Apologies to all, I think I've got it all wrong!
I thought that by connecting my external HDD (as per I have done with mountpoint /pi/mnt/CamFiles), I could then FTP files straight from my CCTV Cameras into that directory, do some changes to them, and they would be automatically moved onto my HDD. I created a symlink to be able to connect to (ln -s mnt/Camfiles ~CamFiles) from my login position, but it seems I somehow cannot move the files onto my HDD.
The cameras will FTP the files into that directory and I have done lots of searching on 'automatically moving files from a raspberry pi onto a USD HDD' and all I've found is information on creating mountpoints (which I've done in fstab) and dragging/dropping any files into that directory using either a mac or windows connection (mine is windows 10) through windows explorer.
All it seems I am doing is creating new directories based upon the file dates coming in, and then moving the files into them.
My pi is now full and if I run this command "sudo du -xh / | grep -P "G\t"" (found through my seraches) to find out by what, I get:-
4.2G /home/pi/mnt/CamFiles/RearOfHouse/mp4Files/201910_mp4
4.5G /home/pi/mnt/CamFiles/RearOfHouse
2.2G /home/pi/mnt/CamFiles/Dots/2019/10/01
3.3G /home/pi/mnt/CamFiles/Dots/2019/10
13G /home/pi/mnt/CamFiles/FrontOfHouse/mp4Files/201910_mp4
14G /home/pi/mnt/CamFiles/FrontOfHouse
21G /home/pi/mnt/CamFiles
21G /home/pi/mnt
21G /home/pi
21G /home
2.1G /usr/lib
1.1G /usr/share
3.3G /usr
25G /
So it seems to me the files are just building up inside 'pi/mnt/CamFiles' which my script (below) works on the files.
#!/bin/bash
#source $HOME/.bash_profile
## this file is being ran from the directory on the HDD '/CamFiles/FrontOfHouse/'
# create an array with all the files/dir inside ~/CamFiles/FrontOfHouse/
####!/bin/bash
arr=(/home/pi/mnt/CamFiles/FrontOfHouse/*.jpg)
# iterate through array using a counter
for ((i=0; i<${#arr[@]}; i++)); do
################### SET UP VARIABLES FOR CODE ###########################
j=${arr[$i]:38:6}"_jpg" ## 201903_jpg
echo "j= " ${j}
k=${arr[$i]:0:34}"/jpgFiles/" ## /home/pi/mnt/CamFiles/FrontOfHouse/jpgFiles/
echo "k= " ${k}
h=${arr[$i]:0:56} ## /home/pi/mnt/CamFiles/FrontOfHouse/ARC20190315080521.jpg
echo "h= " ${l}
m=${arr[$i]:0:56} ##/home/pi/mnt/CamFiles/FrontOfHouse/ARC20190315080521.jpg
echo "m- " ${m}
n=${k}${j} ## /home/pi/mnt/CamFiles/FrontOfHouse/201903
echo "n= "${n}
o=${arr[$i]:38:6} ## 201903
echo "o= " ${o}
oo="${k}${o}""_jpg"
echo "oo= " ${oo}
l="${k}${j}"
echo "l= " ${l}
################### CREATE ANY NEW DIRECTORIES THAT NEED CREATING ##############
mkdir -p "${oo}" ### this creates new directories in location of this exec file
echo " DIR " "${oo}" " Built"
################# MOVE ALL FILES TO RELEVANT DIRECTORIES NEXT ##################
### mv pathtofileA pathtofileB ###
aa="201901_jpg"
bb="201902_jpg"
cc="201903_jpg"
dd="201904_jpg"
ee="201905_jpg"
ff="201906_jpg"
gg="201907_jpg"
hh="201908_jpg"
ii="201909_jpg"
jj="201910_jpg"
kk="201911_jpg"
ll="201912_jpg"
echo "Starting to move files.........."
if [ ${j} = ${aa} ]; then
echo "moving " "${m}" " to " "${l}"
mv "${m}" "${l}"
fi
if [ ${j} = ${bb} ]; then
mv "${m}" "${l}"
fi
# if [ ${j} = ${cc} ]; then
#fi
mv "${m}" "${l}"
fi
if [ ${j} = ${dd} ]; then
mv "${m}" "${l}"
fi
if [ ${j} = ${ee} ]; then
mv "${m}" "${l}"
fi
if [ ${j} = ${ff} ]; then
mv "${m}" "${l}"
fi
if [ ${j} = ${gg} ]; then
mv "${m}" "${l}"
fi
if [ ${j} = ${hh} ]; then
mv "${m}" "${l}"
fi
if [ ${j} = ${ii} ]; then
mv "${m}" "${l}"
fi
if [ ${j} = ${jj} ]; then
mv "${m}" "${l}"
fi
echo "All files moved."
done
I thought I could avoid buying a ready built CCTV monitoring system as this was by far the cheaper option, but it is looking more likely I will have to now.
I am going to give it a little more time searching, but am not holding my breath, as it looks to me the pi cannot automatically move files to my HDD.
WD
(I'm going to add 'rm -rf RearOfHose' and all the other subdirectories to the end of my scripts to see what that does)
