NPDedyukhin
Setting privileges for the script
Thu Oct 10, 2019 6:49 am
Good afternoon! :)
Faced such a problem: I execute a command from the shell in a python script.
The command is executed successfully only when I launch it manually through the console using "sudo".
The command is:
sudo python wifi_scan_01.py
The script itself is as follows:
import os #обращаемся к оболочке
myCmd = 'iwlist wlan0 scan | grep "ESSID"' #моя команда которая через консоль вывела бы список доступных сетей wifi
os.system (myCmd) #выполняем мою команду
This is unacceptable to me, since in the future this script will be executed without my participation (it will be called from other scripts).
I want to resolve this issue without using "sudo" - as it is considered unsafe, and not entirely correct.
How can I configure privileges specifically for this script so that after its launch the command is executed successfully?
For example, I know that somehow you can use the ".policy" file to configure a specific script. But I don’t know exactly how.
How to use the Polkit library or DBus? :geek:
Respectfully,
Nikita Dedyukhin
neilgl
Re: Setting privileges for the script
Thu Oct 10, 2019 9:58 am
What version of Raspbian and pi are you running it on? On my pi4 running Buster, log in as pi then not using sudo,
pi@pi4:~ $ iwlist wlan0 scan | grep ESSID
                    ESSID:"BlackSabbath"
                    ESSID:"NETGEAR-5G"
                    ESSID:"LedZep"
                    ESSID:"ESP_32E0E8"
And a python script like yours also returns 4 SSID, not run using sudo.
hippy
Thu Oct 10, 2019 12:01 pm
Your Python program worked for me on a pi 3B using buster without a 'sudo'. But, if you do need to execute something which needs to be 'sudo' you can do that by adding the 'sudo' within the Python code -
import os
myCmd = 'mkdir /magic'
os.system(myCmd)
pi@Pi3B:~/tmp $ python2 mk.py
mkdir: cannot create directory '/magic': Permission denied
pi@Pi3B:~/tmp $
Then with the 'sudo' added -
import os
myCmd = 'sudo mkdir /magic'
os.system(myCmd)
pi@Pi3B:~/tmp $ ls /
bin   dev  home  lost+found  media  opt   root  sbin  srv  tmp  var
boot  etc  lib   magic       mnt    proc  run   snap  sys  usr
pi@Pi3B:~/tmp $
That Python code can do anything it wants without having to run it with 'sudo' always seemed a little odd and dangerous to me but that's the way it is.
bjtheone
Thu Oct 10, 2019 12:16 pm
Depends on how you have sudo setup. Do you want convenience or security. Unrestricted sudo without requiring a password, is only slightly better than just running as root. However, it is a real Linux system, you can lock it down as tight as you want.
Out of the box, using it as a tinkering and learning platform it makes sense to remove much of the security and simplify things to make it more accessible. Forcing the use of sudo at least points out that some commands have more potential for chaos and mayhem and should at least be double checked.
NPDedyukhin
Thu Oct 10, 2019 2:36 pm
import os
os.system(myCmd)
pi@Pi3B:~/tmp $
import os
os.system(myCmd)
pi@Pi3B:~/tmp $
Thanks, earned! ;)
Respectfully,
Nikita Dedyukhin
hippy
Thu Oct 10, 2019 3:05 pm
But then didn't, and then appeared to work with sudo, but also afterwards without ...
pi@Pi3B:~/tmp $ iwlist wlan0 scan | grep "SSID"
pi@Pi3B:~/tmp $ sudo iwlist wlan0 scan | grep "SSID"
                    ESSID:"TALKTALK..."
                    ESSID:"VM..."
                    ESSID:"TP-LINK..."
                    ESSID:"TALKTALK..."
                    ESSID:"VM..."
                    ESSID:"TP-LINK..."
pi@Pi3B:~/tmp $
I suspected it was just coincidence that using 'sudo' and getting a result led to a belief that 'sudo' was required.
Though now it seems to only work without 'sudo' after having been run with a 'sudo'.
Seems it has to be invoked with 'sudo' then non-'sudo' can be used for some period of time thereafter. Weird.
https://linux.die.net/man/8/iwlist
"Triggering scanning is a privileged operation (root only) and normal users can only read left-over scan results".
I guess leftover scan results expire.
neilgl
Thu Oct 10, 2019 3:32 pm
And is iwlist the old command and the newer iw command has more features?
sudo iw wlan0 scan | egrep 'SSID|signal'
davidcoton
Thu Oct 10, 2019 5:23 pm
Furthermore, it appears (but I have not tested) that iw does not need sudo to scan: see here.
hippy
Thu Oct 10, 2019 5:26 pm
Seems to need sudo for me ...
pi@Pi3B:~/apps/wifiscan $ sudo iw wlan0 scan
BSS e4:f4:c6:b1:3c:40(on wlan0)
        last seen: 608285.805s [boottime]
        TSF: 0 usec (0d, 00:00:00)
        ... snip ...
pi@Pi3B:~/apps/wifiscan $ iw wlan0 scan
command failed: Operation not permitted (-1)
While 'iw' does seem more useful, more informative than 'iwlist', 'iwconfig' etc, I do wish developers would provide backwards compatible output so one can simply swap 'iwlist' for 'iw' without having to rewrite everything which parses the output :(
Andyroo
Thu Oct 10, 2019 5:28 pm
Buster (about a week out of date) does need sudo:
pi@web:~ $ iw wlan0 scan | egrep 'SSID|signal'
pi@web:~ $ sudo iw wlan0 scan | egrep 'SSID|signal'
	signal: -68.00 dBm
	SSID: VodafoneConnectxxxxxx
	etc
davidcoton
Thu Oct 10, 2019 5:30 pm
        ... snip ...
Just proves you can't believe everything you read, even software documentation :lol: :roll:
Andyroo
Thu Oct 10, 2019 5:36 pm
Did not your mother teach you anything about data on the Internet.
It's only worth the value of the paper it's written on :lol: :?: :lol: :mrgreen:
bjtheone
Fri Oct 11, 2019 12:47 am
While the permission allow the execution, and an unprivileged user can run it if /sbin is in your path, it seems that privileges are required to do anything useful with it. Not quite sure what the point is to set it 755.
