Sulforaphane
Rasperry Pi 4 - it just hangs when upgrading.
Mon Oct 14, 2019 9:28 pm
Hello.
I need some help.
Every time I run the "sudo apt upgrade" command. It just hangs.
Specifically it happened when installing the latest kernels:
Preparing to unpack .../0-raspberrypi-kernel-headers_1.20190925+1-1_armhf.deb ...
Unpacking raspberrypi-kernel-headers (1.20190925+1-1) over (1.20190819-1) ...
Progress: [  4%] [##........................................................]
It stops at 4%.
What may be the fault? I have checked the Micro SD and it seems fine.
ShiftPlusOne
Re: Rasperry Pi 4 - it just hangs when upgrading.
Wed Oct 16, 2019 12:55 pm
How long did you wait? It's a package with a lot of small files, which dpkg doesn't handle well. I think if you leave it for long enough, it will finish.
If you don't need to build out-of-tree/DKMS modules, it's safe to uninstall the package.
Sulforaphane
Wed Oct 16, 2019 1:03 pm
Maybe 20/30 minutes I waited.
Is this normal?
How do I uninstall this package?
ShiftPlusOne
Wed Oct 16, 2019 1:21 pm
Sulforaphane wrote:Maybe 20/30 minutes I waited.
I haven't timed it, but depending on the storage medium, I wouldn't be surprised
Sulforaphane wrote:How do I uninstall this package?
sudo apt remove raspberrypi-kernel-headers
Sulforaphane
Wed Oct 16, 2019 2:09 pm
Wow, didn't know it was so simple.
That did the job, thanks a lot!
