Pjhants
Re: STICKY: HOWTO: Create Custom HDMI modes
Fri Jan 25, 2019 7:51 am
I am helping a friend interface an HDMI LCD display to a Pi. The display is borderless and a specific size to replicate a flight simulator instrument panel. I have tried creating a custom resolution but without success. I can't get a stable display at all. I get a flashing backlight or if anything is displayed it is intermittent and repeated across the panel.
The display will work on a PC graphics card (GTX1080Ti) with the following settings:
- 720 x 1280.
- 60Hz.
- 8 bit.
- Colour Format RGB
- Colour spacing SDR.
The display itself is a: Sharp LS060R1SX01.
The driver chip is Toshiba 358870XBG.
So far we have failed to find any detailed data sheets for the Sharp display.
I think it's default resolution is 1440 X 2560 which is probably too much for the Pi but I can't even get a custom setting to run:
Amongst other settings suggested on this thread I have tried even standard 16x9 resolutions. I also tried:
hmdi_cvt 1440 720 60
hdmi_group=2
hdmi_mode=87
I can't find any timings info for the display Does anyone have any ideas or suggestions?
dom
Tue Jan 29, 2019 12:23 pm
hdmi_group=2
hdmi_mode=87
Unless the data sheet says it supports [email protected] then this is very unlikely to work.
The actual resolution 1440x2560x60 requires a pixel clock of 221MHz (actually more due to blanking),
so that won't work without overclock settings.
May be some info here: https://www.raspberrypi.org/forums/view ... 3#p1348063
chrhartz
Tue Feb 26, 2019 11:41 pm
Hi all,
I made a pcb with the CM3L compute module and TFP401A HDMI to ttl decoder. I am using the DS90C385A
ttl to LVDS driver from TI to drive a 10.1" 1280x800 IPS display from Duobond displays.
It works generally. I am getting a stable picture with expected size, no flickering and colors are displayed normally.
So it seems the h- and v-sync is working and the color channels are connected the right way.
But the display is almost unreadable. It seems that there is still a problem with the pixel clock or something else.
I have tried different hdmi_timings without success. Also different cvt modes, driver settings and so on with no luck.
I made the pcb very carefully with impedance control, 4 layers, length matching and differential pair length matching better
than 0.2 mm. So I am hoping the pcb is not forcing the problem. :?
In fact this is my first HDMI and LVDS design and I have no experience so far. I grabbed all informations about it from
the datasheets, Adafruit designs, reference design from TI and other resources.
It would be very helpful if someone can give me a hint for the correct display timing. There are a lot of parameters that
can be changed and I don´t know where to start. :(
I bought a RTD2660 driver board together with the lcd. Unfortunally the RPi is not able to readout the EEDID EEPROM.
I was hoping the chinese guys programmed the EEDID correctly so I can fetch the correct timing values but no hope
from this side. The RTD2660 is displaying the picture perfectly... Should I switch to this chip? :roll:
Chris
mosoto
Tue Mar 12, 2019 12:53 am
I have a Samsung Ultra Widescreen Monitor s34e790c (3440 x 1440 resolution) and I was recently struggling to get it to work with my raspberry pi 3b+ at that resolution. I finally got it to work so I figured I'd share my findings here in case it helps anyone else.
Ultimately, what helped me the most was running:
/opt/vc/bin/tvservice -d edid.dat; /opt/vc/bin/edidparser edid.dat
This dumped the various modes for the monitor including a 50hz 3440x1440 and a 30hz 3440x1440 which were unrecognized. Running at 30hz worked right off the bat with a custom hdmi timing.
hdmi_drive=2
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=87
hdmi_timings=3440 0 48 32 80 1440 1 3 10 8 0 0 0 30 0 157788000 7
max_framebuffer_width=3440
max_framebuffer_height=1440
Trying to run it at 50hz, however, was another matter. The edidparser dump showed that this should be the timings:
hdmi_timings=3440 1 48 32 80 1440 0 3 10 21 0 0 0 50 0 265320000 7
hdmi_pixel_freq_limit=265320000
I adjusted the hdmi pixel freq limit since I read in one of these pages that the limit is somewhere around 160mhz. Unfortunately, did this not work. The monitor would continously fail.
Ultimately, I found that I needed to overclock the raspberry pi to get it to work. I suppose this is too high a resolution for the standard raspberry pi settings. This is what I ended up using for the overclocking. I can't claim to understand all of it and I wouldn't recommend doing this but I'll paste them in case anyone wants to play around with it.
gpu_mem=256
force_turbo=1
hdmi_ignore_cec_init=1
arm_freq=1050
core_freq=500
sdram_freq=600
over_voltage=6
gpu_freq=500
This page was useful in understanding some of this:
https://elinux.org/RPiconfig
With the overclock and I did get the monitor to work at 50hz though ultimately I reverted to 30hz as I'm not sure what the overclocking will do to the longevity of my pi.
Anyway, hope that is useful.
aBUGSworstnightmare
Tue Mar 19, 2019 11:47 am
Hi all,
Chris
Your timing is incorrect! post your config.txt settings. Is your TFP401A configured/wired correctly?
antiriad
Contact: Twitter
Sat Mar 23, 2019 1:54 pm
it is technically possible to set a custom video resolution of 320x200 with a VGA666?
Thank you!
gigawat
Wed Jun 19, 2019 9:44 pm
Hello All,
I am new to the PI.
I have designed my own compute module carrier board with a TI SN75LVDS83ADGGR for LVDS. It works very well with my 10.1" 1280x800 LVDS display.
My config.txt is as follows:
dtparam=audio=on
dtoverlay=dpi18-666-cff
framebuffer_width=1280
framebuffer_height=800
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x6f217
hdmi_timings=1280 0 40 48 88 800 0 13 3 32 0 0 0 60 0 71000000 5
gpu_mem=256
dtoverlay=i2c-gpio,i2c_gpio_sda=28,i2c_gpio_scl=29,i2c_gpio_delay_us=2
enable_uart=1
I have even used the following and it works perfectly:
dtparam=audio=on
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
gpu_mem=256
hdmi_cvt=1280 800 60 5 0 0 1
enable_uart=1
My problem is when I switch to a 7" 1280x800 LVDS display. I get a black screen. No matter what I change, I get a black screen.
I have checked my hardware by doing the following:
I have a 10.1" HDMI to LVDS driver board that came with my 10.1" screen. It works great with the 10.1" screen. I am able to connect this same driver board with no changes to my 7" screen, with the same cable, and it works perfectly. I have confirmed the 7" screen is getting all of the various voltages it requires. Again, the same LVDS cable from my 10.1" HDMI to LVDS driver board works perfectly. So in my mind, disconnecting my LVDS cable going to my 10.1" display from my compute module carrier board and connecting it to my 7" display should work. I can tell the back light comes on, but there is just a black image. No raspberry pie symbols during the boot sequence. Nothing...
I have tried using the following:
hdmi_timings=1280 0 64 1 5 800 0 40 1 2 0 0 0 60 0 68200000 5
Which is based on the timings found in the 7" display data sheet, which I have attached here.
Would somebody please check and see that my hdmi_timings= parameters are matching what the data sheet is saying? Maybe that is my problem.
I don't know what else to check or try. Any ideas? This would be greatly appreciated. Thank you so much!
merefield
Re: Custom HDMI modes
Mon Jul 01, 2019 5:02 pm
mrillinthebrain wrote:
Mon Aug 17, 2015 10:54 pm
i will never know why but max_framebuffer_height was the problem.
i have now 2560x1080 60hz 21x9 on my LG 29UM65 on raspbian(!)
here is my confix.txt
hdmi_drive=2
disable_overscan=1
hdmi_group=2
hdmi_mode=87
hdmi_timings=2560 1 64 64 96 1080 1 3 10 31 0 0 1 60 0 185580000 8
config_hdmi_boost=4
max_framebuffer_width=2560
max_framebuffer_height=1280
framebuffer_height=1080
gpu_mem=128
arm_freq=900
gpu_freq=275
sdram_freq=500
hdmi_pixel_freq_limit=400000000
avoid_pwm_pll=1
This works on the Raspberry Pi 4B :geek: with my 21:9 29" Asus monitor :cool:
Totally awesome! So nice to use the full width with a Pi!
Really appreciate you posting, thank you!!
If i'm really picky it's a bit 'teary' but that's probably an issue with Pi not keeping up with the 59Hz monitor refresh rate?
aBUGSworstnightmare
Mon Jul 01, 2019 6:59 pm
I'm surprised to see your posting and your hdmi_timings processed correctly. Here https://www.raspberrypi.org/forums/view ... 0#p1486790 I was told that hdmi_timings is an issue with FKMS and the recommendation is to provide the EDID dato to the firmware via edid.dat in boot directory.
Have you tested with that option as well by chance?
And. what is the effect of 'avoid_pwm_pll'?
6by9
Mon Jul 01, 2019 7:29 pm
I'd expect the monitor to report the correct details in the edid, and fkms will then make the appropriate mode available.
The firmware will always switch back to one of the standard resolutions unless it is given explicit timings.
heymac
Fri Aug 30, 2019 11:12 am
Where does the value for hdmi_pixel_freq_limit come from ?
antiriad
Contact: Twitter
Sat Oct 12, 2019 6:07 am
it is true that custom video modes (hdmi_mode 87) are not supported on RPI4?
Thank you
aBUGSworstnightmare
Sat Oct 12, 2019 6:33 am
Thank you
seems to work for some folks.
But you might be better off with putting them into an EDID.dat file - under detailed timings section.
But this is work in progress as it requires new firmware (which is still beta at the time of writing rhis post)
6by9
Sat Oct 12, 2019 8:26 am
Thank you
I believe the latest apt kernel does bump up to 4.19.75, in which case it does support mode 87, and will pass kms that single mode and bypass edid parsing entirely. Certainly the rpi-update firmware supports it.
antiriad
Contact: Twitter
Sat Oct 12, 2019 8:31 am
I did rpi-update a week ago, and I can't get dpi_mode=87 working (I'm using a VGA666). I'll check again.
May I ask which command related to KMS driver should be present in config.txt? (kms, fkms...)
stt
Sat Dec 07, 2019 4:03 pm
Recently I bought a 14.9" 1280x390 LTA149B780F LCD panel for a project, it comes with a controller board that by default shows a picture at 1280x768 but of course it's quite squashed. This happens with Raspbian and Windows and is likely explained by the generic controller board only returning standard 4:3, 16:9 resolutions as tested with tvservice/edidparser.
Got the display working well enough but wanted to write down some notes about it in case it helps anyone.
Here's the specsheet for the panel https://www.beyondinfinite.com/lcd/Libr ... 9B780F.pdf
Using the timings listed I couldn't get a picture it only displayed "Out of range". Plugging display via HDMI into Win10 with an NVidia card and testing custom resolutions this one gave a good picture:
Specsheet says the native refresh rate is 60Hz but ~67Hz is what worked, similarly it lists pixel clock range of 31-37MHz but what works is 42MHz, I'm not sure if this is due to the controller board or what, please comment with any ideas.
Using this information here's my Raspbian configs:
/boot/config.txt:
hdmi_group=2
hdmi_mode=87
hdmi_timings=1280 0 8 128 64 390 0 1 3 24 0 0 0 67 0 42009500 8
And plugging those into Tomi's calculator http://www.epanorama.net/faq/vga2rgb/calc.html it gave working xorg.conf:
    HorizSync      26 - 29
    VertRefresh    66 - 68
    Modeline "1280x390"   42.0095   1280 1288 1416 1480   390 391 394 418  -hsync
dimster
Fri Jan 10, 2020 12:38 pm
I own a Rpi4 4Gb but the image goes blank when Raspbian Buster tries to load the desktop environment. I tried also Lakka, custom Retropie, Kubuntu, ... None of them work.
You see the 4 raspberry's on the screen, but after a few moments, the screen goes blank.
When using Raspbian Buster LITE (without the desktop environment), everything boots up fine.
Binary EDID file in attach. (It looks like tvservice shows me the correct modes and selects it -> 1080p60)
The config.txt is default. (vc4-fkms-v3d)
How it's connected:
rpi4 (micro hdmi to regular hdmi adapter + cable) -> hdmi splitter (not switch!) -> Yamaha AVR RX-V667 -> Sony 46HX800 HDTV.
It's connected using the HDMI 0 port next to the USB-C port.
What I tried:
Used a micro hdmi to regular hdmi cable instead of the adapter + cable -> NOT OK!
Connected the rpi4 directly to the AVR with the same adapter + cable -> NOT OK!
Connected the rpi4 directly to the AVR with a micro hdmi to regular hdmi cable -> NOT OK!
It ONLY works when I connect the rpi4 directly to the TV with the same adapter + cable or with the micro hdmi to regular hdmi cable. Safe mode works too.
So I don't think the issue is with the adapter or even the hdmi switch. It must be related to the new way the rpi4 is handling the gpu compared to the rpi2/3. (Which I own too and work perfectly)
The OS loads just fine because I can access it using SSH.
I wasted hours trying stuff you find around the web/forums: hdmi_force_hotplug=1, lowering the gpu_mem size, hdmi_mode=2, ... Without any success.
To me, the EDID file looks fine, but maybe I need to use a custom hdmi mode in the config.txt file?
Thanks in advance for your help
Kind regards
edid.zip
(379 Bytes) Downloaded 20 times
aBUGSworstnightmare
Sat Jan 11, 2020 8:21 am
Edid block of which device?
Run edid-decode on it an post the output.
Your TV seems to be UHD; have you enabled [email protected]?
Here is a how-to for debugging display problems https://www.raspberrypi.org/documentati ... t/video.md
As your using several devices in the signal chain I would recommemd to start from the display, then add the splitter and any other equipment.
dimster
Sat Jan 11, 2020 5:06 pm
Thanks for your feedback!
However, the added EDID file is the one when the EDID switch on the HDMI splitter is set to STD.
But it should be set to TV instead. That's what I did now, but same problem persists (blank screen). In attach you can find the correct EDID from the TV and not the HDMI splitter.
This is the mode detected/selected when I check tvservice through SSH:
state 0xa [HDMI CUSTOM RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
I think that the AVR is sending some wrong signal to the TV or something. (Maybe a standby/sleep command?)
This is the parsed output:
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 160x90 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encodin g:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is SONY_TV
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 48-62 Hz, horizontal is 15-70 kHz, max pixe l clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID established timing I/II bytes are 21 08 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/I I
HDMI:EDID standard timings block x 8: 0x8180 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 0
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:ye s, yuv422:yes, #native DTD:4
HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 10, 2880x480i @ 60Hz
HDMI:EDID found CEA format: code 11, 2880x480i @ 60Hz
HDMI:EDID found CEA format: code 14, 1440x480p @ 60Hz
HDMI:EDID found CEA format: code 35, 2880x480p @ 60Hz
HDMI:EDID found CEA format: code 15, 1440x480p @ 60Hz
HDMI:EDID found CEA format: code 36, 2880x480p @ 60Hz
HDMI:EDID found CEA format: code 25, 2880x576i @ 50Hz
HDMI:EDID found CEA format: code 26, 2880x576i @ 50Hz
HDMI:EDID found CEA format: code 29, 1440x576p @ 50Hz
HDMI:EDID found CEA format: code 37, 2880x576p @ 50Hz
HDMI:EDID found CEA format: code 30, 1440x576p @ 50Hz
HDMI:EDID found CEA format: code 38, 2880x576p @ 50Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|88|96|176|192 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 8 channels PCM, sample rate: 32|44|48|88|96|176|192 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 6 channels AC3, sample rate: 32|44|48 kHz, bitrate: 640 kbps
HDMI:EDID found audio format 7 channels DTS, sample rate: 32|44|48|88|96 kHz, bi trate: 1536 kbps
HDMI:EDID found audio format 6 channels One Bit Audio, sample rate: 44 kHz, code c define: 0
HDMI:EDID found audio format 8 channels Dobly Digital+, sample rate: 44|48 kHz, codec define: 0
HDMI:EDID found audio format 8 channels MLP, sample rate: 48|96|192 kHz, codec d efine: 0
HDMI:EDID found audio format 8 channels DTS-HD, sample rate: 48|96|192 kHz, code c define: 1
HDMI:EDID found HDMI VSDB length 8
HDMI:EDID HDMI VSDB has physical address 1.4.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv 444:yes
HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
HDMI:EDID HDMI VSDB content type support: game|cinema|photo|text
HDMI:EDID found Video Capability DB length 2
HDMI:EDID video capability: CE:3 IT:2 PT:3 QS:1
HDMI:EDID filtering formats with pixel clock unlimited MHz or h. blanking unlimi ted
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clo ck 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MH z (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MH z (score 66472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 6 6472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 M Hz (score 4635592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 1 8432
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 149416
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 2 8800
HDMI:EDID CEA mode (10) 2880x480i @ 60 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (11) 2880x480i @ 60 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (14) 1440x480p @ 60 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (15) 1440x480p @ 60 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 14 8 MHz (score 5398248)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3617160
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score o f 128680
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (25) 2880x576i @ 50 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (26) 2880x576i @ 50 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (29) 1440x576p @ 50 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (30) 1440x576p @ 50 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 4232360
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score o f 124532
HDMI:EDID CEA mode (35) 2880x480p @ 60 Hz with pixel clock 108 MHz has a score o f 66472
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 103643
HDMI:EDID CEA mode (36) 2880x480p @ 60 Hz with pixel clock 108 MHz has a score o f 66472
HDMI:EDID CEA mode (37) 2880x576p @ 50 Hz with pixel clock 108 MHz has a score o f 66472
HDMI:EDID CEA mode (38) 2880x576p @ 50 Hz with pixel clock 108 MHz has a score o f 66472
HDMI0:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clo ck 148 MHz
HDMI:EDID has HDMI support and audio support
edidparser exited with code 0
edid_46HX800.zip
(389 Bytes) Downloaded 16 times
aBUGSworstnightmare
Sat Jan 11, 2020 7:34 pm
Do us a favour and use edid-decode.
Make sure to install it by 'sudo apt install edid-decode' and then run it on your edid data
I learned that parse-edid will give incorrect output so I stopped using it and use edid-decode instead.
 tvservice -d some-edid
edid-decode < some-edid
dimster
Sun Jan 12, 2020 2:17 pm
OK, sorry for that.
This is the EDID when the AVR is powered on:
EDID version: 1.3
Manufacturer: SNY Model ee01 Serial Number 16843009
Made in week 1 of 2010
Digital display
Maximum image size: 160 cm x 90 cm
Gamma: 2.20
RGB color display
First detailed timing is preferred timing
Display x,y Chromaticity:
Red: 0.6250, 0.3398
Green: 0.2802, 0.5947
Blue: 0.1552, 0.0703
White: 0.2832, 0.2978
Established timings supported:
[email protected] 4:3 HorFreq: 31469 Hz Clock: 25.175 MHz
[email protected] 4:3 HorFreq: 37900 Hz Clock: 40.000 MHz
[email protected] 4:3 HorFreq: 48400 Hz Clock: 65.000 MHz
Standard timings supported:
[email protected] 5:4 HorFreq: 64000 Hz Clock: 108.000 MHz
Detailed mode: Clock 148.500 MHz, 1600 mm x 900 mm
1920 2008 2052 2200 hborder 0
1080 1084 1089 1125 vborder 0
+hsync +vsync
VertFreq: 60 Hz, HorFreq: 67500 Hz
Detailed mode: Clock 74.250 MHz, 1600 mm x 900 mm
1280 1390 1430 1650 hborder 0
720 725 730 750 vborder 0
+hsync +vsync
VertFreq: 60 Hz, HorFreq: 45000 Hz
Monitor name: SONY TV
Monitor ranges (GTF): 48-62Hz V, 15-70kHz H, max dotclock 150MHz
Has 1 extension blocks
Checksum: 0xbd (valid)
CTA extension block
Extension version: 3
70 bytes of CTA data
Video data block
VIC 31 [email protected] 16:9 HorFreq: 56250 Hz Clock: 148.500 MHz
VIC 16 [email protected] 16:9 HorFreq: 67500 Hz Clock: 148.500 MHz
VIC 20 [email protected] 16:9 HorFreq: 28125 Hz Clock: 74.250 MHz
VIC 5 [email protected] 16:9 HorFreq: 33750 Hz Clock: 74.250 MHz
VIC 19 [email protected] 16:9 HorFreq: 37500 Hz Clock: 74.250 MHz
VIC 4 [email protected] 16:9 HorFreq: 45000 Hz Clock: 74.250 MHz
VIC 18 [email protected] 16:9 HorFreq: 31250 Hz Clock: 27.000 MHz
VIC 17 [email protected] 4:3 HorFreq: 31250 Hz Clock: 27.000 MHz
VIC 22 [email protected] 16:9 HorFreq: 15625 Hz Clock: 27.000 MHz
VIC 21 [email protected] 4:3 HorFreq: 15625 Hz Clock: 27.000 MHz
VIC 3 [email protected] 16:9 HorFreq: 31469 Hz Clock: 27.000 MHz
VIC 2 [email protected] 4:3 HorFreq: 31469 Hz Clock: 27.000 MHz
VIC 7 [email protected] 16:9 HorFreq: 15734 Hz Clock: 27.000 MHz
VIC 6 [email protected] 4:3 HorFreq: 15734 Hz Clock: 27.000 MHz
VIC 1 [email protected] 4:3 HorFreq: 31469 Hz Clock: 25.175 MHz
VIC 32 [email protected] 16:9 HorFreq: 27000 Hz Clock: 74.250 MHz
VIC 10 [email protected] 4:3 HorFreq: 15734 Hz Clock: 54.000 MHz
VIC 11 [email protected] 16:9 HorFreq: 15734 Hz Clock: 54.000 MHz
VIC 14 [email protected] 4:3 HorFreq: 31469 Hz Clock: 54.000 MHz
VIC 35 [email protected] 4:3 HorFreq: 31469 Hz Clock: 108.000 MHz
VIC 15 [email protected] 16:9 HorFreq: 31469 Hz Clock: 54.000 MHz
VIC 36 [email protected] 16:9 HorFreq: 31469 Hz Clock: 108.000 MHz
VIC 25 [email protected] 4:3 HorFreq: 15625 Hz Clock: 54.000 MHz
VIC 26 [email protected] 16:9 HorFreq: 15625 Hz Clock: 54.000 MHz
VIC 29 [email protected] 4:3 HorFreq: 31250 Hz Clock: 54.000 MHz
VIC 37 [email protected] 4:3 HorFreq: 31250 Hz Clock: 108.000 MHz
VIC 30 [email protected] 16:9 HorFreq: 31250 Hz Clock: 54.000 MHz
VIC 38 [email protected] 16:9 HorFreq: 31250 Hz Clock: 108.000 MHz
Audio data block
Linear PCM, max channels 2
Supported sample rates (kHz): 192 176.4 96 88.2 48 44.1 32
Supported sample sizes (bits): 24 20 16
Linear PCM, max channels 8
AC-3, max channels 6
Supported sample rates (kHz): 48 44.1 32
Maximum bit rate: 640 kb/s
DTS, max channels 7
Supported sample rates (kHz): 96 88.2 48 44.1 32
Maximum bit rate: 1536 kb/s
One Bit Audio, max channels 6
Supported sample rates (kHz): 44.1
Dolby Digital+, max channels 8
MAT (MLP), max channels 8
Supported sample rates (kHz): 192 96 48
DTS-HD, max channels 8
Speaker allocation data block
Speaker map:
FL/FR - Front Left/Right
LFE - Low Frequency Effects
FC - Front Center
BL/BR - Back Left/Right
BC - Back Center
RLC/RRC - Rear Left/Right of Center
Vendor-specific data block, OUI 000c03 (HDMI)
Source physical address 1.4.0.0
Supports_AI
DC_36bit
DC_30bit
DC_Y444
Maximum TMDS clock: 225MHz
Supported Content Types:
Graphics
Cinema
Game
Extended tag: Video capability data block
YCbCr quantization: No Data (0)
RGB quantization: Selectable (via AVI Q) (1)
PT scan behaviour: Support both over- and underscan (3)
IT scan behaviour: Always Underscanned (2)
CE scan behaviour: Support both over- and underscan (3)
Underscans PC formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
4 native detailed modes
1920 2448 2492 2640 hborder 0
+hsync +vsync
VertFreq: 50 Hz, HorFreq: 56250 Hz
1280 1720 1760 1980 hborder 0
+hsync +vsync
VertFreq: 50 Hz, HorFreq: 37500 Hz
Checksum: 0xb4 (valid)
And this is the EDID when the AVR is in standby mode (Passthrough mode):
EDID version: 1.3
Digital display
Gamma: 2.20
RGB color display
Red: 0.6250, 0.3398
+hsync +vsync
+hsync +vsync
CTA extension block
40 bytes of CTA data
Video data block
Audio data block
Speaker map:
Supports_AI
DC_36bit
DC_30bit
DC_Y444
Graphics
Cinema
Game
Basic audio support
6 native detailed modes
+hsync +vsync
+hsync +vsync
540 542 547 562 vborder 0
+hsync +vsync interlaced
VertFreq: 60 Hz, HorFreq: 33750 Hz
VertFreq: 50 Hz, HorFreq: 28125 Hz
Checksum: 0x4 (valid)
These are the specs of the AVR: https://europe.yamaha.com/en/products/a ... specs.html
Return to “Advanced users”
