Gooseman
raspberrypi-bootloader (1.20190925-1) upgrade fails: /boot too small
Tue Oct 01, 2019 2:22 pm
I tried to update my existing RPi3 systems (buster distro, latest upgrades) to raspberrypi-bootloader (1.20190925-1) via
sudo apt update && sudo apt upgrade
and it fails with the message:
dpkg-divert: error: cannot copy '/usr/share/rpikernelhack/start4cd.elf' to '/boot/start4cd.elf.dpkg-divert.tmp': failed to write (No space left on device)
It seems to be a problem with /boot being at 99% utilization and apt running into some trouble. /boot has around 50MB of size.
Unfortunately, I re-ran apt upgrade and as the messages seemes then ok, I rebooted my RPi.. but now it is bricked and I cannot even get the boot messages..
1) anything I can do to revive the SD except for reinstalling buster?
2) I have another system with the same problem but I did not reboot yet, so it is still running fine. I am pretty sure however, that a reboot will brick it. Any ideas how to fix the problem/roll back?
Thanks in advance!
klricks
Re: raspberrypi-bootloader (1.20190925-1) upgrade fails: /boot too small
Tue Oct 01, 2019 3:30 pm
Did you do an OS upgrade in the past rather than a fresh install?
The size of /boot is now ~250 MB.
I believe you must do a fresh install to get the larger size.
ShiftPlusOne
Tue Oct 01, 2019 3:52 pm
We've strongly tried to discourage people from upgrading for this exact reason. I'll roll back to the previous package for now and add a check that will block you from upgrading to the new package to prevent people from shooting themselves in the foot.
Gooseman
Tue Oct 01, 2019 4:03 pm
What exactly do you mean? Upgrading from stretch to buster?
ShiftPlusOne
Tue Oct 01, 2019 4:09 pm
Yes. Since buster is the first release to support pi 4, the boot partition requirements have been increased. Without resizing it, it's tricky to find a solution that works for everybody.
We could split the kernels and firmware into more separate packages. We could try to determine which files the user actually wants to end up with. But both of these approaches will lead to problems later down the line.
For now, blocking the upgrade to in cases where it may fail is the safest way to avoid bricked pis.
Gooseman
Tue Oct 01, 2019 4:14 pm
thanks for the clarification.. I read about discouraging direct upgrades but I tried on a non-essential system without problems a few weeks ago so I felt safe. Definitely my mistake..
For those of my systems which did the upgrade but have not rebooted yet: any hints how to roll back the changes already made? Probably fetching my pre-buster backup images..
ShiftPlusOne
Tue Oct 01, 2019 4:17 pm
If you wait and run apt-get update in about an hour, you should be able to reinstall the previous version of those packages, without kernel8.img
Gooseman
Tue Oct 01, 2019 4:27 pm
thanks a lot, very much appreciated!
ShiftPlusOne
Tue Oct 01, 2019 4:41 pm
you can use 'apt policy package_name' to check the available versions, then install them with 'sudo apt install --reinstall package_name=version'
tigernero
Thu Oct 03, 2019 3:59 pm
For those like me who did a clean install of a buster with a July 10 release, doing "sudo apt update && sudo apt dist-upgrade" will I find myself with an updated November 26 image? because I did it and I noticed that the kernel is still stopped at 4.19.66 on pi3b + and has not updated to 4.19.75.
Thu Oct 03, 2019 4:11 pm
Raspbian Buster
sudo apt update
sudo apt full-upgrade
sudo reboot
Retired disgracefully.....
B.Goode
Thu Oct 03, 2019 4:15 pm
Possibly not an appropriate thread to highjack with your question.
See https://www.raspberrypi.org/forums/view ... 6&t=253229 and/or https://www.raspberrypi.org/forums/view ... 6&t=253340
Tl;dr: update+upgrade not (necessarily) equivalent to installing a current image.
ShiftPlusOne
Thu Oct 03, 2019 4:16 pm
The question is a little difficult to answer. Apt deals with packages, not images. Images contain packages, but images may also have other changes.
So to answer your question literally, no it will not get you to the new image, but it will update your packages to newer versions.
It won't pick up the updated kernel and bootloader packages because I don't want to brick people's pis but the solution to it is getting more and more convoluted the more I work on it. When it's ready, I'll push it out.
tigernero
Thu Oct 03, 2019 4:21 pm
thanks for the info, but at a practical level what changes between having the release of 07-10-2019 updated with "sudo apt update && sudo apt dist-upgrade", with that of November 26, 2019? because being both based on the buster the boot partition is always the same 256mb or not? what should it break? do I still have a 32 or 64 bit kernel doing 10-7-2019 updates on both pi3b + and pi4? if I do rpi-update will I have the last 64-bit kernel?
FTrevorGowen
Thu Oct 03, 2019 5:55 pm
@tigernero - somethings not right with your dates here - it, as I post, is only 3rd Oct. 2019 so where do you get "07-10-2019" and "November 26, 2019" from?
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Thu Oct 03, 2019 6:01 pm
Trev.
Silly date formats - they're the bane (after Db2 code pages).
USA 07-10-2019 == EUR 10/07/2019 == ISO 2019-10-07 == JIS 19/10/07
This is a doctor free zone.
FTrevorGowen
Thu Oct 03, 2019 6:19 pm
Trev.
Aargh! You're probably right Dougie - it was the explicit use of "November" that jarred!!!
Trev.
tigernero
Thu Oct 03, 2019 6:26 pm
To clarify: I have installed the Raspberry Pi reference 2019-07-10 on a pi3b + and a pi4, and until now I have always updated with "sudo apt update && sudo apt dist-upgrade". Having released the raspbian version 2019-09-26, I was wondering if I have this version now with the latest updates or I have to do installation from scratch. I ask this because I noticed that the kernel is stopped at 4.19.66 and only with a sudo rpi-update I took it to 4.19.75. What is the difference between starting a 2019-07-10 installation and upgrading, or starting with a direct installation from 2019-09-26 ?. the boot partition nn has the same capacity to be able to receive 64 bit kernels without breaking?
I apologize in error on the month of November I meant September with the dates in Italian.
B.Goode
Fri Oct 04, 2019 9:39 am
See https://www.raspberrypi.org/forums/view ... 6#p1546477
My understanding is that the separate issue of the size of the boot partition should not arise with any system originally installed from an official Raspberry Pi Raspbian Buster Operating System image. The problems some people have apparently experienced are almost certainly a consequence of attempting to perform an 'in place' upgrade from a 'legacy' release based on Raspbian Stretch, having ignored the advice to the contrary from Raspberry Pi.
ShiftPlusOne
Tue Oct 08, 2019 8:37 am
I've put an updated version of the package into the 'untested' component.
Instructions on how to try it are the same as the ones here: https://www.raspberrypi.org/forums/view ... p?t=249650
I'm not confident enough to push it to 'main' yet, so confirmation that everything works as expected would be good.
If there's not enough space in /boot to install everything, it will leave out or only install pi 4 kernel and firmware files, depending on which pi you're running on.
andrum99
Tue Oct 08, 2019 10:31 am
Does it show a warning that it is doing that? I ask as that would break the ability to use that SD card in different models of Pi.
ShiftPlusOne
Tue Oct 08, 2019 10:33 am
It does show a warning, but it's likely to scroll past before the user notices. The aim isn't to make it perfect, but just ensure the user can still reboot and that apt isn't in a broken state that's difficult to recover from.
Setting up raspberrypi-bootloader (1.20190925-2) ...
You do not have enough space in /boot to install this package.
Skipping Pi 4 support
Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Setting up libraspberrypi0 (1.20190925-2) ...
Setting up libraspberrypi-doc (1.20190925-2) ...
Setting up libraspberrypi-bin (1.20190925-2) ...
Setting up libraspberrypi-dev (1.20190925-2) ...
andrum99
Tue Oct 08, 2019 9:54 pm
That makes sense - thanks for clarifying.
HawaiianPi
Wed Oct 09, 2019 7:31 am
... but the solution to it is getting more and more convoluted the more I work on it. When it's ready, I'll push it out.
It seems to me the solution is for people to follow recommendations and not upgrade from an older OS. As far as I know, that was never a supported procedure (Debian/Raspbian stable is not a rolling release), so I'm not sure why effort is being devoted to supporting it now?
Especially when it will likely just lead to further trouble (limiting what gets installed in the smaller /boot partition will cause problems when someone tries to swap the card to another model). So you're just trading one problem for another.
Although it is very nice of you to try. Image
Wed Oct 09, 2019 7:35 am
Totally agree that starting fresh has always been the recommendation, says so in Simon Long's Blog:
https://www.raspberrypi.org/blog/buster ... -raspbian/
Return to “Raspbian”
