BrodyStone21
Headless Pi not booting into correct screen resolution.
Wed Dec 04, 2019 6:11 pm
I am currently running a headless pi 4b and I am using mosh and VNC viewer to control it. I have specified in my config.txt file to boot into 1080p @60Hz however this only works if I have my 1080p monitor plugged in. Before if I would start the Pi without a monitor plugged in I couldn't use VNC viewer but now I can, it's just in the wrong resolution. It is currently outputting 1024x768 @ 60.00Hz, progressive instead of 1920x1080.
Below are the config settings I have changed along with disabling overscan. According to the RPi website group, 2 and mode, 82 should be outputting 1920x1080 progressive @60Hz. I got this information from https://www.raspberrypi.org/documentati ... t/video.md
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=82
FTrevorGowen
Re: Headless Pi not booting into correct screen resolution.
Wed Dec 04, 2019 9:09 pm
hdmi_group=2
hdmi_mode=82
When running headless (assuming you can/do SSH in ...) probably better to start the server in virtual mode - some examples here:
https://www.cpmspectrepi.uk/raspberry_p ... uster.html
NB: that means you can specify the display geometry.
Trev.
BrodyStone21
Wed Dec 04, 2019 9:42 pm
So would I want to disable the vnc server from automatically starting on boot? And then ssh into my machine and then do vncserver --geometery 1920x1080? Or what would I do, I'm having a hard time following all of those pictures.
Update: I tried disabling vncserver on startup and the SSHing into my pi and running the command vncserver -randr=1920x1080 and then opening vncviewer but it says its not currently looking for cloud connections when I try to do that.
FTrevorGowen
Wed Dec 04, 2019 9:53 pm
The virtual mode runs independently of any "automatic on boot" service and creates a different connection - Note the ':1' after the IP address . I use a PuTTY terminal to login by SSH to a P4B that's the window with the yellow background where you'll find the vncserver command used to start the server - it reports back with the required connection for the RealVNC viewer.
Trev.
BrodyStone21
Wed Dec 04, 2019 10:02 pm
Okay, thank you for the help I managed to get it to boot into the resolution in which I desired, however how do I open this over the cloud. For example, right now I can enter 10.0.0.145:1 in vncviewer but what would I do if I wasn't connected to the same internet?
FTrevorGowen
Wed Dec 04, 2019 10:30 pm
Sorry, don't use "the cloud" so can't provide much advice but, if your "direct" server address ends in ":0" (analogous to 10.0.0.145:0 for the "direct" local connection) perhaps try replacing with ":1" (analogous to 10.0.0.145:1 above). If that's not "the pattern" then, hopefully a cloud user here will advise further (and, presumably, you also need to be able to login remotely by SSH using a good secure method)
Trev.
