Right now I've got my Pi in another room hooked up just to router via Ethernet and I'm configuring it over VNC on my windows 7 machine. Mainly due to lack of inputs and displays, but I'd like that to be my eventual setup.
Anyway I've got rtorrent set up, but I would like for it to run at startup without logging in or having to connect to the vnc. How can I do this? Is there a way to do this and still view the program when I do log in to the vnc?
- RaTTuS
- Contact: Twitter YouTube
Re: Run rtorrent on startup
well it depends....
how many cats have you ....
seriously
never having used it
you are using the console version?
a couple of things you can do
1)
edit /etc/inittab
change
1:2345:respawn:/sbin/getty --noclear 38400 tty1
to be
1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>&1
^ change pi to be whatever usename you are using
this means that the 1st console session will automatically log you in as user pi
2)
edit
~/.bash_rc
~/ means your home directory
add right at the end
if [ $(tty) == /dev/tty1 ]; then
rtorrent
fi
this means that if bash sees that you are on console one it will launch rtorrent [change that to be what ever command you want/need].
now you can log in fine on other consoles [f2-f6] with no issues and if you stop the program on console 1 then you can carry on as normal - if you
exit
then it will re-run the program mentioned in the .bashrc file.
others will have different methods
seriously
1)
edit /etc/inittab
change
to be
2)
edit
~/.bash_rc
rtorrent
fi
exit
Covfefe
Covfefe
Ok I did both of those things. I set it for to log into root, then I logged into root on my VNC thing. But when I looked at the task manager there's no rtorrent as there would be if I ran it normally in the terminal.
I'm still having trouble with this. Does anyone have any suggestions?
- RaTTuS
ssh into it and
sudo apt-get install pastebinit
w
and
ps axOT | pastebinit
who is logged in
w
and
who is logged in
Covfefe
Covfefe
I am logged in as root, and that is the only user.
http://paste.debian.net/180559
- RaTTuS
that pastebin is of no use for this problem
no need to log in as root, a normal user is fine
cat /etc/rc.local
cat /etc/inittab
tail ~/bashrc
cat /etc/rc.local
cat /etc/inittab
tail ~/bashrc
Covfefe
Covfefe
The correct way to do this is with a service:
You could use screen or run as an underprivileged or chrooted user, etc.
(indentation is killed by phpBB
then#!/bin/bash
#/etc/init.d/rtorrent
NAME=rtorrent
PID=$(pidof $NAME);
function start {
if [ "$PID" = "" ] ; then
echo "Starting $NAME...";
tmux new-session -d -n $NAME -s $NAME rtorrent
echo " Done.";
else
echo "$NAME is already running as $PID.";
fi
function stop {
if [ "$PID" != "" ] ; then
echo "Stoping $NAME...";
kill $PID;
TIMEOUT=30;
START=$( date +%s);
while [ $(( $( date +%s) - ${START} )) -lt ${TIMEOUT} ]; do
PID=$(tmux ls |grep rtorrent);
if [ "$PID" == "" ]; then break
else sleep 2
fi
done
echo "Error: $NAME would not stop";
else
echo " Done.";
fi
else
echo "$NAME is was not running.";
fi
function status {
if [ "$PID" = "" ]; then
echo "$NAME is not running";
else
echo "$NAME is running with pid $PID";
fi
if [ "$1" = "start" ]; then
start
elif [ "$1" = "stop" ]; then
stop
elif [ "$1" = "restart" ]; then
stop
start
elif [ "$1" = "status" ]; then
status
else
echo " * Usage: /etc/init.d/$NAME [start|status|stop|restart]";
fi
update-rc.d rtorrent defaults
service rtorrent start
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
