john_alan
Entropy of headless setup
Fri Jan 10, 2020 11:27 am
Is the entropy of a headless raspberry pi setup considered OK despite having no keyboard/mouse, given that the pi boasts a Hardware TRNG?
epoch1970
Re: Entropy of headless setup
Fri Jan 10, 2020 9:08 pm
If by "OK" you mean "works" then yes it does work. Raspbian Lite (others?) comes preinstalled with rngd or haveged, I don't remember having seen processes fail or block waiting for entropy.
HawaiianPi
Fri Jan 10, 2020 9:17 pm
Depends in which version of Raspbian. Older versions didn't include rng-tools by default, more recent ones do.
apt policy rng-tools
jahboater
Fri Jan 10, 2020 10:10 pm
Isn't some entropy saved to disk so that its available immediately on boot up?
HawaiianPi
Fri Jan 10, 2020 10:20 pm
Don't know about that, but there used to be a problem with headless VNC taking a long time to reconnect after a reboot (due to lack of entropy), and installing haveged or rng-tools seemed to fix it. Because of that, the Raspbian devs started including rng-tools by default in some version of Stretch (don't recall exactly when). So later versions of Stretch and all versions of Buster should have it.
trejan
Fri Jan 10, 2020 11:49 pm
IIRC it also caused problems with the SSH host key generation at first boot which took a long time. If people were impatient and pulled power because it appeared to be dead then they could end up with the keys half generated. The SSH server wouldn't work but it also wouldn't regenerate the keys.
john_alan
Sat Jan 11, 2020 9:57 am
Thanks folks sounds good.
