I am having problems getting a USB hard drive connected. I have a Raspberry Pi with Arch Linux installed on a USB hard drive. This boots fine. The hard drive that I have Arch Linux installed on is an external 2.5in USB drive. I have this powered from a powered USB hub but connected directly to the bottom USB port on my Pi. I then have this USB hub connected to the top USB port on my Pi. I have then connected another 2.5in USB hard drive to the USB hub. I then get the following in the kernel.log:
Aug 10 21:37:14 alarmpi kernel: [ 154.542425] usb 1-1.2: new high speed USB device number 14 using dwc_otg
Aug 10 21:37:14 alarmpi kernel: [ 154.642851] usb 1-1.2: New USB device found, idVendor=04b4, idProduct=6560
Aug 10 21:37:14 alarmpi kernel: [ 154.642883] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 10 21:37:14 alarmpi kernel: [ 154.655107] hub 1-1.2:1.0: USB hub found
Aug 10 21:37:14 alarmpi kernel: [ 154.655385] hub 1-1.2:1.0: 4 ports detected
Aug 10 21:37:28 alarmpi kernel: [ 168.672399] usb 1-1.2: reset high speed USB device number 14 using dwc_otg
Aug 10 21:37:28 alarmpi kernel: [ 168.752339] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:28 alarmpi kernel: [ 168.942343] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:28 alarmpi kernel: [ 169.132347] usb 1-1.2: reset high speed USB device number 14 using dwc_otg
Aug 10 21:37:28 alarmpi kernel: [ 169.212349] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:28 alarmpi kernel: [ 169.402347] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:29 alarmpi kernel: [ 169.592356] usb 1-1.2: reset high speed USB device number 14 using dwc_otg
Aug 10 21:37:29 alarmpi kernel: [ 170.012217] usb 1-1.2: device not accepting address 14, error -71
Aug 10 21:37:29 alarmpi kernel: [ 170.092352] usb 1-1.2: reset high speed USB device number 14 using dwc_otg
Aug 10 21:37:30 alarmpi kernel: [ 170.512222] usb 1-1.2: device not accepting address 14, error -71
Aug 10 21:37:30 alarmpi kernel: [ 170.622234] hub 1-1.2:1.0: hub_port_status failed (err = -19)
Aug 10 21:37:30 alarmpi kernel: [ 170.622281] hub 1-1.2:1.0: hub_port_status failed (err = -19)
Aug 10 21:37:30 alarmpi kernel: [ 170.622305] hub 1-1.2:1.0: hub_port_status failed (err = -19)
Aug 10 21:37:30 alarmpi kernel: [ 170.622327] hub 1-1.2:1.0: hub_port_status failed (err = -19)
Aug 10 21:37:30 alarmpi kernel: [ 170.622346] hub 1-1.2:1.0: activate --> -19
Aug 10 21:37:30 alarmpi kernel: [ 170.622619] usb 1-1.2: USB disconnect, device number 14
Aug 10 21:37:30 alarmpi kernel: [ 170.702364] usb 1-1.2: new high speed USB device number 15 using dwc_otg
Aug 10 21:37:30 alarmpi kernel: [ 170.782477] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:30 alarmpi kernel: [ 170.972346] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:30 alarmpi kernel: [ 171.162344] usb 1-1.2: new high speed USB device number 16 using dwc_otg
Aug 10 21:37:30 alarmpi kernel: [ 171.242348] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:30 alarmpi kernel: [ 171.432349] usb 1-1.2: device descriptor read/64, error -71
Aug 10 21:37:31 alarmpi kernel: [ 171.622349] usb 1-1.2: new high speed USB device number 17 using dwc_otg
Aug 10 21:37:31 alarmpi kernel: [ 172.042219] usb 1-1.2: device not accepting address 17, error -71
Aug 10 21:37:31 alarmpi kernel: [ 172.122357] usb 1-1.2: new high speed USB device number 18 using dwc_otg
Aug 10 21:37:32 alarmpi kernel: [ 172.542218] usb 1-1.2: device not accepting address 18, error -71
Aug 10 21:37:32 alarmpi kernel: [ 172.542481] hub 1-1:1.0: unable to enumerate USB device on port 2
Robert
