imfuraisoth
Re: STICKY: Setting up HDMI output when video output is wrong.
Mon Aug 05, 2019 10:08 pm
I'm trying to get my pi4 to output in standard def resolution and I'm only seeing 1920x1080 on my monitor. My goal is to out put video for my Sega Blast City monitor and when I try to hook it up to the monitor, the image is split 3 ways and compressed. I was told it is probably due to the output still being in HD instead of SD. I've tried to modify the config.txt file for standard def. I've tried all sorts of settings and nothing seems to work. Has anyone else successfully connected their Pi to an actual arcade monitor? If so, what settings did you use? Was it a pi 4 or 3 and below?
The image looks fine on my standard PC LCD 23" monitor. Only when it's hooked up to the cab, it's all skewed.
CodeCage
Tue Sep 03, 2019 2:19 pm
Here are the settings I had to use on a Vizio D32hn-D0 to get a display from my RasPi 4"
hdmi_ignore_edid=0xa5000080
hdmi_group=1
hdmi_mode=16
And while all of this re-configuring of these videos parameters is way over the head of most newbies, they'll sure learn a lot by sticking with it and getting their monitor working with there RasPi 4!
TD540
Sat Sep 07, 2019 6:20 am
Got this 4K display here: the LG 27UK850-W
Added
hdmi_enable_4kp60=1
to the Pi4's config.txt
But the highest resolution I get is 2560x1440 at 59.95Hz frequency
the display should be able to handle 3840x2160 at 60Hz ...
after trying to switch HDMI-1's resolution to 3840x2160, the screen goes dark and shows a "no-signal" message. Then after 10 seconds, the pi switches back to 2560x1440.
snIP3r23
Sun Sep 08, 2019 11:48 am
Hi all!
I am tgrying to get my Sony TV working with my Rasp Pi4 4GB together with the new RaspEX Build 190807. I allways get an Unsupported Signal Messsage on my TV.
I use this config.txt:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
# hdmi_mode=2
## exton change
hdmi_drive=2
## end exton change
#sniper20190829
hdmi_pixel_encoding=1
hdmi_mode=16
#hdmi_edid_file=1
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=11
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
But i am confused about the output of some commands. I get this after boot:
root@raspberry:~# /opt/vc/bin/tvservice -s
state 0xa [HDMI CUSTOM RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
And if i use the following command i get this - and also no output:
root@raspberry:~# /opt/vc/bin/tvservice -p
Powering on HDMI with preferred settings
state 0xa [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
My edit.dat shows me this:
root@raspberry:~# /opt/vc/bin/edidparser edid.dat
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 71x40 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is SONY_TV
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 48-62 Hz, horizontal is 14-70 kHz, max pixel clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID established timing I/II bytes are 21 08 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x8180 A9C0 714F B300 0101 0101 0101 0101
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 0
HDMI:EDID found DMT format: code 83, 1600x900p @ 60 Hz (16:9) in standard timing 1
HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 2
HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 3
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:0
HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
HDMI:EDID found CEA format: code 60, 1280x720p @ 24Hz
HDMI:EDID found CEA format: code 62, 1280x720p @ 30Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found audio format 6 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 6 channels AC3, sample rate: 32|44|48 kHz, bitrate: 640 kbps
HDMI:EDID found HDMI VSDB length 8
HDMI:EDID HDMI VSDB has physical address 4.0.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
HDMI:EDID HDMI VSDB content type support: game|cinema|photo|text
HDMI:EDID found Video Capability DB length 2
HDMI:EDID video capability: CE:3 IT:2 PT:3 QS:3
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 66472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 4635592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 3273832
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 28800
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 5398248)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3617160
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 2732360
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (21) 1152x864p @ 75 Hz with pixel clock 108 MHz has a score of 99649
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 4232360
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 124532
HDMI:EDID CEA mode (34) 1920x1080p @ 30 Hz with pixel clock 74 MHz has a score of 149416
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 103643
HDMI:EDID DMT mode (58) 1680x1050p @ 60 Hz with pixel clock 146 MHz has a score of 130840
HDMI:EDID filtering out CEA format: 1280x720p @ 24 Hz (60) with pixel clock 59 MHz and hfp:1760 hs:40 hbp:220
HDMI:EDID filtering out CEA format: 1280x720p @ 30 Hz (62) with pixel clock 74 MHz and hfp:1760 hs:40 hbp:220
HDMI:EDID DMT mode (83) 1600x900p @ 60 Hz with pixel clock 108 MHz has a score of 111400
HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
HDMI:EDID has HDMI support and audio support
/opt/vc/bin/edidparser exited with code 0
What am i doing wrong???
Thx for help in advance
snIP3r
FTrevorGowen
Sun Sep 08, 2019 12:29 pm
Hi all!
#hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
hdmi_group=1
# hdmi_mode=2
## exton change
hdmi_drive=2
## end exton change
#sniper20190829
hdmi_mode=16
#hdmi_edid_file=1
# no display
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=on
[pi4]
max_framebuffers=2
[all]
Parsing edid.dat...
snIP3r
What is "RaspEX Build 190807"?
What does tvservice -m CEA report?
If "RaspEX Build 190807"" is not (equivalent to) current Raspbian Buster try that instead and report back. Also, for Buster, and since my TV possibly has similar capabilities to yours you may find these recent notes of interest: http://www.cpmspectrepi.uk/raspberry_pi ... erP4B.html - in particular your config.txt seems to have had least one inappropriate entry (in the [all] section).
Trev.
ravio_the_unlikely
Thu Sep 12, 2019 7:34 am
indri wrote:
Tue Jul 16, 2019 7:33 am
I'm trying to configure the rpi4 to work with a BenQ_EW2770QZ monitor in native resolution (2560x1440), so far no luck.
has anyone managed to get 1440p on a 27" monitor?
I have already tried here https://github.com/raspberrypi/firmware/issues/1181 for help.
Edit: solved with xrandr (arch wiki)
Please post your solution.
trantuong
Mon Sep 16, 2019 5:06 pm
I have problem with RP4.
RP4 can not display on LG 29wk600. It is always show "no signal" . How can i fix this problem ?
Please help me !!! Thanks
Lucifer22334
Mon Sep 23, 2019 1:19 pm
Hi all,
My HDMI monitor falls off in this category HDMI group= 1 and HDMI mode = 16. I tested it with the command given above but still, it doesn't give output on the HDMI monitor. I have checked my HDMI monitor conf and it is 1080p/1920x1080 Hz. When I changed in config.txt it stopped ssh also. Please help...
jakorten
Sat Oct 12, 2019 7:08 am
Yesterday I got an Asus VT168 monitor (with touch).
The monitor has two inputs: HDMI and VGA.
Through HDMI (both Pi 4 ports) it is not recognized by the Pi 4, even though the Pi 3 (with the same SD card) has no problems with connecting it straight HDMI to HDMI.
I then tried the VGA port (using a VGA - HDMI cable): that works well, even with the recommended somewhat strange resolution of 1366x768 @59.79Hz.
I use Buster (10). Any help appreciated on how to get it also working using HDMI.
Note: the touch part does work out of the box at both the Pi 3 and Pi 4 so while I would really like to only use HDMI - HDMI it is a great working solution in the end having a touch screen on the Pi for a little over 100€.
Update:
I now also got HDMI output by enabling:
hdmi_safe=1
config_hdmi_boost=4
It does not work with 1366x768 yet but does with 1024x768.
Update 2:
I ended up using 1920x1080p, seems to work ok. Everything is a little small but at least touch and the screen are in synch and it properly fills my entire screen etc through HDMI. I could always fall back to VGA of course. (This post helped me understand setting display modes better: viewtopic.php?t=249045)
Update 3:
Because of some other software I updated Raspbian. Now it does accept 1366x768 but it does now have an 'underscan' issue.
Is (re)solved it, now it works perfectly!!!
Disabled hdmi_safe again (was solved in the update apparently):
#hdmi_safe=1
disable_overscan=0
Fiddled around with overscan_ borders:
overscan_left=15
overscan_right=10
overscan_top=8
overscan_bottom=5
framebuffer_width=1366
framebuffer_height=768
hdmi_force_mode=1
hdmi_group=2
hdmi_mode=81
hdmi_drive=1
config_hdmi_boost=2
Update 4:
Works with:
disable_overscan=1
hdmi_force_mode=1
hdmi_drive=1
config_hdmi_boost=2
dtparam=audio=on
[pi4]
max_framebuffers=2
GreenPi
Thu Oct 31, 2019 2:57 am
Brand new Pi owner here. I have linux experience but mostly my use case was working out of the box and not doing a lot of trouble shooting. I read the forums and saw some of the requested items. See below.
I've had it now for about two weeks. I use it as a Desktop more than anything else. I have self loaded Rasberrian onto the SD card. I'm running XFCE4 desktop. I am experiencing some performance issues with video's. I simply turned on dtoverlay=vc4-fkms-v3d to get my monitor working properly. So I am seeking some advise for tuning my graphics card and monitors to see if I can hopefully stop the studdering.
I have run rpi-update on my Pi and I am using the newer firmware.
Config.txt
#hdmi_safe=1
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=16
#hdmi_drive=2
# no display
#config_hdmi_boost=4
#sdtv_mode=2
over_voltage=6
arm_freq=1750
gpu_mem=512
gpu_feq=600
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
dtparam=audio=on
[pi4]
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
./tvservice -m DMT
Group DMT has 10 modes:
           mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
           mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
           mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
           mode 32: 1280x960 @ 60Hz 4:3, clock:108MHz progressive
           mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
           mode 42: 1400x1050 @ 60Hz 4:3, clock:121MHz progressive
           mode 47: 1440x900 @ 60Hz 16:10, clock:106MHz progressive
           mode 82: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
           mode 83: 1600x900 @ 60Hz 16:9, clock:108MHz progressive
           mode 85: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
./tvservice -m CEA
Group CEA has 9 modes:
           mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
           mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
           mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
           mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
  (prefer) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
           mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
           mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
           mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
           mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
 ./tvservice -s
state 0xa [HDMI CUSTOM RGB full 16:9], 1920x1080 @ 60.00Hz, progressive
tvDump
didparser tvDump
Parsing tvDump...
HDMI:EDID version 1.3, 1 extensions, screen size 30x26 cm
HDMI:EDID features - videodef 0x80 standby suspend active off; colour encoding:RGB444|YCbCr444|YCbCr422; sRGB is default colourspace; preferred format is native; does not support GTF
HDMI:EDID monitor name is HS156PC
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID monitor range: vertical is 48-75 Hz, horizontal is 35-94 kHz, max pixel clock is 200 MHz
HDMI:EDID standard timings block x 8: 0xD1C0 D1C0 A9C0 9500 9040 8180 8140 81C0
HDMI:EDID found DMT format: code 82, 1920x1080p @ 60 Hz (16:9) in standard timing 0
HDMI:EDID found DMT format: code 82, 1920x1080p @ 60 Hz (16:9) in standard timing 1
HDMI:EDID found DMT format: code 83, 1600x900p @ 60 Hz (16:9) in standard timing 2
HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 3
HDMI:EDID found DMT format: code 42, 1400x1050p @ 60 Hz (4:3) in standard timing 4
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 5
HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 6
HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 7
HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found DMT detail timing format: 1920x1080p @ 60 Hz (82)
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
HDMI:EDID found HDMI VSDB length 7
HDMI:EDID HDMI VSDB has physical address 1.0.0.0
HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
HDMI:EDID HDMI VSDB max TMDS clock 340 MHz
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID ignoring non HDMI VSDB with IEEE reg 0xc45dd8
HDMI:EDID ignoring non HDMI VSDB with IEEE reg 0x00001a
HDMI:EDID extended data block YCbCr420CapMap - length 5
HDMI:EDID extended data block tag 0x05 length 3 not supported
HDMI:EDID video capability: CE:3 IT:3 PT:3 QS:3
HDMI:EDID extended data block tag 0x06 length 6 not supported
HDMI:EDID adding mandatory support for CEA (3) 720x480p @ 60Hz
HDMI:EDID adding mandatory support for CEA (17) 720x576p @ 50Hz
HDMI:EDID adding mandatory support for CEA (18) 720x576p @ 50Hz
HDMI:EDID adding mandatory support for CEA (19) 1280x720p @ 50Hz
HDMI:EDID filtering formats with pixel clock unlimited MHz or h. blanking unlimited
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 135592)
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 117160
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 232360
HDMI:EDID DMT mode (32) 1280x960p @ 60 Hz with pixel clock 108 MHz has a score of 98728
HDMI:EDID DMT mode (42) 1400x1050p @ 60 Hz with pixel clock 121 MHz has a score of 113200
HDMI:EDID DMT mode (47) 1440x900p @ 60 Hz with pixel clock 106 MHz has a score of 102760
HDMI:EDID DMT mode (82) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 4649416
HDMI:EDID DMT mode (85) 1280x720p @ 60 Hz with pixel clock 74 MHz has a score of 80296
HDMI0:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
GreenPi
marcinq
Wed Nov 06, 2019 9:34 pm
I'm having an issue with 4B and custom DMT mode. I've got a VGA display that has a resolution of 400x240 15:9. It worked perfectly with RasPi Zero W and a HDMI to VGA converter with the following settings:
        hdmi_cvt=400 240 60 6 0 0 0
        hdmi_group=2
        hdmi_mode=87
        hdmi_drive=2
Now when I put those settings into config.txt of 4B I get scrolling lines across the screen. Clearly something wrong with the 4B display driver?? Even the startup rainbow is distorted and split into many horizontal lines at an angle.
tvservice on the 4B reports this:
state 0xa [HDMI DMT (87) RGB full 15:9 x4], 400x240 @ 57.00Hz, progressive
So in theory it should work, but it doesn't.
Is group2, mode87 broken on 4B?
UPDATE:
Just checked what does the TV SERVICE report on my Zero:
state 0xa [HDMI DMT (87) RGB full 16:9 x4], 400x240 @ 58.00Hz, progressive
Therefore there is a 1Hz difference in the refresh rate and the monitor might not like that. What clock is this dependent on and can it be changed (ideally it should be 60Hz).
viktor_sc
Thu Nov 07, 2019 10:08 pm
Update 3:
#hdmi_safe=1
disable_overscan=0
overscan_left=15
overscan_right=10
overscan_top=8
overscan_bottom=5
hdmi_force_mode=1
hdmi_group=2
hdmi_mode=81
hdmi_drive=1
config_hdmi_boost=2
I have the same screen and the same issue. Thanks to your post I could get it working. Actually, just the setting hdmi_drive=1 is enough in my case. This switches it to DVI mode.
However, my sound doesn't work whit this setting. It worked on the previous RPI3 with the monitor through HDMI and then a speaker connected to the monitor. Now there's no sound regardless where I connect the speaker to (RPI directly or monitor).
Any ideas here?
Thanks,
Viktor
marcinq
Fri Nov 08, 2019 12:57 pm
As you have switched your HDMI output to DVI mode you will not get sound as DVI does not carry sound. Sound output is only possible with HDMI output mode.
Fri Nov 08, 2019 2:14 pm
hdmi_drive=2 should enable sound even when working in DVI mode.
Unreadable squiggle
viktor_sc
Sun Nov 10, 2019 12:14 pm
I understand that DVI doesn't carry sound and that it won't work through the HDMI cable.
My problem is that it doesn't even work on the sound output directly at the Raspi...
johnsmith101
Re: Setting up HDMI output
Mon Dec 30, 2019 2:27 pm
JollyRoger wrote:
Tue Jun 19, 2012 6:26 am
For folks who have had problems getting their TV to recognise input from the Pi (and for the Pi to work with the TV), I have found after much experimentation that the order in which you power up is crucial. I am using a Matsui 19" TV (from Dixons/Curry, model no M19LID618), and for this TV the power-up sequence has to be:
1 Switch on the TV at the mains so that it is in Standby mode
2 Power up the Pi
3 Turn on the TV and switch to HDMI mode.
My config.txt file for this TV (after many tries) is:
hdmi_mode=4
overscan_top=-32
overscan_bottom=-32
overscan_left=-56
overscan_right=-56
I hope this helps.
thank u so much.. my issue has been resolved now..:) tubemate authorityapk.com get-mobdro.com
vnunnari
Thu Jan 09, 2020 3:26 pm
Hi dudes,
I got both PI3B+ and now the PI4 4Go.
I bought a small LCD Screen for a PI project (10 inch).
This Screen works well with PI3B+ using RECALBOX OS
But black screen blinking every 4sec on the PI4 4Go with RASPBIAN BUSTER
My PI4 boots well and i can connect to it via SSH.
So i changed the /boot/config.txt many time but nothing works.
I tryed to connect my PI4 4Go on a standard HDMI desktop screen and also on my samsung TV: working well
I tryed to comment ALL LINES then just let this one:
hdmi_safe = 1
-> does not work
I tryed the EDID preferred mode : CEA (17)
-> still doesn't work
I updated all firmwares on the PI4 4Go:
> Are any fixes currently under développement?
> May another OS like NOOBS solve that issue?
Boring PI4 :cry:
Here is EDID File:
Parsing monitorEDID...
HDMI:EDID version 1.3, 1 extensions, screen size 47x26 cm
HDMI:EDID features - videodef 0x81 !standby !suspend active off; colour encoding:RGB444|YCbCr444|YCbCr422; sRGB is default colourspace; preferred format is native; does not support GTF
HDMI:EDID monitor range: vertical is 56-75 Hz, horizontal is 30-83 kHz, max pixel clock is 210 MHz
HDMI:EDID monitor name is HDMI
HDMI:EDID failed to find a matching detail format for 1024x600p hfp:44 hs:88 hbp:188 vfp:3 vs:6 vbp:16 pixel clock:50 MHz
HDMI:EDID calculated refresh rate is 60 Hz
HDMI:EDID guessing the format to be 1024x600p @60 Hz
HDMI:EDID found unknown detail timing format: 1024x600p hfp:44 hs:88 hbp:188 vfp:3 vs:6 vbp:16 pixel clock:50 MHz
HDMI:EDID established timing I/II bytes are AF EF 00
HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found preferred CEA detail timing format: 720x576p @ 50 Hz (17)
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz (native)
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
HDMI:EDID found HDMI VSDB length 5
HDMI:EDID HDMI VSDB has no extension fields
HDMI:EDID adding mandatory support for CEA (1) 640x480p @ 60Hz
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 4773832)
HDMI:EDID DMT mode (5) 640x480p @ 72 Hz with pixel clock 31 MHz has a score of 5529
HDMI:EDID DMT mode (6) 640x480p @ 75 Hz with pixel clock 31 MHz has a score of 5760
HDMI:EDID DMT mode (8) 800x600p @ 56 Hz with pixel clock 36 MHz has a score of 26880
HDMI:EDID DMT mode (10) 800x600p @ 72 Hz with pixel clock 50 MHz has a score of 8640
HDMI:EDID DMT mode (11) 800x600p @ 75 Hz with pixel clock 49 MHz has a score of 9000
HDMI:EDID CEA mode (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 398248
HDMI:EDID best score mode is now CEA (17) 720x576p @ 50 Hz with pixel clock 27 MHz (score 5087208)
HDMI:EDID DMT mode (17) 1024x768p @ 70 Hz with pixel clock 75 MHz has a score of 13762
HDMI:EDID DMT mode (18) 1024x768p @ 75 Hz with pixel clock 78 MHz has a score of 14745
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 4232360
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 56104
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 3232360
HDMI:EDID DMT mode (36) 1280x1024p @ 75 Hz with pixel clock 135 MHz has a score of 24576
HDMI0:EDID preferred mode remained as CEA (17) 720x576p @ 50 Hz with pixel clock 27 MHz
Any help would be really appreciated :)
aBUGSworstnightmare
Fri Jan 10, 2020 8:01 am
Please post results of:
tvservice -s
tvservice -l
tvservice -d 10in-edid
edid-decode < 10in-edid
As you're suffering from 'screen blinking' you should set the output format to VGA 60Hz (hdmi_group=1 and hdmi_mode=1; changed in config.txt) first and reboot your Raspberry Pi before doing this.
As an option a VNC connection might work (or SSH).
vnunnari
Fri Jan 10, 2020 3:53 pm
Hi aBUGSworstnightmare and thanks to try helping me.
I first changed hdmi_group=1 and hdmi_mode=1 to config.txt then reboot.
tvservice -s
state 0x6 [DVI CUSTOM RGB full 4:3], 1024x768 @ 60.00Hz, progressive
tvservice -l
1 attached device(s), display ID's are : Display Number 2, type HDMI 0
decode-edid < 10in-edid
EDID EEPROM not found.  Please make sure that the eeprom module is loaded.
parse-edid edidtxt > decodedFile
Checksum Correct
Section "Monitor"
        Identifier "HDMI"
        ModelName "HDMI"
        VendorName "DWE"
        # Monitor Manufactured week 28 of 2009
        # EDID version 1.3
        # Digital Display
        DisplaySize 470 260
        Gamma 2.20
        Option "DPMS" "true"
        Horizsync 30-83
        VertRefresh 56-75
        # Maximum pixel clock is 210MHz
        #Extension block found. Parsing...
        Modeline        "Mode 15" -hsync -vsync
        Modeline        "Mode 0" +hsync -vsync
        Modeline        "Mode 1" 27.027 1440 1478 1602 1716 480 484 487 525 -hsy                                        nc -vsync interlace
        Modeline        "Mode 2" 27.027 1440 1478 1602 1716 480 484 487 525 -hsy                                        nc -vsync interlace
        Modeline        "Mode 3" 27.027 720 736 798 858 480 489 495 525 -hsync -                                        vsync
        Modeline        "Mode 4" 27.027 720 736 798 858 480 489 495 525 -hsync -                                        vsync
        Modeline        "Mode 5" 27.000 1440 1464 1590 1728 576 578 581 625 -hsy                                        nc -vsync interlace
        Modeline        "Mode 6" 27.000 1440 1464 1590 1728 576 578 581 625 -hsy                                        nc -vsync interlace
        Modeline        "Mode 7" 27.000 720 732 796 864 576 581 586 625 -hsync -                                        vsync
        Modeline        "Mode 8" 27.000 720 732 796 864 576 581 586 625 -hsync -                                        vsync
        Modeline        "Mode 9" 74.250 1280 1720 1760 1980 720 725 730 750 +hsy                                        nc +vsync
        Modeline        "Mode 10" 74.250 1280 1390 1420 1650 720 725 730 750 +hs                                        ync +vsync
        Modeline        "Mode 11" 74.250 1920 2448 2492 2640 1080 1082 1089 1125                                         +hsync +vsync interlace
        Modeline        "Mode 12" 74.250 1920 2008 2052 2200 1080 1082 1087 1125                                         +hsync +vsync interlace
        Modeline        "Mode 13" 148.500 1920 2448 2492 2640 1080 1084 1089 112                                        5 +hsync +vsync
        Modeline        "Mode 14" 148.500 1920 2008 2052 2200 1080 1084 1089 112                                        5 +hsync +vsync
        Modeline        "Mode 16" +hsync +vsync interlace
        Modeline        "Mode 17" +hsync +vsync interlace
        Modeline        "Mode 18" +hsync +vsync
        Option "PreferredMode" "Mode 15"
aBUGSworstnightmare
Sat Jan 11, 2020 8:05 am
One command is used incorrectly! It's edid-decode.
Make sure to install it by 'sudo apt install edid-decode' and then run it again.
I learned that parse-edid will give incorrect output so I stopped using it and use edid-decode instead.
vnunnari
Sat Jan 11, 2020 8:10 pm
Thanks,
i just did is, here is the result:
EDID version: 1.3
Manufacturer: DWE Model 2100 Serial Number 20000080
Made in week 28 of 2009
Digital display
DFP 1.x compatible TMDS
Maximum image size: 47 cm x 26 cm
Gamma: 2.20
DPMS levels: Off
RGB color display
Default (sRGB) color space is primary color space
First detailed timing is preferred timing
Display x,y Chromaticity:
  Red:   0.6484, 0.3388
  Green: 0.2822, 0.6025
  Blue:  0.1425, 0.0703
  White: 0.3134, 0.3291
Established timings supported:
  720x400@70Hz 9:5 HorFreq: 31469 Hz Clock: 28.320 MHz
  640x480@60Hz 4:3 HorFreq: 31469 Hz Clock: 25.175 MHz
  640x480@72Hz 4:3 HorFreq: 37900 Hz Clock: 31.500 MHz
  640x480@75Hz 4:3 HorFreq: 37500 Hz Clock: 31.500 MHz
  800x600@56Hz 4:3 HorFreq: 35200 Hz Clock: 36.000 MHz
  800x600@60Hz 4:3 HorFreq: 37900 Hz Clock: 40.000 MHz
  800x600@72Hz 4:3 HorFreq: 48100 Hz Clock: 50.000 MHz
  800x600@75Hz 4:3 HorFreq: 46900 Hz Clock: 49.500 MHz
  832x624@75Hz 4:3 HorFreq: 49726 Hz Clock: 57.284 MHz
  1024x768@60Hz 4:3 HorFreq: 48400 Hz Clock: 65.000 MHz
  1024x768@70Hz 4:3 HorFreq: 56500 Hz Clock: 75.000 MHz
  1024x768@75Hz 4:3 HorFreq: 60000 Hz Clock: 78.750 MHz
  1280x1024@75Hz 5:4 HorFreq: 80000 Hz Clock: 135.000 MHz
Standard timings supported:
Detailed mode: Clock 50.250 MHz, 476 mm x 268 mm
               1024 1068 1156 1344 hborder 0
                600  603  609  625 vborder 0
               +hsync -vsync
               VertFreq: 59 Hz, HorFreq: 37388 Hz
Serial number: 0
Monitor ranges (GTF): 56-75Hz V, 30-83kHz H, max dotclock 210MHz
Monitor name: HDMI
Has 1 extension blocks
Checksum: 0xf9 (valid)
CTA extension block
Extension version: 3
29 bytes of CTA data
  Video data block
    VIC   6 1440x480i@60Hz 4:3  HorFreq: 15734 Hz Clock: 27.000 MHz
    VIC   7 1440x480i@60Hz 16:9  HorFreq: 15734 Hz Clock: 27.000 MHz
    VIC   2 720x480@60Hz 4:3  HorFreq: 31469 Hz Clock: 27.000 MHz
    VIC   3 720x480@60Hz 16:9  HorFreq: 31469 Hz Clock: 27.000 MHz
    VIC  21 1440x576i@50Hz 4:3  HorFreq: 15625 Hz Clock: 27.000 MHz
    VIC  22 1440x576i@50Hz 16:9 (native) HorFreq: 15625 Hz Clock: 27.000 MHz
    VIC  17 720x576@50Hz 4:3  HorFreq: 31250 Hz Clock: 27.000 MHz
    VIC  18 720x576@50Hz 16:9  HorFreq: 31250 Hz Clock: 27.000 MHz
    VIC  19 1280x720@50Hz 16:9  HorFreq: 37500 Hz Clock: 74.250 MHz
    VIC   4 1280x720@60Hz 16:9  HorFreq: 45000 Hz Clock: 74.250 MHz
    VIC  20 1920x1080i@50Hz 16:9  HorFreq: 28125 Hz Clock: 74.250 MHz
    VIC   5 1920x1080i@60Hz 16:9  HorFreq: 33750 Hz Clock: 74.250 MHz
    VIC  31 1920x1080@50Hz 16:9  HorFreq: 56250 Hz Clock: 148.500 MHz
    VIC  16 1920x1080@60Hz 16:9 (native) HorFreq: 67500 Hz Clock: 148.500 MHz
  Audio data block
    Linear PCM, max channels 2
      Supported sample rates (kHz): 48 44.1 32
      Supported sample sizes (bits): 24 20 16
  Speaker allocation data block
    Speaker map:
      FL/FR - Front Left/Right
  Vendor-specific data block, OUI 000c03 (HDMI)
    Source physical address 1.0.0.0
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
1 native detailed modes
Detailed mode: Clock 27.000 MHz, 697 mm x 392 mm
                720  732  796  864 hborder 0
                576  581  586  625 vborder 0
               -hsync -vsync
               VertFreq: 50 Hz, HorFreq: 31250 Hz
Detailed mode: Clock 74.250 MHz, 697 mm x 392 mm
               1920 2008 2052 2200 hborder 0
                540  542  547  562 vborder 0
               +hsync +vsync interlaced
               VertFreq: 60 Hz, HorFreq: 33750 Hz
               1920 2448 2492 2640 hborder 0
               VertFreq: 50 Hz, HorFreq: 28125 Hz
               1280 1720 1760 1980 hborder 0
                720  725  730  750 vborder 0
               +hsync +vsync
               VertFreq: 50 Hz, HorFreq: 37500 Hz
Detailed mode: Clock 148.500 MHz, 697 mm x 392 mm
               1080 1084 1089 1125 vborder 0
               +hsync +vsync
               VertFreq: 50 Hz, HorFreq: 56250 Hz
Checksum: 0xd0 (valid)
vnunnari
Wed Jan 15, 2020 7:52 am
aBUGSworstnightmare, any Idea?
transmitterdan
Sun Jan 19, 2020 4:01 am
I use HDMI video into a 55 inch LG OLED TV. I have 3 Pi units (1 model 3B and 2 model 4). The one older 3B unit works fine. But the 2 brand new model 4 units both cause the TV to blank (switches to black) then a couple seconds later the screen comes back on. It happens at random but really annoying times. Is there any solution to the screen blinking off/on?
Here are some tvservice outputs:
pi@raspberrypi4:~ $ tvservice -s
pi@raspberrypi4:~ $ tvservice -l
pi@raspberrypi4:~ $ edid-decode 10in-edid
EDID version: 1.3
Manufacturer: GSM Model 1 Serial Number 16843009
Made in week 1 of 2017
Digital display
Maximum image size: 160 cm x 90 cm
Gamma: 2.20
RGB color display
  Red:   0.6396, 0.3300
  Green: 0.2998, 0.5996
  Blue:  0.1503, 0.0595
  White: 0.3125, 0.3291
  1152x864@60Hz 4:3
  1280x1024@60Hz 5:4 HorFreq: 64000 Hz Clock: 108.000 MHz
Detailed mode: Clock 594.000 MHz, 1600 mm x 900 mm
               3840 4016 4104 4400 hborder 0
               2160 2168 2178 2250 vborder 0
               +hsync +vsync
Skelingaton
Tue Jan 21, 2020 11:24 pm
I've been asking around trying to find a fix to get my Sony Bravia 1080p TV working for almost a month now and figured I'd post here since the main forum hasn't had much input. Below is my current config and I've tried messing around with several settings in the config but haven't found anything that works.
hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
hdmi_group=1
hdmi_mode=16
hdmi_drive=2
# no display
config_hdmi_boost=4
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
[pi4]
max_framebuffers=2
[all]
[all]
#dtoverlay=vc4-kms-v3d
Anyone have suggestions on what to try to get this working with a Pi 4b?
Manos
Fri Jan 24, 2020 12:44 am
Hey, I'm trying to get a Pi 4b set up right now and can't get video to display. I ran some tvservice commands to get more info on my TV and from what I can tell it belongs to hdmi_group=1 and hdmi_mode=16 but even using those settings the problem is still there. Here are the command lines I ran and the info I got from them.
/opt/vc/bin/tvservice -m CEA
           mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
           mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
           mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
           mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive
/opt/vc/bin/tvservice -m DMT
Group DMT has 5 modes:
           mode 39: 1360x768 @ 60Hz 16:9, clock:85MHz progressive
/opt/vc/bin/tvservice -d edid.dat
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 89x50 cm
HDMI:EDID monitor range: vertical is 58-62 Hz, horizontal is 14-70 kHz, max pixel clock is 150 MHz
HDMI:EDID standard timings block x 8: 0x8180 A9C0 0101 0101 0101 0101 0101 0101
HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 4066472)
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 3773832
HDMI:EDID CEA mode (60) 1280x720p @ 24 Hz with pixel clock 59 MHz has a score of 69236
HDMI:EDID CEA mode (62) 1280x720p @ 30 Hz with pixel clock 74 MHz has a score of 80296
Nothing jumps out at me as far as what I can change in the config.txt to fix it so I'm open to advice from anyone with more experience. In the meantime I'm going to keep trying out a few settings and see if happen to come across any fix.
