- operates like IPSec at the kernel level for efficiency;
- uses 4000 lines of code instead of 600,000 lines.
Direct WireGuard Relative
iperf3 ping iperf3 ping iperf3 ping
Pi4B to Xeon 936 0.182 704 0.874 75% 20%
Xeon to Xeon 935 0.207 896 0.481 96% 43%
Since WireGuard is not included in the latest version of Raspbian Buster, I installed from source using
$ wget https://git.zx2c4.com/WireGuard/snapshot/WireGuard-0.0.20190905.tar.xz
$ tar Jxf WireGuard-0.0.20190905.tar.xz
$ cd WireGuard-0.0.20190905
$ cd src
$ make -j8
$ sudo bash
# make install
The Pi 4B to Xeon iperf3 runs were
$ iperf3 -c 192.168.177.2 ; # Pi 4B to Xeon over WireGuard
Connecting to host 192.168.177.2, port 5201
[ 5] local 192.168.177.4 port 57466 connected to 192.168.177.2 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 83.4 MBytes 700 Mbits/sec 0 417 KBytes
[ 5] 1.00-2.00 sec 84.1 MBytes 705 Mbits/sec 0 417 KBytes
[ 5] 2.00-3.00 sec 84.3 MBytes 707 Mbits/sec 0 417 KBytes
[ 5] 3.00-4.00 sec 85.3 MBytes 715 Mbits/sec 0 458 KBytes
[ 5] 4.00-5.00 sec 84.5 MBytes 709 Mbits/sec 0 458 KBytes
[ 5] 5.00-6.00 sec 83.5 MBytes 701 Mbits/sec 0 458 KBytes
[ 5] 6.00-7.00 sec 83.8 MBytes 703 Mbits/sec 0 458 KBytes
[ 5] 7.00-8.00 sec 85.5 MBytes 717 Mbits/sec 0 458 KBytes
[ 5] 8.00-9.00 sec 83.9 MBytes 704 Mbits/sec 0 458 KBytes
[ 5] 9.00-10.00 sec 83.8 MBytes 703 Mbits/sec 0 458 KBytes
[ 5] 0.00-10.00 sec 842 MBytes 706 Mbits/sec 0 sender
[ 5] 0.00-10.04 sec 841 MBytes 703 Mbits/sec receiver
iperf Done.
$ iperf3 -c d0.wulf ; # Pi 4B to Xeon direct no WireGuard
Connecting to host d0.wulf, port 5201
[ 5] local 192.168.174.145 port 55916 connected to 192.168.174.150 port 5201
[ 5] 0.00-1.00 sec 111 MBytes 935 Mbits/sec 1 366 KBytes
[ 5] 1.00-2.00 sec 112 MBytes 937 Mbits/sec 0 366 KBytes
[ 5] 2.00-3.00 sec 112 MBytes 940 Mbits/sec 0 366 KBytes
[ 5] 3.00-4.00 sec 112 MBytes 936 Mbits/sec 0 366 KBytes
[ 5] 4.00-5.00 sec 112 MBytes 939 Mbits/sec 0 366 KBytes
[ 5] 5.00-6.00 sec 112 MBytes 938 Mbits/sec 0 366 KBytes
[ 5] 6.00-7.00 sec 112 MBytes 937 Mbits/sec 0 366 KBytes
[ 5] 7.00-8.00 sec 112 MBytes 937 Mbits/sec 0 366 KBytes
[ 5] 8.00-9.00 sec 112 MBytes 937 Mbits/sec 0 366 KBytes
[ 5] 9.00-10.00 sec 112 MBytes 938 Mbits/sec 0 366 KBytes
[ 5] 0.00-10.00 sec 1.09 GBytes 938 Mbits/sec 1 sender
[ 5] 0.00-10.04 sec 1.09 GBytes 933 Mbits/sec receiver
iperf Done.
$ iperf3 -c 192.168.177.2 ; # Xeon to Xeon over WireGuard
[ 5] local 192.168.177.3 port 34170 connected to 192.168.177.2 port 5201
[ 5] 0.00-1.00 sec 108 MBytes 902 Mbits/sec 0 314 KBytes
[ 5] 1.00-2.00 sec 107 MBytes 897 Mbits/sec 0 361 KBytes
[ 5] 2.00-3.00 sec 107 MBytes 897 Mbits/sec 0 383 KBytes
[ 5] 3.00-4.00 sec 107 MBytes 897 Mbits/sec 0 401 KBytes
[ 5] 4.00-5.00 sec 107 MBytes 898 Mbits/sec 0 419 KBytes
[ 5] 5.00-6.00 sec 107 MBytes 896 Mbits/sec 0 419 KBytes
[ 5] 6.00-7.00 sec 107 MBytes 894 Mbits/sec 0 419 KBytes
[ 5] 7.00-8.00 sec 107 MBytes 896 Mbits/sec 0 419 KBytes
[ 5] 8.00-9.00 sec 107 MBytes 897 Mbits/sec 0 419 KBytes
[ 5] 9.00-10.00 sec 107 MBytes 897 Mbits/sec 0 419 KBytes
[ 5] 0.00-10.00 sec 1.04 GBytes 897 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.04 GBytes 896 Mbits/sec receiver
iperf Done.
$ iperf3 -c d0.wulf ; # Xeon to Xeon direct no WireGuard
[ 5] local 192.168.174.151 port 35774 connected to 192.168.174.150 port 5201
[ 5] 0.00-1.00 sec 113 MBytes 947 Mbits/sec 0 369 KBytes
[ 5] 1.00-2.00 sec 112 MBytes 937 Mbits/sec 0 369 KBytes
[ 5] 2.00-3.00 sec 111 MBytes 935 Mbits/sec 0 369 KBytes
[ 5] 3.00-4.00 sec 111 MBytes 932 Mbits/sec 0 369 KBytes
[ 5] 4.00-5.00 sec 111 MBytes 934 Mbits/sec 0 369 KBytes
[ 5] 5.00-6.00 sec 112 MBytes 937 Mbits/sec 0 369 KBytes
[ 5] 6.00-7.00 sec 111 MBytes 935 Mbits/sec 0 369 KBytes
[ 5] 7.00-8.00 sec 111 MBytes 931 Mbits/sec 0 369 KBytes
[ 5] 8.00-9.00 sec 111 MBytes 934 Mbits/sec 0 397 KBytes
[ 5] 9.00-10.00 sec 112 MBytes 937 Mbits/sec 0 397 KBytes
[ 5] 0.00-10.00 sec 1.09 GBytes 936 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec receiver
iperf Done.
$ ping -c 5 192.168.177.2 # ; Pi 4B to Xeon over WireGuard
PING 192.168.177.2 (192.168.177.2) 56(84) bytes of data.
64 bytes from 192.168.177.2: icmp_seq=1 ttl=64 time=0.512 ms
64 bytes from 192.168.177.2: icmp_seq=2 ttl=64 time=0.434 ms
64 bytes from 192.168.177.2: icmp_seq=3 ttl=64 time=2.51 ms
64 bytes from 192.168.177.2: icmp_seq=4 ttl=64 time=0.453 ms
64 bytes from 192.168.177.2: icmp_seq=5 ttl=64 time=0.468 ms
--- 192.168.177.2 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 138ms
rtt min/avg/max/mdev = 0.434/0.874/2.505/0.816 ms
$ ping -c 5 d0.wulf # ; Pi 4B to Xeon direct no WireGuard
PING d0.wulf (192.168.174.150) 56(84) bytes of data.
64 bytes from d0.wulf (192.168.174.150): icmp_seq=1 ttl=64 time=0.190 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=2 ttl=64 time=0.140 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=3 ttl=64 time=0.176 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=4 ttl=64 time=0.194 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=5 ttl=64 time=0.211 ms
--- d0.wulf ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 125ms
rtt min/avg/max/mdev = 0.140/0.182/0.211/0.025 ms
$ ping -c 5 192.168.177.2 ; # Xeon to Xeon over WireGuard
64 bytes from 192.168.177.2: icmp_seq=1 ttl=64 time=0.485 ms
64 bytes from 192.168.177.2: icmp_seq=2 ttl=64 time=0.476 ms
64 bytes from 192.168.177.2: icmp_seq=3 ttl=64 time=0.471 ms
64 bytes from 192.168.177.2: icmp_seq=4 ttl=64 time=0.515 ms
64 bytes from 192.168.177.2: icmp_seq=5 ttl=64 time=0.460 ms
5 packets transmitted, 5 received, 0% packet loss, time 53ms
rtt min/avg/max/mdev = 0.460/0.481/0.515/0.027 ms
$ ping -c 5 d0.wulf ; # Xeon to Xeon direct no WireGuard
64 bytes from d0.wulf (192.168.174.150): icmp_seq=1 ttl=64 time=0.223 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=2 ttl=64 time=0.226 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=3 ttl=64 time=0.218 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=4 ttl=64 time=0.220 ms
64 bytes from d0.wulf (192.168.174.150): icmp_seq=5 ttl=64 time=0.150 ms
5 packets transmitted, 5 received, 0% packet loss, time 58ms
rtt min/avg/max/mdev = 0.150/0.207/0.226/0.031 ms
