Peter_D_Hedin
Trouble with update on Raspberry Pi 4
Wed Sep 11, 2019 5:26 am
When I update I get this error:
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
What should I do to fix it?
Re: Trouble with update on Raspberry Pi 4
Wed Sep 11, 2019 5:31 am
Use apt instead of apt-get and you will get a Y/n question, type Y and press ENTER
sudo apt update
sudo apt full-upgrade
sudo reboot
It is because you are using the first Buster Release image which was pre-release....
Last edited by fruitoftheloom on Wed Sep 11, 2019 5:53 am, edited 3 times in total.
Peter_D_Hedin
Wed Sep 11, 2019 5:44 am
Problem solved. I use sudo apt instead of sudo apt-get.
