1uke_
Is it OK to use a 4 Multi-Port Quick Charge Mains Wall Charger Adapter Plug to power multiple pis?
Sat Sep 28, 2019 9:15 pm
As my skill with Raspberry Pi increases, I find I am using more Pi's to host various services on my network.
As a result of this I am fast running out of power sockets.
I wondered if it is safe to use a 4 Multi-Port Quick Charge Mains Wall Charger Adapter Plug to power multiple pis?.
Below is an example
rin67630
Re: Is it OK to use a 4 Multi-Port Quick Charge Mains Wall Charger Adapter Plug to power multiple pis?
Sat Sep 28, 2019 9:43 pm
This is safe. I am doing it with a similar multi-charger.
drgeoff
Sat Sep 28, 2019 10:46 pm
"Safe" and "performing satisfactorily" are two different things.
davidcoton
You need to check the total load the PSU can support. Often they will not provide the full current on all ports simultaneously.
Even then they may not maintain 5V when running a significant load.
Signature retired
Sat Sep 28, 2019 10:59 pm
The markings on that photo say 2.4A @ 5V, 1.8A @ 9V or 1.5A @ 12V.
I'd have thought it was easier to use a mains 13A socket strip and an official power supply for each Raspberry.
This is a doctor free zone.
Sun Sep 29, 2019 4:15 am
The developer of the PiDramble uses this product:
https://www.amazon.com/AUKEY-Charger-4- ... B077P1HC6H
Retired disgracefully.....
LTolledo
Sun Sep 29, 2019 5:02 am
Below is an example
An almost similar device was used by another forum member.... with disastrous result for him/her.
you're free to follow his/her example....
while most of us follow the official recommendation of the RPF.... and having peace of mind while at it.
Some people be like:
rin67630
Sun Sep 29, 2019 8:53 am
IMHO that corrspnds to the the AI standard for smart chargers.
They can deliver higher voltages than 5V, but only after a handshake over the USB communication channel.
Nothing wrong with using this charger at 5V only.
rin67630
Sun Sep 29, 2019 9:07 am
I am using that one, but for one 3b+ Pi or 2 3a+ Pis only.
https://www.ebay.de/itm/3-Port-USB-Tele ... 4462394319
They deliver a good 5V voltage, the display measurement is accurate enough and I am informed about the drawn current.
Gavinmc42
Sun Sep 29, 2019 10:04 am
I'm looking for one that will give me 12amps total, 4 x 3amps.
I'm dancing on Rainbows.
davidcoton
Sun Sep 29, 2019 10:50 am
Gavinmc42 wrote: I'm looking for one that will give me 12amps total, 4 x 3amps.
The RAV unit discussed in
USB powered hub or charging station to power Pi 4B cluster?
may be suitable.
Signature retired
LTolledo
Sun Sep 29, 2019 10:53 am
An ATX (or even an ITX) PSU may be up for the job....
rin67630
Sun Sep 29, 2019 2:29 pm
Not directly! Powering the Pis with an unfused high current Power supply is dangerous!
You will need to include a proper fusing on each output and include everything in a decent cabinet...
That is probably not something for everyone.
A good solution would have been to re-use a charger from an obsolete laptop. They usually deliver 3-4A at 19v.
With a buck converter as that one for each pi :
https://www.ebay.co.uk/itm/6-24V-12V-24 ... 3809634140
you can power around five Pi 4 and seven Pi 3, maybe even more if you don't use a lot of periphery.
LTolledo
Sun Sep 29, 2019 8:52 pm
I'd still prefer DougieLawson's suggested solution...
safer
simpler
modular
better isolation
