sudo service --status-all
Sound familiar?
Thanks,
Dave
sudo service cron stop
sudo service cron start
sudo service cron status
● cron.service - Regular background program processing daemon
Loaded: loaded (/lib/systemd/system/cron.service; enabled)
Active: active (running) since Sun 2019-09-22 15:18:27 NZST; 5 days ago
Docs: man:cron(8)
Main PID: 1244 (cron)
CGroup: /system.slice/cron.service
├─ 1244 /usr/sbin/cron -f
├─32436 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant_sbms.conf
└─32537 dhclient -v -pf /run/dhclient.wlan0.pid -lf /var/lib/dhcp/dhclient.wlan0.leases wlan0
Sep 27 18:54:01 raspberrypi sudo[29699]: root : TTY=unknown ; PWD=/root ; USER=root ; COMMAND=/home/./run_system.sh
Sep 27 18:54:01 raspberrypi sudo[29699]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 27 18:54:05 raspberrypi sudo[29699]: pam_unix(sudo:session): session closed for user root
Sep 27 18:54:05 raspberrypi CRON[29692]: pam_unix(cron:session): session closed for user root
Sep 27 18:55:01 raspberrypi CRON[29744]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 27 18:55:01 raspberrypi CRON[29748]: (root) CMD (/usr/bin/flock -w 0 /home/run_system.sh -c "sudo /home/./run_system.sh" > /dev/null 2>&1)
Sep 27 18:55:01 raspberrypi sudo[29751]: root : TTY=unknown ; PWD=/root ; USER=root ; COMMAND=/home/./run_system.sh
Sep 27 18:55:01 raspberrypi sudo[29751]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 27 18:55:05 raspberrypi sudo[29751]: pam_unix(sudo:session): session closed for user root
Sep 27 18:55:05 raspberrypi CRON[29744]: pam_unix(cron:session): session closed for user root
