Geordon
WLAN MAC address changes at every reboot?
Sun Apr 07, 2019 8:00 am
I am in the US and have Xfinity as my Internet provider. They have the rented routers set up so that you can do some basic LAN and usage monitoring on their website, where you can see the devices connected to the WiFi router.
This evening, I discovered that my brand new RPi 3 B+ keeps changing the MAC address that the router sees every time it reboots. Some examples of the addresses that have shown tonight are:
26FAC023F266
323B93DE1451
AAF284033D5D
5A779C7B38A5
2A61D54909F0
This also causes a new IP address to be assigned via DHCP, so my ssh keys are getting screwed up every time I reboot the Pi.
I have updated and upgraded all of the installed software on the Pi.
Two questions:
  • What is causing this?
  • How can I either force a consistent MAC address or hard code an IP address for the wlan0 interface?
This is a crazy thing and it shouldn't be doing what it's doing, but I don't know where to start looking to figure this out. I would have thought that the MAC address was hard-coded into the wlan hardware...
B.Goode
Re: WLAN MAC address changes at every reboot?
Sun Apr 07, 2019 8:12 am
What Operating System is running on your RPi 3b+?
What additional software have you installed?
(Your expectation is correct: the wlan Mac address should be 'hardwired' and derived from the system hardware serial number. The Mac addresses you are seeing are not from the range assigned to Raspberry Pi Foundation/Trading. Something else 'odd' is going on.)
Are you in a position to put a completely standard unmodified release of Raspbian Stretch on a new/spare microSD card and check its behaviour?
Sun Apr 07, 2019 10:32 am
I've got a 3B that does this. It's got a static IP assigned by my router but the MAC changes at every boot and it gets a DHCP pool address.
I've not had enough time to find whether it's a firmware bug or a Raspbian bug.
It runs my ADS-B receiver so it's going to be a pain to build a new SDCard - so at the moment that's on hold until Raspbian Buster emerges from its cocoon some time in the next few months. That Raspberry will be the first on Buster.
It works ok and it does the FlightAware job ok as it is so I'm applying the "if it ain't broke" rule.
Geordon
Sun Apr 07, 2019 2:44 pm
DougieLawson wrote: I've got a 3B that does this. It's got a static IP assigned by my router but the MAC changes at every boot and it gets a DHCP pool address.
It's driving me batty. However, after I burned the SD card with Stretch (again) it seems to be holding the MAC address fine. Is there somewhere on the Pi that I can manually set the IP address snd still get everything else via DHCP?
I'm glad to know its not just me experiencing this weirdness.
Andyroo
Sun Apr 07, 2019 2:52 pm
You can set a static IP in /etc/dhcpcd.conf
Mine has:
interface wlan0
    static ip_address=192.168.1.2/24
    static routers=192.168.1.254
For my WiFi link but you can do the same for eth0 if you want.
Geordon
Sun Apr 07, 2019 8:25 pm
I'm slightly confused. In order to get something similar, I had to install udhcpd, which seems to be a full DHCP server implementation. My Xfinity router is my local DHCP service provider, and I want it to stay that way.
Is there a package that I should be looking for to install that file, or do I just need to manually create it as you showed and that will be enough to get the job done to force the specified IP address?
Geordon
Sun Apr 07, 2019 9:04 pm
Ok, I was able to force the WiFi address, but the MAC is still flipping all over the place with reboots, which is playing havoc with the router's device table. I plugged the Pi in via Ethernet and was able to use the network preferences tool to configure the address.
This is definitely an annoying issue. Is there somewhere I can submit a bug report or something?
mattmiller
Sun Apr 07, 2019 9:26 pm
JFI I just tried rebooting my Pi3B+ to see what happens and its kept its MAC address of b8:27:eb:7f:21:68 so it doesn't happen to them all
glum
Sun Apr 07, 2019 10:17 pm
`dhcpcd` is the default dhcp client in Raspbian. You don't need to install anything.
Geordon
Sun Apr 07, 2019 10:25 pm
Aurgh! I just rebooted my Pi again (while it was still plugged into Ethernet) and BOTH of the interfaces changed MAC addresses!
NGC6543
Sun Apr 07, 2019 11:37 pm
Assuming (dangerous, I know) that the (seemingly top secret) LAN7515 is similar to the LAN7500, the MAC address is either stored in an external EEPROM or is configured by the driver. I cannot see an EEPROM anywhere near the LAN7515, so in the absence of any other clues must assume it's done by the driver.
Edit to add: Just realised we're mainly talking about WLAN. The below still applies.
Now, that should be done by some algorithm that doesn't change. It's simply wrong that it can do so without external influence. Anyway...
External influence... if the driver supports the standard ifconfig command to change MAC address, perhaps putting it in a startup script would do the trick.
ifconfig eth0 hw ether MAC-ADDRESS
Maybe worth a try. I'm not running it my 3B+, because it's working properly and I don't want to scupper it :lol:
The other possibility of course is that the LAN7515 holds the MAC address internally in which case, if no software is deliberately changing the MAC, something is broken.
Mon Apr 08, 2019 5:37 am
The Ethernet MAC is set by the driver and based on the Pi's serial number.
The built-in WiFi MAC is set the same way, but the bottom 48 bits are xored with 0x555555 to make it different to the Ethernet MAC.
Unreadable squiggle
andrum99
Mon Apr 08, 2019 7:31 am
Just had a quick look at the driver for the LAN7515, and if I've read it correctly it attempts to get a MAC address from Device Tree, then EEPROM, then OTP, then falls back to generating a random MAC address. How does the serial number get passed to the driver to calculate the MAC address? Is the OTP referenced in the driver One Time Programmable memory, or something else?
incognitum
Mon Apr 08, 2019 11:21 am
While the values are both derived from serial, I recall they are SET in different ways though.
The wifi chip has its own OTP.
Unlike Ethernet, in which case the Pi's firmware calculates desired MAC and passes it to Linux through device-tree, so driver can set it.
Are you sure that both wifi and LAN are changing?
Are you running something different than Raspbian?
RaTTuS
Contact: Twitter YouTube
Mon Apr 08, 2019 12:31 pm
cat /etc/debian_version ; uname -v ; ip link show
Covfefe
Guff666
Sun Nov 03, 2019 11:55 am
Has there been any update on this issue?
I've recently rebuilt a Pi 3B+ that was previously working fine. It's running stock stretch with all updates applied and with no additions at the moment and is suffering exactly the same behaviour.
Everything starts as expected:
Nov  3 10:15:33 docker4 systemd[1]: Starting dhcpcd on all interfaces...
Nov  3 10:15:33 docker4 dhcpcd[287]: dev: loaded udev
Nov  3 10:15:33 docker4 dhcpcd[287]: wlan0: starting wpa_supplicant
Nov  3 10:15:33 docker4 dhcpcd-run-hooks[352]: wlan0: starting wpa_supplicant
Nov  3 10:15:33 docker4 dhcpcd[287]: eth0: waiting for carrier
Nov  3 10:15:33 docker4 dhcpcd[287]: wlan0: waiting for carrier
Nov  3 10:15:33 docker4 dhcpcd[287]: wlan0: carrier acquired
Nov  3 10:15:33 docker4 dhcpcd[287]: DUID 00:01:00:01:24:3d:de:25:b8:27:eb:a6:09:03
Nov  3 10:15:33 docker4 dhcpcd[287]: wlan0: IAID eb:a6:09:03
Nov  3 10:15:33 docker4 dhcpcd[287]: wlan0: adding address fe80::c564:f0e5:bab8:c32
Nov  3 10:15:33 docker4 dhcpcd[287]: wlan0: carrier lost
Nov  3 10:15:33 docker4 dhcpcd[287]: wlan0: deleting address fe80::c564:f0e5:bab8:c32
Nov  3 10:15:36 docker4 dhcpcd[287]: wlan0: carrier acquired
Nov  3 10:15:36 docker4 dhcpcd[287]: wlan0: IAID eb:a6:09:03
Nov  3 10:15:36 docker4 dhcpcd[287]: wlan0: adding address fe80::ed76:8f08:b2b2:4fae
Nov  3 10:15:37 docker4 dhcpcd[287]: wlan0: rebinding lease of 172.29.12.3
Nov  3 10:15:37 docker4 dhcpcd[287]: wlan0: probing address 172.29.12.3/24
Nov  3 10:15:37 docker4 dhcpcd[287]: wlan0: soliciting an IPv6 router
Nov  3 10:15:41 docker4 dhcpcd[287]: wlan0: leased 172.29.12.3 for 300 seconds
Nov  3 10:15:41 docker4 dhcpcd[287]: wlan0: adding route to 172.29.12.0/24
Nov  3 10:15:41 docker4 dhcpcd[287]: wlan0: adding default route via 172.29.12.1
Nov  3 10:15:41 docker4 dhcpcd[287]: forked to background, child pid 518
Nov  3 10:15:41 docker4 systemd[1]: Started dhcpcd on all interfaces.
Nov  3 10:15:50 docker4 dhcpcd[518]: wlan0: no IPv6 Routers available
The .3 address is statically allocated by my Unifi USG.
However, 10 mins later:
Nov  3 10:25:47 docker4 dhcpcd[518]: wlan0: deleted route to 172.29.12.0/24
Nov  3 10:25:47 docker4 dhcpcd[518]: wlan0: deleted IP address 172.29.12.3/24
Nov  3 10:25:47 docker4 dhcpcd[518]: wlan0: deleting default route via 172.29.12.1
Nov  3 10:25:48 docker4 dhcpcd[518]: wlan0: carrier lost
Nov  3 10:25:48 docker4 dhcpcd[518]: wlan0: new hardware address: c2:b9:b1:9a:c2:90
Nov  3 10:25:50 docker4 dhcpcd[518]: wlan0: carrier acquired
Nov  3 10:25:50 docker4 dhcpcd[518]: wlan0: IAID b1:9a:c2:90
Nov  3 10:25:50 docker4 dhcpcd[518]: wlan0: adding address fe80::7d43:ac48:3ac3:75a9
Nov  3 10:25:50 docker4 dhcpcd[518]: wlan0: carrier lost
Nov  3 10:25:50 docker4 dhcpcd[518]: wlan0: deleting address fe80::7d43:ac48:3ac3:75a9
Nov  3 10:25:50 docker4 dhcpcd[518]: wlan0: rebinding lease of 172.29.12.3
Nov  3 10:25:51 docker4 dhcpcd[518]: wlan0: NAK: address not available from 172.29.12.1
Nov  3 10:25:51 docker4 dhcpcd[518]: wlan0: message: address not available
Nov  3 10:25:51 docker4 dhcpcd[518]: wlan0: soliciting a DHCP lease
Nov  3 10:25:51 docker4 dhcpcd[518]: wlan0: soliciting an IPv6 router
Nov  3 10:25:54 docker4 dhcpcd[518]: wlan0: offered 172.29.12.137 from 172.29.12.1
Nov  3 10:25:54 docker4 dhcpcd[518]: wlan0: probing address 172.29.12.137/24
Nov  3 10:25:59 docker4 dhcpcd[518]: wlan0: leased 172.29.12.137 for 300 seconds
Nov  3 10:25:59 docker4 dhcpcd[518]: wlan0: adding route to 172.29.12.0/24
As you can see, at 10:25:48, carrier is lost and a new hardware address allocated: which precipitates a change of IP address.
Subsequent reboots result in similar behaviour. The hardware address changes each time the system reboots and thereafter changes at random intervals. This is the result of `sudo grep dhcp /var/log/daemon | less`
Nov  3 11:49:05 docker4 systemd[1]: Starting dhcpcd on all interfaces...
Nov  3 11:49:05 docker4 dhcpcd[384]: dev: loaded udev
Nov  3 11:49:05 docker4 dhcpcd[384]: wlan0: starting wpa_supplicant
Nov  3 11:49:05 docker4 dhcpcd-run-hooks[445]: wlan0: starting wpa_supplicant
Nov  3 11:49:05 docker4 dhcpcd[384]: eth0: waiting for carrier
Nov  3 11:49:05 docker4 dhcpcd[384]: wlan0: waiting for carrier
Nov  3 11:49:05 docker4 dhcpcd[384]: wlan0: carrier acquired
Nov  3 11:49:05 docker4 dhcpcd[384]: DUID 00:01:00:01:24:3d:de:25:b8:27:eb:a6:09:03
Nov  3 11:49:05 docker4 dhcpcd[384]: wlan0: IAID eb:a6:09:03
Nov  3 11:49:05 docker4 dhcpcd[384]: wlan0: adding address fe80::c564:f0e5:bab8:c32
Nov  3 11:49:05 docker4 dhcpcd[384]: wlan0: carrier lost
Nov  3 11:49:05 docker4 dhcpcd[384]: wlan0: deleting address fe80::c564:f0e5:bab8:c32
Nov  3 11:49:07 docker4 dhcpcd[384]: wlan0: new hardware address: c6:db:7e:ff:79:b0
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: carrier acquired
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: IAID 7e:ff:79:b0
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: adding address fe80::e53e:9146:3af:509b
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: carrier lost
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: deleting address fe80::e53e:9146:3af:509b
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: rebinding lease of 172.29.12.137
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: NAK: address in use from 172.29.12.1
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: message: address in use
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: soliciting an IPv6 router
Nov  3 11:49:12 docker4 dhcpcd[384]: wlan0: soliciting a DHCP lease
Nov  3 11:49:16 docker4 dhcpcd[384]: wlan0: offered 172.29.12.162 from 172.29.12.1
Nov  3 11:49:16 docker4 dhcpcd[384]: wlan0: probing address 172.29.12.162/24
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: carrier lost
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: carrier acquired
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: IAID 7e:ff:79:b0
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: adding address fe80::e53e:9146:3af:509b
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: deleting address fe80::e53e:9146:3af:509b
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: soliciting a DHCP lease
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: offered 172.29.12.162 from 172.29.12.1
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: soliciting an IPv6 router
Nov  3 11:49:17 docker4 dhcpcd[384]: wlan0: probing address 172.29.12.162/24
Nov  3 11:49:23 docker4 dhcpcd[384]: wlan0: leased 172.29.12.162 for 300 seconds
Nov  3 11:49:23 docker4 dhcpcd[384]: wlan0: adding route to 172.29.12.0/24
Nov  3 11:49:23 docker4 dhcpcd[384]: wlan0: adding default route via 172.29.12.1
Nov  3 11:49:23 docker4 dhcpcd[384]: forked to background, child pid 593
The system was previously running jessie, so I might try re-flashing with jessie to see if the behaviour is restricted to stretch.
B.Goode
Sun Nov 03, 2019 12:34 pm
The last time I recall this being discussed it was traced to HASSIO being installed on top of Raspbian, and Hassio in turn installs Network Manager which was thought to be the cause of the non-standard behaviour.
So although you are starting with a 'stock' OS, have you added anything?
And if you have got to reinstall the Raspbian Operating System, why not move forward to the Raspbian Buster release which has been the recommended and supported version for over 4 months?
How, if at all, does Docker feature in your configuration?
jj_0
Sun Nov 03, 2019 12:46 pm
For reference, see here for the fix for NetworkManager, in case you have that installed.
Guff666
Sun Nov 03, 2019 3:56 pm
Now that is interesting. Previously, this node was running hassos/hassio. The reason for the rebuild is to be able to run hassio_supervisor etc on top of docker on raspbian, rather than on top of hassos. I need this as I want to add a UPS hat and hassos has no drivers for it. Also, I am used to docker commands rather than the abbreviated hassos set. However, despite the coincidence, the node is running just the basic raspbian with no additions yet. Your caution does give me a concern though. I'll try to find previous threads on this issue.
As an aside, I'm pursuing this problem because whenever i tried to do a `docker pull`, it failed with "Could not reach any registry servers". I tracked this down to being due to unsymmetrical routes on the USG because of the frequent IP address changes. I then rebuilt with pure stretch and the problem persisted.
In the end I deferred the downgrade to jessie (I couldn't find an IMG that would boot) in favour of reinstalling stretch and removing the static address allocation on the USG. NB: I stayed with stretch because buster wasn't fully supported for home assistant last time I checked.
Clearing the static allocation seems to have cured the problem. The node seems to be stable now (30 mins).
NB: I have now checked again and hassio etc seem to be supported, so I'll have a go with buster.
bls
Contact: Twitter
Thu Nov 14, 2019 8:55 pm
I was curious to see how KDE performed on the Pi4, so I installed it. Each time I rebooted the Pi, the MAC address changed. When I rebooted with a non-KDE system, the MAC address reverted to the one on the system.
It would be interesting to know if anyone seeing a changing MAC address is using KDE or some other heavyweight windowing system that apparently mucks where it shouuld't be mucking (IMHO).
Super-useful tools:
RPi SD Card Image Manager: https://github.com/gitbls/sdm
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
Easy-Peasy VPN installer/manager: https://github.com/gitbls/pistrong
Guff666
Fri Nov 15, 2019 9:53 am
I got to the bottom of the problem. My installation, (and I think, buster by default) had network-manager installed. Network-manager gets the IP address instead of dhcpcd and network-manager can be set to randomise the MAC address when it boots. This is a security “feature”, but it obviously screws with statically-allocated IP addresses.
The documentation is confusing about how to stop this behaviour (it’s not supposed to be the default anyway). My solution was to simply remove network-manager.
svs.smol
Sat Nov 16, 2019 10:40 pm
If Network-manager is installed.
To disable the MAC address randomization create the file:
/etc/NetworkManager/conf.d/100-disable-wifi-mac-randomization.conf
And add:
[connection]
wifi.mac-address-randomization=1
[device]
wifi.scan-rand-mac-address=no
AskePetter
Wed Mar 11, 2020 3:11 pm
And add:
[connection]
[device]
The method described above solved my problems. I was on a Pi 4 Running Hassio on top of Docker, on top of Raspbian Buster, and I saw the same whirlwind of MAC addresses but this seems to have cured it! Big thanks to user sms.smol! :D
ob2s
Fri Mar 13, 2020 2:54 am
I tried this, rebooted my router and the pi, but the allocations persist. I guess I can live with 5 less dhcp addresses, but it IS annoying.
panec
Sun Mar 15, 2020 9:21 pm
In my case this helped:
Network-Manager will reset your mac address during the wifi scanning.
To permanently change your mac address:
Edit your /etc/NetworkManager/NetworkManager.conf as follows:
[device]
Reboot and verify your settings.
Got from https://community.home-assistant.io/t/t ... 38?u=panec
