I have tried removing the infrared filter from some old webcams, I am thinking of doing thermal imaging with a thermometer module attached as a control to room temperature.
My question is how the current camera module designed? Can I remove the IR filter as easy as normal webcams?
Re: Thermal imaging possible?
AFAIK , there is no camera module yet.
There is a protoype , but the RPi has had protypes too. Several of them.
Cost-saving is very important for the foundation .
So , let's wait a bit ...
ghans
ghans
Aloha 'oe,
This question was asked several times in this thread http://www.raspberrypi.org/phpBB3/viewt ... =43&t=6120
but unfortunately has never been answered...and it is going to be a phone camera, so very small.
I belief in the RPi community that they will come up with a mod
I imagine a lot of people will want to use the camera module to make some kind of automated surveillance device. That's what I want it for. I was wanting to make a baby monitor and don't mind added IR LED's for extra lighting. Hopefully a camera module with a removable filter is made available -- or two different camera modules: one with an IR filter and one without.
- Grumpy Mike
- Contact: Website
The wavelengths you want for thermal imaging are way longer than you can detect with a camera sensor with the IR filter removed. Just look at the difference in price between an IR camera and a thermal imaging camera.
A standard silicon CCD or CMOS sensor can detect near-IR wavelengths out to about 1 um, which can see things slightly less than visibly red-hot:
http://www.bealecorner.com/trv900/d8/ir/index.html
However that's a long way away from the exotic sensors needed for the 3-5 um Mid-IR wavelength band, which you need for imaging objects at or near normal room temperatures.
http://www.bealecorner.com/trv900/thermal/therm.html
- Gert van Loo
- Contact: Website
So you can us it only for very, very, very close upsA standard silicon CCD or CMOS sensor can detect near-IR wavelengths out to about 1 um
Sometimes it's hard to know what to read when a hobbyist seeks whether his idea is possible, thanks for pointing out the wavelength thing.
Just today I came across this: http://www.melexis.com/Infrared-Thermom ... 0-776.aspx
Super-low resolution at only 16x4 pixels, but it is a true thermal imager (thermopile technology) and it costs about $65.
http://www.digikey.com/scripts/DkSearch ... 20&cur=USD
If you think that's expensive, compare that to a "traditional" thermal imager, like the FLIR line ranging from FLIR i7 at $2000 through FLIR T640 at $26000, to SC8000 at (? probably > $100k)
http://www.shopflir.com/p7655/flir_i7_i ... QgodB3UAew
http://www.shopflir.com/p12100/flir_t64 ... camera.php
http://www.flir.com/thermography/americ ... /?id=45674
Extracted from http://www.flir.com/thermography/americ ... /?id=51657jbeale wrote:... If you think that's expensive, compare that to a "traditional" thermal imager, like the FLIR line ranging from FLIR i7 at $2000 through FLIR T640 at $26000, to SC8000 at (? probably > $100k) ...
... With this overstock pricing, you can experience beautiful high speed HD IR Imagery for at 1k by 1k for under $100k.
Looks like it ain't gonna be easy to remove the IR filter from the sensor as the glass 'undercuts' the plastic holding module,vicary wrote:I have tried removing the infrared filter from some old webcams, I am thinking of doing thermal imaging with a thermometer module attached as a control to room temperature.
Heh: http://www.raspberrypi.org/phpBB3/viewt ... 43&t=44339Bleugh wrote:Looks like it ain't gonna be easy to remove the IR filter from the sensor as the glass 'undercuts' the plastic holding module,vicary wrote:I have tried removing the infrared filter from some old webcams, I am thinking of doing thermal imaging with a thermometer module attached as a control to room temperature.
Flir are far to expensive...
maybe this kind of IR thermometer with USB connection could be easily hacked?
http://www.ebay.co.uk/itm/NON-CONTACT-I ... 19ca52efd0
around 100£ on Ebay.
If you could read the data via usb and user a 2 stepper motor to automate the measures in X and Y axis....
Non usb version could be as cheap as 5-10£!! just scan , read the lcd with a camera? use same 2 motors to make multiple points/measure.
just my 2 cents.
Leo
just my 2 cents.
Leo
Cool - good find! Any idea how easy it would be to interface with an RPi?
jbeale wrote:Just today I came across this: http://www.melexis.com/Infrared-Thermom ... 0-776.aspx
