cgd
Firebird2.5-xxx in Raspbian Stretch?
Fri Oct 18, 2019 3:59 pm
Did you solve the problem? I am leading with same issue. Nobody had this problem? If anyone did it, please could say how? Thanks
B.Goode
Re: Firebird2.5-xxx in Raspbian Stretch?
Fri Oct 18, 2019 4:42 pm
I can't help directly, but can pass on the following -
User @Pancetto has not logged into the forums since a few days after posting their query 2 years ago. It is unlikely, but not impossible, that they will reply.
By reference to a site such as https://packages.debian.org/search?suit ... d2.5-super it is apparent that Debian did not implement this package in Stretch and Buster. By extension, it will not be installable with Raspbian either.
mahjongg
Fri Oct 18, 2019 11:51 pm
split from obsolete thread
Sat Oct 19, 2019 10:01 am
You should find a solution which works with Raspbian Buster Operating System and Firebird 3
https://packages.debian.org/buster/firebird3.0-common
Thinking outside the box is better than burying your head in the sand...
Return to “Raspberry Pi OS”
