NPDedyukhin
Pi Camera Cable Length
Fri Nov 29, 2019 8:23 am
Good day to all! :)
Why does the Pi Camera have such a short cable?
If I want to place the camera on the street, then it turns out the device itself will also have to be placed on the street?
Or are there other ways? :geek:
Respectfully,
Nikita Dedyukhin
Re: Pi Camera Cable Length
Fri Nov 29, 2019 8:44 am
Good day to all! :)
https://thepihut.com/products/raspberry ... -extension
Retired disgracefully.....
......to an uncomplicated life !
Fri Nov 29, 2019 9:11 am
The electrical signals on the cable are very tiny and also fast. Long cables can mean that the signals become too weak to use or will get corrupted during transmission. The camera module is similar to those used in some mobile phones. How long are the cables inside them?
As stated there are unofficial extensions available, but the picture quality is not guaranteed, especially at higher resolutions or frame rates.
Fri Nov 29, 2019 9:14 am
You can go longer. 15cm is OK on my V1 camera. Lengths up to 30cm need local testing. There's even an adaptor that splits the cable put and lets you run over an HDMI cable as an extension.
HermannSW
Fri Nov 29, 2019 9:50 am
Only 15cm is supported, but I use 1m and 2m cables routinely:
https://www.raspberrypi.org/forums/view ... m#p1542203
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Burngate
Fri Nov 29, 2019 10:24 am
It depends how far away the street is, but you may find it's cheaper to place a Pi close to the camera, and use very much cheaper network cable for the long distance
Return to “Camera board”
