First, I just want to say thank you for all the great things you guys have created, Raspberry Pi has open the door to so many possibilities.
With that said my inquiry is focused on the need for a new camera that is better suited for the streaming and UAV drone robotic type applications that a majority of people use them for.
My application is Open.HD (Branch of EZ-WIFIBROADCAST) which is a low latency packet injection/monitor mode based long-range video transmission system.
https://github.com/HD-Fpv/Open.HD
Latency:
https://youtu.be/9wORSRSSVvY
Vid 1
https://youtu.be/9IdX1wz22ZQ
Vid 2
https://youtu.be/C3-fypJs2P8
One of the video uses the Toshiba CSI to adapter for the GoPro and as you can see the video is really clear it also has a better dynamic range.
I'm trying to understand why for example in the V2 camera you chose a 8MP IMX219 1/4" 2.7K sensor we're very few people actually stream 2.7k video?
The Achilles heel of open HD has been the lack of wide dynamic range abilities of the V1 or V2 camera.
I have learned that more megapixels does not necessarily mean a better camera.
What we desperately need is a good, High quality 1MP - 2MP 1/2" sensor like the IMX290 or Aptina AR0330 capable of very low lux, WDR and large sensor/pixel size as to optimize 720p 60/1080p 30fps video application.
So much of our conversation outside of this forum for the open HD Wi-Fi broadcast system is about users trying to find alternative camera solutions such as the Auvidea B101 module, Arducam MIPI cams, Veye IMV291 or USB cameras.... However, those cameras have limited resolution options and don't have access to all of the juicy Raspivid advanced paramaters...
It is my hope that this message will not fall on deaf ears and within the next year, a new camera with some or all of the following:
• A high quality, Glass wide-angle lens,
• 1/2" WDR Sensor
• FPV Style tilt mount
• 1MP-3MP Sensor
