Re: Raspberry Pi 4 usb boot?
Thu Oct 31, 2019 10:57 am
LTolledo wrote:
Thu Oct 31, 2019 10:17 am
Hey!
Glad you two finally achieved your "interim goal" without further "pain" and "frustrations"... :D
our thanks to RonR for lovingly maintaining and updating the script....
....and of course ..... lets be a little more patient until the procedure for the "ultimate goal" is available....in due time..... ;)
Bootloader guy is now working fully on USB boot. No timescales as yet.
Thu Oct 31, 2019 11:21 am
Good to hear. I'll be glad when I can get my Pi 4B4 booting from its SSD :)
But I'm prepared to wait.
Unreadable squiggle
LTolledo
Thu Oct 31, 2019 11:52 am
jamesh wrote: Bootloader guy is now working fully on USB boot. No timescales as yet.
Great news! :o
Thanks! (and most specially to the Bootloader guy/team) :D
me in no rush too.... :mrgreen:
all systems running fine at the moment.... ;)
Some people be like:
RossDv8
Wed Nov 06, 2019 1:17 am
After my experience when I changed to the bootable SSD on my Pi 3B+, I think the only real advantage I will have when this facility is added to the Pi 4, is that loading pictures from my digital camera will not tie up a USB 3 port :-)
It is great that the Raspberry Pi is so flexible and the team so dedicated.
I haven't turned on another of my computers for two weeks now other than to print something, or simply to boot one of the computers, any of which performs an auto clean of my inkjet printers on boot.
On the odd occasions when I had another computer running, I am surprised by how sluggish the more powerful computers are compared with the Pi 4, when doing the mundane tasks like browsing or word processing now that the Pi 4 is running on SSD.
I understand that the boot system differs from that in the Pi 3B+.
Is it likely that the behaviour will end up being similar to that of the Pi 3B+? Once SSD boot is enabled, if the Pi detects a bootable microSD, it will default to booting from that, but of there is a non-bootable microSD, it will just mount it as storage?
Remember, nobody is listening to you
until you fart ...
Wed Nov 06, 2019 9:37 am
As the Pi 4B has an eeprom with the initial bootcode in, I suspect at some point the boot order will be configurable.
Unreadable squiggle
Gavinmc42
Thu Nov 07, 2019 2:09 am
That would be nice, the uSD timeout adds seconds when booting from USB.
Is that also going to be an option for netbooting?
I'm dancing on Rainbows.
andrum99
Thu Nov 07, 2019 2:37 am
The boot order is already configurable, for the beta bootloader with netboot built in:
BOOT_ORDER=0x21
will try SD card first, then netboot. Whereas:
BOOT_ORDER=0x12
Will try netboot, then SD card. Alternatively:
BOOT_ORDER=0x1
will try SD card only. And:
BOOT_ORDER=0x2
will try netboot only.
There's also SD_BOOT_MAX_RETRIES and NET_BOOT_MAX_RETRIES to configure things.
See https://github.com/raspberrypi/rpi-eepr ... ot_beta.md
Presumably when USB boot arrives it will be 0x4, but that's just a guess.
andrum99
Thu Nov 07, 2019 2:43 am
I'm now picturing someone with "bootloader guy" on their T-shirt :D
I may have taken that too far.
Gavinmc42
Thu Nov 07, 2019 2:59 am
Depends on how long he takes ;)
Could be free beers or boos if he shows up wearing that T shirt :lol:
Sounds like netbooting is now worth playing around with, had not been paying enough attention.
andrum99
Fri Nov 08, 2019 11:37 am
It's only available on the beta firmware - see the above linked github repo for details.
Gavinmc42
Sat Nov 09, 2019 1:32 am
Yep, understood, rpi-eeprom-update.
Now if only I had a USB booting PI4 I could use as a server to test the net booting ones ;)
Not sure who wrote the code for the Pi3 USB boot but it works well with my USB3/SSD dock.
Give them a few beers.
Same dock will halt my Pi4 when it boots from an uSD, it continues when I unplug.
Anyway, looks like my netboot testing will need to use a Pi3 with SSD at the moment.
USB3/SATA dock details, is it a quirky one?
[ 2433.589953] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 2433.611671] usb 2-1: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 1.00
[ 2433.611682] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2433.611687] usb 2-1: Product: USB3.0 HDD DOCK
[ 2433.611691] usb 2-1: Manufacturer: JMicron
[ 2433.611696] usb 2-1: SerialNumber: 0000AB123519
[ 2433.635627] scsi host0: uas
[ 2433.636911] scsi 0:0:0:0: Direct-Access     Crucial_ CT240M500SSD1    8101 PQ: 0 ANSI: 6
[ 2433.639059] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[ 2433.639068] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2433.639339] sd 0:0:0:0: [sda] Write Protect is off
[ 2433.639345] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
[ 2433.639869] sd 0:0:0:0: [sda] Disabling FUA
[ 2433.639876] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2433.640728] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
jj_0
Sun Nov 10, 2019 10:07 am
The reboot problem is likely due to power backfeed from your USB3/SSD dock to the Pi's USB3 port - assuming you power it externally of course. The easiest way to fix that is to connect it via an USB3 hub that does not backfeed power to the USB3 port. The hard part is finding such a USB3 hub. The TP-Link UH400 and UH700 USB3 hubs work for me. Another way to fix it is to use an USB3 cable with the 5V wire cut.
As to needing quirks, the best way to find out is to do some tests, if you get 'uas' error messages in the log when copying large files to the SSD then you need to disable uas or maybe upgrade the firmware (at your own risk).
mahjongg
Sun Nov 10, 2019 2:21 pm
If the boot-loader will be revised, will it be able to boot from an exFAT partition? All previous RPI boot system were only capable of booting from a FAT32 partition, but with larger than 32GB SD-Cards getting cheaper all the time more and more cards will be formatted exFAT. I know that many people no longer use NOOBS, but wouldn't it be nice if exFAT booting could be implemented?
if booting from exFAT means we need to pay MS licences, then forget that I asked.
Sun Nov 10, 2019 2:26 pm
Microsoft have open source'd FAT and exFAT. No fees required.
trejan
Sun Nov 10, 2019 3:34 pm
It'll be the cost of writing an exFAT module for the VPU from scratch. The one in the Linux kernel can't be used as it is GPL. The initial patch for it was nearly 11,000 lines so it is a lot more complicated than FAT.
dickon
Sun Nov 10, 2019 3:55 pm
Two minutes of Googling found http://elm-chan.org/fsw/ff/00index_e.html which looks as if it'll do the trick, isn't GPL, and looks to be current. Bonus: designed for embedded systems, so minimally RO compiles to ~4k ARMv7, and requires a trivial set of IO primitives.
I'm sure there will be others out there. No need to write from scratch.
trejan
Sun Nov 10, 2019 4:11 pm
Ah nice. I didn't know FatFs had been updated. I've used it before in a microcontroller and its a very handy library.
ShiftPlusOne
Mon Nov 11, 2019 2:01 pm
AFAIK, there are no plans to support exFAT.
PeterO
Mon Nov 11, 2019 3:50 pm
Surely the size of the SD card it irrelevant ? It's only the size of the boot partition that matters, and since that is quite small there is no need to support exFAT.
PeterO
procount
Mon Nov 11, 2019 4:32 pm
Surely the size of the SD card is irrelevant ? It's only the size of the boot partition that matters, and since that is quite small there is no need to support exFAT.
This is very true.
However, the instructions for NOOBS (since it was written when SD cards were all relatively small) state: "Format an SD card that is 8GB or greater in size as FAT32", which was ok when cards were small, but can cause issues now with SD cards >=64GB, as we know.
Actually, NOOBS only requires the first partition to be formatted as FAT32, and this need only be big enough to hold the NOOBS installation files. So you are absolutely right, but creating an initial boot partition of the correct size and then formatting it as FAT32 suddenly becomes a none-newbie experience.
Now that Etcher is available, my solution was to create an Etcher image for pinn-lite, which makes it as easy to install as any other OS, and avoids all the issues of large SD cards, special FAT32 formatting tools, and issues with SD cards not being partitioned properly with an MBR.
PeterO
Mon Nov 11, 2019 5:48 pm
Ah, I had missed the NOOBS angle. I've never used it so I don't know how it works.
PeterO
vintozver
Mon Nov 11, 2019 11:50 pm
I don't see the point. boot partition is for boot. Just slice out the partition of the size you need.
I would rather ask for the GPT support ...
trejan
Tue Nov 12, 2019 1:11 am
As procount mentioned above, it would be a good addition for NOOBS which is installed by extracting the contents of the zip into a FAT32 formatted SD card. The FAT32 requirement means needing to run a third party formatting tool which isn't very noob friendly.
procount
Tue Nov 12, 2019 8:49 am
Sorry, I may not have been clear in my opinion.
I am not advocating adding exFAT as a boot option.
I was trying to point out WHY current instructions for installing NOOBS might make people think exFAT would be necessary now that large SD cards >= 64GB are more common.
But in fact, this is not needed. There are a couple of alternative options:
1. The noobs instructions could be modified to create a small recovery partition which can then be formatted as FAT32, instead of formatting the whole SD card. But this is not very newbie friendly, which is what NOOBS was all about.
2. Now that Etcher is here which makes writing images as easy as formatting/unzipping for newbies, NOOBS could be provided as an alternative image file, like pinn-lite.img.zip is.
Actually, requiring the whole SD card to be formatted as FAT32 first for NOOBS is wasteful in both time and SD writes, contributing to additional wear.
So NOOBS requirements can be made the same as any other OS (i.e. a small FAT32 partition). I think this is preferable to adding a load of exFAT bloat to the bootloader, which I'm sure RPF engineers won't be doing.
jj_0
Tue Nov 12, 2019 9:40 am
Yes, but at the moment Etcher is only installable on the Pi by getting the .deb package directly for @futurejones's github. This is also not easy for noobs. It might be easier if in addition of providing an image file the NOOBS instructions included installing gnome-disks. The benefit of this is that gnome-disks is part of the Raspbian distribution so can be installed via apt or via 'Add/ Remove Software' and also is maintained/updated.
