The webpages (https://projects.raspberrypi.org/en/projects/rock-band) have git repos (https://github.com/RaspberryPiLearning/rock-band) but what software is used to compile the styles and content into html?
Anyone know? Has this been asked before maybe?
Re: what e-learning software does the foundation use to compile its webpages?
This was asked before, see the below link for the answer.
https://www.raspberrypi.org/forums/view ... 70#p773773
Things may have changed since then. Could be Sphinx as used by one of the Raspberry Pi projects
https://projects.raspberrypi.org/en/pro ... -your-code
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
@scotty101 suggested topic cover your problem.
you can also use opensource and freemium LMS software...
https://classroom.google.com
https://www.blackboard.com/blackboard-open-lms
https://www.edusys.co/en-in/lms-software.html
https://www.onenote.com
https://moodle.org/
https://evernote.com/
What is LMS?
A learning management system is a software application for the administration, documentation, tracking, reporting, and delivery of educational courses, training programs, or learning and development programs. read more https://en.wikipedia.org/wiki/Learning_ ... ent_system
https://moodle.org/
What is LMS?
And Moodle runs even on RPi: https://moodlebox.net/.
Maintainer of MoodleBox, a Moodle server on Raspberry Pi
Yes, and on rPi4-4 the efficiency will further increase . Hope the Moodle experience on Ubuntu 19.10,rPi4-4, will encourage the emergence of a 'rPi4-4 MoodleBox'
- Attachments
- moodle_7.2_rPi4-4.jpg (139.28 KiB) Viewed 3700 times
FYI, MoodleBox already works on RPi4: https://moodlebox.net/en/news/version-3.0.0/.
Brilliant, everything works '100% out of box' on rPi4-4.mina wrote: ↑Sat Nov 09, 2019 3:53 pm...
login as: moodlebox
moodlebox@192.168.1.136's password:
Linux moodlebox 4.19.66-v7l+ #1253 SMP Thu Aug 15 12:02:08 BST 2019 armv7l
This is MoodleBox version 3.1.0, 2019-08-23.
MoodleBox is made by Nicolas Martignoni, https://github.com/martignoni/.
Please read the documentation at https://moodlebox.net/.
Last login: Sat Nov 9 20:33:19 2019 from 192.168.1.75
moodlebox@moodlebox:~ $ neofetch
`.::///+:/-. --///+//-:`` moodlebox@moodlebox
`+oooooooooooo: `+oooooooooooo: -------------------
/oooo++//ooooo: ooooo+//+ooooo. OS: Raspbian GNU/Linux 10 (buster) armv7l
`+ooooooo:-:oo- +o+::/ooooooo: Host: Raspberry Pi 4 Model B Rev 1.1
`:oooooooo+`` `.oooooooo+- Kernel: 4.19.66-v7l+
`:++ooo/. :+ooo+/.` Uptime: 20 mins
...` `.----.` ``.. Packages: 603 (dpkg)
.::::-``:::::::::.`-:::-` Shell: bash 5.0.3
-:::-` .:::::::-` `-:::- Terminal: /dev/pts/0
`::. `.--.` `` `.---.``.::` CPU: BCM2835 (4) @ 1.500GHz
.::::::::` -::::::::` ` Memory: 312MiB / 3955MiB
php not 64 bits
if this test fails, it indicates a potential problem
It has been detected that your site is not using a 64-bit PHP version. It is recommended that you upgrade your site to ensure future compatibility
Moodle 3.8 will be part of next release of MoodleBox. See https://github.com/moodlebox/moodlebox/issues/156.geev03 wrote: ↑Sat Nov 09, 2019 8:47 pmSoon to be released ,Moodle 3.8 with. integrated H5P https://docs.moodle.org/dev/H5P is an opportunity to take the next MoodleBox to another level of usability.
This will go away when Raspbian image is totally 64-bit. In any case, it has absolutely no impact on MoodleBox usage or performance, apart the display of this warning. So, not a big deal.geev03 wrote: ↑Sat Nov 09, 2019 8:47 pmCode: Select all
php not 64 bits if this test fails, it indicates a potential problem It has been detected that your site is not using a 64-bit PHP version. It is recommended that you upgrade your site to ensure future compatibility
It seems there is an LMS known as Moodle that will run on an RPi.
But the question was:
