] wilc_sdio mmc1:0001:1 wlan0: INFO [wilc_wlan_init]Initializing WILC_Wlan [ 152.927295] wilc_sdio mmc1:0001:1: SDIO speed: 25000000 [ 158.296843] wilc_sdio mmc1:0001:1: wilc_sdio_cmd53..failed, err(-110) [ 158.296910] wilc_sdio mmc1:0001:1: Failed cmd53, read reg (003b0000)... [ 158.296917] [wilc start]: fail read reg 0x3b0000
What am I doing wrong? , thanks for your help in advance.
pkar wrote: ↑Wed Feb 19, 2020 9:34 am
Hi Scprt,
I'm getting the same output as you, were you able to figure out what was going wrong?
I am use the WILC100-SD board. I have shortened the wires as much as a I can and have even tried to reduce the clock below 5MHz, but nothing seems to help.
I tried the driver direct from Atmel as well as the one in the RPi repo (not sure what the difference or even if there is one), but they both produce the same result.
I'm going to see if I can get a scope on the signals see if there is something to learn there.
