allampanato
Programming languages support
Wed Oct 09, 2019 2:16 pm
Hi to all. What is the state of various programming languages on the RPi?
I am currently planning a project, where I will need to access the GPIO, the camera module and use Websockets. So I need a language which can access all the features of the RPi. I will use a RPi4 and a RPi Zero W.
I know Python fully supports the RPi family. I have used it for years. But Python is a bit slow for my needs now.
I have a list of potential candidates: Java/Kotlin/JVM in general, C#, C++, Go, Javascript/Node.js. Node.js should have a decent support ( from what I have read ). C#/.Net core too.
Also, what about Ultibo? It should support the RPi hardware fully. But websockets?
Re: Programming languages support
Wed Oct 09, 2019 2:24 pm
I think any computer language you can think of will be supported on the Pi.
However, the range is narrowed if you want particular libraries.
For your use case, requiring speed , I'd go with C or C++. All your requirements would be covered by easily available libraries.
No idea about Ultibo, isn't that Pascal based?
allampanato
Wed Oct 09, 2019 3:40 pm
Yes, I know that practically every programming language can run on the RPi/Linux. But I need to access the GPIO pins and the camera module. And not every language has bindings to the appropriate libraries.
I know that Python has them all. Nodejs should have them ( not 100% sure ). All others, don't know.
And yes, Ultibo is Freepascal-based.
rpiMike
Wed Oct 09, 2019 3:46 pm
I would try Python first. I've not had any speed issues - its coped with everything I've used it for.
Wed Oct 09, 2019 4:36 pm
I'll repeat that C/C++ has libraries for all you need, and the ONLY other camera library I know about is in Python.
ejolson
Wed Oct 09, 2019 4:40 pm
It sounds like the person making the original post has been using Python and already run into limitations with regards to execution speed.
One thought would be to profile your Python code and write the part that is slow in C and and call it from Python. While a multiple-language approach tends to be more complicated than writing everything in one language, there are many people who know Python and C well enough to work on such projects.
If I were writing code for a complicated multi-threaded server, I would try Go.
Although Go was designed to make it easy to code a multi-threaded server, it is not particularly popular on this forum. Go also runs best in 64-bit environments with AES hardware support and may need some custom interfacing code for the GPIO and camera on the Pi. As none of these problems are likely insurmountable, I think it might be the better choice.
timrowledge
Wed Oct 09, 2019 6:04 pm
Smalltalk is considerably faster than python and offers easy access to gpio, web services, client-server, OS access, excellent developer tools, actual, real, portability, a sensible language and generally a lot of good things. There has been a Smalltalk available for ARM since before it was originally announced.
www.squeak.org
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
ejolson
Thu Oct 10, 2019 12:43 am
www.squeak.org
The link is broken. Has squeak been discontinued?
Gavinmc42
Thu Oct 10, 2019 1:00 am
https://squeak.org/
Wonder if there is a an Aarch64 version?
I'm dancing on Rainbows.
Thu Oct 10, 2019 11:44 am
allampanato,
Very good. Pretty much every language you will ever need is supported. Frankly if a language does not work on Linux/Unix it's better to be looking at something else.
For your project I suggest using node.js because:
1) Dealing with web sockets in node.js is trivially easy.
The requirement for websockets suggests using JSON as the data transfer format. Which again is trivially easy in node.js. Do not even think about C/C++, dealing with JSON in C/C++ is the road to madness.
2) Dealing with multiple asynchronous events is trivially easy in node.js
The requirement for juggling inputs from GPIO, the camera and the network at the same time suggests using threads in most programming languages. The event driven programming model of Javascript in node.js makes responding to all these events trivially easy. Using treaads is not necessarily difficult but it's a complexity one would rather not deal with.
3) Performance will be better than Python.
If you really need more performance than you can get from node.js then it's probably better to skip the sloth and bloat of Java or any JVM based language. Normally I would suggest C++ at that point but today Rust is a far better alternative https://www.rust-lang.org/
B.Goode
Thu Oct 10, 2019 11:47 am
www.squeak.org
Just a trivial slip in composing the forum post. The site is there.
jahboater
Thu Oct 10, 2019 11:59 am
Using threads is not necessarily difficult but it's a complexity one would rather not deal with.
On Linux (Raspbian) or UNIX, select() makes that sort of thing fairly easy - without using threads.
man 2 select
It is actually a system call.
Thu Oct 10, 2019 12:13 pm
select() is great and all but you end up having to write code like this: https://www.tutorialspoint.com/unix_sys ... select.htm
Most of which is nothing to do with the problem you want to solve. Rather you are having to think about the bigger problem of how to do that kind of thing in C.
jahboater
Thu Oct 10, 2019 12:28 pm
    /* Watch stdin (fd 0) to see when it has input. */
    FD_ZERO(&rfds);
    FD_SET(0, &rfds);
    /* Wait up to five seconds. */
    tv.tv_sec = 5;
    tv.tv_usec = 0;
    retval = select(1, &rfds, NULL, NULL, &tv);
Seems simple enough to me.
The same code works for thousands of devices or sockets.
Much easier and safer than threads IMHO.
Its also very fast and light weight.
Thu Oct 10, 2019 12:37 pm
allampanato,
Does it have the required camera library?
(Note, you could use the V4L2 driver if there is a driver for that).
Thu Oct 10, 2019 3:10 pm
jahboater,
Using select() is not massively complex, but certainly more so than using fs from node.js. Especially when dealing with many files and other I/O at the same time. Also select will block execution thus upsetting responsiveness of other parts of your program. Oh and you have to use C which of course is more complicated to use in the first place.
There is no problem with thread safety in node.js. It has no threads it is event driven.
jamesh,
On can just run the camera command line tools from node.js with system(). Or use one of the many wrapper modules: https://www.npmjs.com/package/pi-camera
https://www.npmjs.com/package/v4l2camera
allampanato
Thu Oct 10, 2019 4:59 pm
Yes, this is one of the problems. The RPi Zero W is the core of a smart doorbell and one of its features is streaming the camera to a bunch of clients on demand. I will have a hub for the heavy lifting, so for now I am trying to understand if it is better to just stream the video to the hub ( and from there to the clients ) or do a direct connection to the clients through ( maybe ) WebRTC.
jahboater
Thu Oct 10, 2019 5:01 pm
Yes, very likely. I have not used node.js, so I cannot comment (JS did not exist when I was doing this sort of thing for a living ...).
That's where select excels. Also I would expect it to be much more scaleable.
No. Just set the timeout to zero and select() will return immediately (handy to implement polling).
The JS event driven model without threads does sound nice, but that's how select() is commonly used anyway.
Select() is a Linux/UNIX system call, I wonder if its possible to strace node and see if its calling select() under the covers :)
allampanato
Thu Oct 10, 2019 5:04 pm
Plus 1 point for Node.js then. For now I don't know if Websockets or WebRTC is the better solution. From what I have read, the difference between the two is that WebRTC supports P2P connections.
I thought about Worker threads in Node.js.
ejolson
Thu Oct 10, 2019 6:39 pm
One important factor to consider in any discussion of the suitability of a particular programming language for a project is how well the language is already known by the developers and by people who might help the developers.
If a programming language is well known, then everything becomes easier compared to when it isn't.
For this reason the popularities of C/C++, Java and Python are self perpetuating. Since many know those languages well, many new programs are created using those languages. This also explains why a person who knows language X best says the task would be easy in language X.
timrowledge
Thu Oct 10, 2019 7:06 pm
https://squeak.org/
Not yet. I’d like to be working on it but other things are in the way. We have x64 for intel devices though so we know the fundamentals work.
Thu Oct 10, 2019 7:37 pm
@jahboater,
If you do that you now have a loop thrashing around as fasts as possible polling things and burning electricity.
Or you put a delay in your polling loop, which gets us back the upsetting responsiveness of other parts of your program problem and introducing latency.
Node.js uses libuv under the hood. The modern way to do asynchronous programming in C in a cross-platform manner. Which in turn uses epoll, kqueue, IOCP, event ports.
@ejolson
Certainly there are a lot of non-technical reasons for language selection. User familiarity, cross-platform support, popularity, availability of useful libraries/modules, ease of taking those libs/modules into use, etc, etc.
For this reason the popularity of JS/node.js is self perpetuating. Since many know that language well, many new programs are creating using that language.
Quite so. In this case I have made a lot of software in all manner of languages, professionally and otherwise, so I can offer a slightly less biased comparison. Only slightly mind :). People have to pick there own poison at the end of the day.
PeterO
Thu Oct 10, 2019 7:44 pm
@jahboater,
You don't seem to understand how select (or poll) actually work. From poll man page....
    The timeout argument specifies the number of milliseconds that poll() should block waiting for a file descriptor to become ready.  The  call
       will block until either:
       *  a file descriptor becomes ready;
       *  the call is interrupted by a signal handler; or
       *  the timeout expires.
PeterO
Thu Oct 10, 2019 9:01 pm
PeterO,
You don's seen to understand what I wrote. I'll try again with reference that man mage:
That could be a long time when reading from sockets, serial ports etc.
Which may never happen.
Well there you go, either that is a zero or very short time out, in which case you are thrashing around needlessly wasting performance and generating heat.
Or that is a longer timeout in which case you have hung up all processing for the duration.
Likely one can find a middle ground but it's a bit kludgy to my mind.
jahboater
Thu Oct 10, 2019 10:29 pm
You should actually try using it .... then it would become clear.
You may set a zero timeout - which is a simple poll.
You may set an interval.
You may specify no timeout at all - so it blocks indefinitely.
For the last case your entire workload is handling events. If the server is doing other substantial work that's not related to the event driven work, then you probably should use another thread for it. Control requests by the way may be TCP messages to the server, which are handled as just another type of event.
So a program that is handling events only does:-
select() returns and you deal with all the events.
Call select() again with no timeout and repeat.
So very simple.
Its only doing work when its processing the events, otherwise the CPU overhead is zero.
No wasted time "thrashing around generating heat".
That's just about the simplest of many scenarios. Select() is a remarkably clever and flexible system call.
I guess the benefit JS provides is to convert events into callbacks. Accept registration of event handlers, and other administrative stuff.
An advantage of doing it in C is you can write your own scheduler directly.
Incidentally, the interval may be set very precisely and select() used to be used as a precise high resolution sleep function before nanosleep() arrived.
