brasta78
RPI 4 USB-C supply
Mon Sep 09, 2019 11:41 am
Ok I heard about RPI 4 problems implementing USB-C spec but for me is other related question - I have DELL USB-C power supply https://www.dell.com/en-ie/work/shop/de ... ccessories that can provide 20V/9V/5V and I don't understand can I plug and test RPI which require 5V? Ampers more than enough - 30W/5V = 6A
bjtheone
Re: RPI 4 USB-C supply
Mon Sep 09, 2019 12:09 pm
USB C issue is that the 4B does not have the appropriate resistor to fully implement the USB C "device type" part of the spec. Due to this smart chargers, that can supply greater than 5V don't know what it wants. Unfortunately various vendors have tacked their own fast charging extensions on and may or may not be fully spec compliant.
In theory a fully compliant USB C multi voltage smart charger should just not charge the Pi. I have not heard of a charger that supplies an over voltage that would harm the Pi but it could happen. I have heard of smart chargers that don't work with the 4B and I believe that at least some Dell chargers do not work.
Mon Sep 09, 2019 1:32 pm
My Dell USB power supply does not work with the Pi4. Just use the official power supply, it's cheap and works.
This problem with certain high end power supplies will be sorted out in a later board revision.
W. H. Heydt
Mon Sep 09, 2019 1:47 pm
In theory a fully compliant USB C multi voltage smart charger should just not charge the Pi...
Nitpick...
A Pi requires a "power supply unit" (PSU), not a "charger". There are no power storage devices on a Pi, and--therefore--nothing to charge. (Yes, there are small capacitors, but the charge they hold isn't intended to and won't power the Pi.)
/Nitpick
Mon Sep 09, 2019 2:21 pm
Just buy the Official Power Supply it was chosen to give quality at an affordable price:
https://www.raspberrypi.org/products/ty ... er-supply/
brasta78
Mon Sep 09, 2019 3:51 pm
check results with my DELL USB-C AC adapter - red light is on and green is flashing but on 2 different monitors and TV didn't show any boot screen... The same with my other USB-C 6V adapter from soldering iron. Voltage on Pin 2 and 4 is 5V.
Should I try to flash EEPROM? But my green light is flashing...
W. H. Heydt
Mon Sep 09, 2019 4:08 pm
No. You should get an official RPF PSU and try with that.
drgeoff
Mon Sep 09, 2019 4:36 pm
Do you realise that without a bootable OS on an inserted micro-SD card you have no prospect of seeing anything on the screen other than a "No signal" or equivalent message generated by the monitor itself?
If the red LED is on and not blinking or going out, then the USB-C issue with the RPI's power input is not the immediate problem.
brasta78
Wed Sep 11, 2019 2:50 pm
so guys all of you who forced me to buy original Raspberry power supply are owing me 10€ :) because my 2 owned USB-C AC adapters appears also working and @drgeoff was right - problem was with SD card
Wed Sep 11, 2019 3:05 pm
In our defence, the thread title is about power supplies...!!!
brasta78
Wed Sep 11, 2019 3:12 pm
that board is alive with non branded power supply it was clear from my test results:
Wed Sep 11, 2019 3:19 pm
At that stage it's not possible to tell if the supply is supplying enough power though. The firmware need to be loaded to get any reports, and I suspect at that point its wasn't.
brasta78
Wed Sep 11, 2019 3:28 pm
jamesh, you know that Dell AC adapter 30W more than enough;)
Burngate
Wed Sep 11, 2019 5:00 pm
Don't, whatever you do, argue with Jamesh.
He's an engineer, he's a moderator, but more to the point, he's all-powerful
If you argue, he makes life difficult for the rest of us
davidcoton
Wed Sep 11, 2019 5:57 pm
Jamesh... he's all-powerful
Is "all-powerful" more than 30W? :lol:
HawaiianPi
Wed Sep 11, 2019 5:59 pm
Actually, no, we don't. Battery chargers may not have the precise voltage regulation needed to run a Pi computer. In fact, some battery charging algorithms require voltage variation (constant current charging), while Pi computers need a stable 5V over varying loads. So while a charger may also act as a power supply for a battery powered device, it's not not necessarily up to the task of powering a computer directly.
Wed Sep 11, 2019 7:56 pm
If that is indeed what it will supply, but that requires negotiation with the board, which is not supported on the Pi.
Not only that, but when I tried a Dell USB-C power supply from my dock, it didn't work at all...
I'm not all powerful, that's Liz.
wildfire
Wed Sep 11, 2019 8:21 pm
:lol: :lol: :lol: :lol: :lol:
James, Eben may be having a word with you tomorrow.
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
Wed Sep 11, 2019 8:28 pm
Only if Liz tells him to.
W. H. Heydt
Wed Sep 11, 2019 8:54 pm
I wouldn't wish to get in an argument with either of them. Or with you, for that matter.
wildfire
Wed Sep 11, 2019 9:41 pm
:D
Anyway, back on topic...
I don't understand why some people use 3rd party chargers when RPF/RPT (always get them mixed up) provide reasonably cheap power supplies which do as it says on the tin and are supported. I've, hold on... 6 Pi's running here (2 0w's 2 3B+'s & 2 4B4's) all using official PSU's and the only time I've seen the lightning bolt over the last few years was booting from an SSD on a 3B+. A powered USB HUB solved that.
When buying a POWER SUPPLY UNIT for the Raspberry Pi, if it's not official then caveat emptor.
Still NF Shirls
brasta78
Thu Sep 12, 2019 5:13 am
same thing i wanted to reply as @jcyr - I've already have 2 USB-C AC adapters and my last thought - stop polluting and save the world :!:
wildfire
Thu Sep 12, 2019 6:29 am
@jcyr @brasta78
As I emphasized in my post, a charger is not the same as a power supply unit, they may look the same and in many cases a charger can replace a PSU but, one has regulated voltage when under load the other does not.
Still NF Shirls
MisterEd
Thu Sep 12, 2019 6:54 am
Some of the official retailers that sell Pis also sell there own power supplies. For example I have the following:
* CanaKit Raspberry Pi 3 Power Supply (Micro USB) - 2.5A
* CanaKit Raspberry Pi 4 Power Supply (USB-C) - 3.0A
Shouldn't these power supplies also be considered just as safe as buying an official power supply? Can't I assume that these power supplies meet technical requirements RPF has established?
wildfire
Thu Sep 12, 2019 7:08 am
If it's a trusted reseller and they describe the PSU as suitable for whatever model of Pi then you shouldn't have a problem. Here in the UK/EU you could return the goods as unfit for purpose (other jurisdictions may vary).
In the case of CanaKit, I don't shop with them but they are well known and I doubt you would have an issue with them.
Adding to my previous post, if you have a charger that's unofficial but works then great, use it but if it doesn't work don't complain to the RPF about it.
Still NF Shirls
