Church Lenard
Re: Image overlay on live video feed
Sun Nov 17, 2019 7:31 pm
gordon77 wrote:
Sun Nov 17, 2019 7:01 pm
Is the camera working? The error message could suggest there is nothing in img. This may also explain your earlier problem.
Did it print a size?
Did you save the reticle as Reticle2.jpg?
If you do ls /dev do you see Video0?
i see video0 but when the script runs it just pulls up a small window thats completely black also i ran it with both reticle2.jpg and my own and it came out with the same results
gordon77
Sun Nov 17, 2019 7:40 pm
Did you see a size printed?
You may to use IDLE3 to see the print output. You can install it, if you don't have it, with sudo apt-get install idle3.
Then run the script through IDLE3.
gordon77
Sun Nov 17, 2019 7:43 pm
what do you see if you run this?
  #!/usr/bin/env python3
import cv2
import os
import time
# setup pi camera
if os.path.exists('/dev/video0') == False:
  path = 'sudo modprobe bcm2835-v4l2'
  os.system (path)
  time.sleep(1)
path = 'v4l2-ctl --set-ctrl=auto_exposure=0'
os.system (path)
# start video
cam = cv2.VideoCapture(0)
# show video size
print (cam.get(3)  , cam.get(4))
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
cv2.namedWindow(winName)
while True:
    # take video frame
    ok, img = cam.read()
    # show image
    cv2.imshow( winName,img)
    # wait
    key = cv2.waitKey(10)
    # press Esc to EXIT
    if key == 27:
       cv2.destroyWindow(winName)
       break
gordon77
Sun Nov 17, 2019 7:46 pm
I have just spotted your earlier error message says img but it should be img2, so that means you are not loading the Reticle2.jpg. Note the capital R.
Church Lenard
Sun Nov 17, 2019 7:47 pm
import cv2
import os
import time
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
while True:
    # take video frame
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
k so this code displays the feed and i am running it in python 3 idle so i dont know if idl3 is a different program but ill try that install code
Church Lenard
Sun Nov 17, 2019 7:50 pm
i am using Reticle2.jpg it gives the same error regardless
gordon77
Sun Nov 17, 2019 7:51 pm
Is the jpg in /home/pi?
Church Lenard
Sun Nov 17, 2019 7:55 pm
its in the downloads
gordon77
Sun Nov 17, 2019 8:07 pm
Copy it to /home/pi or change the script to /home/pi/Documents/Reticle2.jpg
img2 = cv2.imread('/home/pi/Documents/Reticle2.jpg')
Church Lenard
Sun Nov 17, 2019 8:16 pm
im a freaking idiot now it works
Church Lenard
Sun Nov 17, 2019 8:20 pm
ok so one last question how do you make it go fullscreen instead of windowed?
gordon77
Sun Nov 17, 2019 8:29 pm
Try changing it to
cv2.namedWindow(winName, cv2.WND_PROP_FULLSCREEN)
cv2.setWindowProperty(winName, cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
Church Lenard
Sun Nov 17, 2019 8:32 pm
Try changing it to
that kinda worked but its still got the same windowed size and the rest is white
edit: ok so after further inspection on this it displays nearly fullscreen its got a few pixels on the sides that are pure white and interfere slightly with the camera feed also the image has shrunk drastically is there a way to resize these to accommodate for the pixel loss?
carcela
Mon Nov 18, 2019 3:42 am
You can use pi3d:
https://github.com/tipam/pi3d
Church Lenard
Mon Nov 18, 2019 5:20 am
You can use pi3d:
pi 3d looks great and all but its really too much of a hassle to work in a 3d plane to switch back to a 2d plane when all i need to do now is scale up an image
gordon77
Mon Nov 18, 2019 10:28 am
Try changing it to
I don't know why this didn't work correctly, in fact it does sometimes on my PI4 !.
Here's a workaround which reads the resolution of the monitor, sets the camera to half that (i found the colours odd if I set it to the same as my monitor at 1920 x 1080), it then scales to fit.
Note the new reticle4.jpg (zipped).
import cv2
import os
import time
import tkinter as tk
# read screen resolution
root = tk.Tk()
screen_width = root.winfo_screenwidth()
screen_height = root.winfo_screenheight()
print (screen_width , screen_height)
invert_mask = 0
# mouse action
def point(event, x, y, flags, param):
    global invert_mask
    if event == cv2.EVENT_LBUTTONDOWN:
        if invert_mask == 0:
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
print (cam.get(3),cam.get(4))
# set video size
cam.set(3,screen_width/2)
cam.set(4,screen_height/2)
# setup window
winName = "Scope"
cv2.namedWindow(winName,cv2.WND_PROP_FULLSCREEN)
cv2.setWindowProperty(winName, cv2.WND_PROP_FULLSCREEN,cv2.WINDOW_FULLSCREEN)
# setup mouse callback
cv2.setMouseCallback('Scope',point)
# read foreground image
img2 = cv2.imread('Reticle4.jpg')
img3 = (255-img2)
img2gray = cv2.cvtColor(img2,cv2.COLOR_BGR2GRAY)
ret, mask = cv2.threshold(img2gray, 10, 255, cv2.THRESH_BINARY)
mask = cv2.resize(mask,(screen_width,screen_height))
while True:
    # take video frame
    img = cv2.resize(img,(screen_width,screen_height))
    # add the 2 images
        added_image = cv2.bitwise_and(img,img,mask = mask)
    else:
        added_image = cv2.addWeighted(img,0.99,img3,0.7,0.2)
    # show image
    cv2.imshow( winName,added_image)
    # wait
    # press Esc to EXIT
    if key == 27:
       break
Reticle4.jpg.bz2
(70.91 KiB) Downloaded 11 times
HermannSW
Mon Nov 18, 2019 1:54 pm
gordon77 wrote:
Sun Nov 17, 2019 9:17 am
This will show you the video size, and set it to 640 x 480...
Also a new mask.
import cv2
import os
import time
# setup pi camera
    if key == 27:
       break
Thank's again for that script.
I have not done much with Python yet (more with MicroPython on ESP microcontrollers).
I was able to use my own sample_yuv_alpha plugin for bash i420toh264 pipeline.
But it did negatively affect the P only PID controller for stepper PT camera system.
I did need the fine haircross overlay for PID behavior inspection, so doing that in post processing was fine.
Normally I do video stuff with ffmpeg, but alpha blending onto a video seems not to be that simple.
Contrary to your script, which is simple.
So I created a file2file version of your script and used that:
(cv) [email protected]:~ $ cat ovl.file2file.py
import cv2
import os
import time
# video from file
cap = cv2.VideoCapture('tst.h264')
# video output to file
out = cv2.VideoWriter('outpy.avi',cv2.VideoWriter_fourcc('M','J','P','G'), 15, (640,480))
img2 = cv2.imread('640x480.fine_crosshair_450.pgm')
while True:
    # take video frame
    ok, img = cap.read()
    if not ok:
        break
    # add the 2 images
    # write image
    out.write(added_image)
(cv) [email protected]ypi4B:~ $
From the generated video (Python script slows down from [email protected] to 15fps) I created animated .gif of first 7 seconds with gifenc.sh, scaled down to 320x240 in order to keep size at 4MB. This allows to analyze automatic camera movement to blue point (generated by 2 heuristics) on black ball:
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
gordon77
Mon Nov 18, 2019 1:59 pm
I'm pleased it was helpful :D
Church Lenard
Mon Nov 18, 2019 3:02 pm
Also a new mask.
import cv2
import os
import time
# setup pi camera
    if key == 27:
       break
import cv2
import os
import time
# video from file
while True:
    # take video frame
    if not ok:
        break
    # add the 2 images
    # write image
Looks amazing! I can see a few uses for this both in practical and in cosplay areas
Church Lenard
Mon Nov 18, 2019 3:31 pm
Try changing it to
import cv2
import os
import time
root = tk.Tk()
invert_mask = 0
# mouse action
    global invert_mask
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
# setup window
winName = "Scope"
img3 = (255-img2)
while True:
    # take video frame
    # add the 2 images
    else:
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
K so i ran the code and it looks great however is there a way to up the framelimit? its running at about 10fps i think
HermannSW
Mon Nov 18, 2019 4:37 pm
You can find the details here:
https://www.raspberrypi.org/forums/view ... 3#p1568093
carcela
Tue Nov 19, 2019 1:35 am
You can use pi3d:
I already worked on a digital telescope, I advise you to use Picamera (1% of the cpu) instead of opencv (more than 20% cpu) and to display your reticle with pi3d. My program did not take more than 5% cpu with a more sophisticated screen. What is the cpu percentage after executing your program?
Church Lenard
Tue Nov 19, 2019 5:12 am
looks to be below 50%
Church Lenard
Wed Nov 20, 2019 7:25 pm
Also a new mask.
import cv2
import os
import time
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
img2 = cv2.imread('Reticle2.jpg')
while True:
    # take video frame
    # add the 2 images
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
and a version with black or white reticle with a click of the mouse...
import cv2
import os
import time
invert_mask = 0
# mouse action
    global invert_mask
            invert_mask = 1
        else:
            invert_mask = 0
# setup pi camera
  os.system (path)
  time.sleep(1)
os.system (path)
# start video
# show video size
# set video size
cam.set(3,640)
cam.set(4,480)
# setup window
winName = "Scope"
img3 = (255-img2)
while True:
    # take video frame
    # add the 2 images
    else:
    # show image
    # wait
    # press Esc to EXIT
    if key == 27:
       break
Hey so ive gotten this code running in 640x480 and it runs better than the 1920x1080 and i was wondering if there was a way to make the image a bit larger for the 640x480 code?
gordon77
Thu Nov 21, 2019 9:20 am
You could change your monitor to 640x480.
Assuming you are using the GUI..
Choose Preferences from Menu
Choose Screen Configuration
Choose Screens
Choose HDMI-1
Choose Resolution
Choose 640x480
Click on the Green Tick
Choose OK
Return to “Camera board”
