The new image is available fromApart from 3B+ support (including firmware files for the new wifi chip), this update should make some improvement on all Pi models: slightly faster usb and ethernet, corrections for a few very old Plan 9 bugs flushed out by the Go test suite, and some extra crypto support for better interoperability with modern hosts using ssh and hget.
https://9p.io/sources/contrib/miller/9pi.img.gz
Hardly any plan9 users checks this forum so if you plan to use plan9, you may wish to join the 9fans mailing list. See https://9p.io/wiki/plan9/mailing_lists/.
