Thanks how would I install it from that zip? Do I have to use commands in terminal orepoch1970 wrote: ↑Fri Sep 13, 2019 9:12 pmI would recommend piCorePlayer, which wraps piCore linux, Logitech Media Server, Squeezelite, etc. in an easy to live with package. Excellent support for the Pi platform and available audio HATs.
https://www.picoreplayer.org
If you target using a Pi 4, you need a beta release.
Do you know of an alternative that doesn’t do that? I’m using the pi as a work station at work and it’s already all set up was just hoping to install an appAndyroo wrote: ↑Fri Sep 13, 2019 10:32 pmYou would use Etcher or similar to create the SD as this includes the operating system as well as all the programs.
This is not Raspbian but a slightly different version of Linux and the SD card would be dedicated to this task.
Note: This will delete everything off that SD card.
Currently USB drive but I have to select all the music to play it, was wanting just a program open it and hit pl ay
I’ll take a look thanksgordon77 wrote: ↑Sat Sep 14, 2019 6:28 pmYou might like to try this python script l've been working on...
https://github.com/Gordon999/Pi-MP3_Player
It will work on a pi and desktop monitor.
sudo apt-get update
sudo apt-get install rhythmbox
