spaceman5
Can the 3COM 3CRUSB10075 USB Wi-Fi Adapter Work with Raspberry Pi?
Mon Sep 09, 2019 4:25 am
Hi all
I bought 2 RPi boards recently:
1) RPi Zero W
2) RPi Zero v1.3
I might need once in a while to connect the RPi Zero v1.3 to an internet, just for a short time,
and I wonder regarding this:
I have at home a completely new USB Wi-Fi Adapter, that was bought long long ago.
It is 3COM 3CRUSB10075.
Can it work with RPi? (Zero v1.3)
Thank you
Re: Can the 3COM 3CRUSB10075 USB Wi-Fi Adapter Work with Raspberry Pi?
Mon Sep 09, 2019 4:41 am
Hi all
1) RPi Zero W
2) RPi Zero v1.3
Thank you
It is quite an ancient 54g WiFi Adaptor which I believe uses a Zydas Chipset, providing it has Linux driver / firmware it should work.
Plug it in and see if it is recognised:
lsusb -v
https://linux.die.net/man/8/lsusb
Retired disgracefully.....
spaceman5
Mon Sep 09, 2019 8:18 am
Hi fruitoftheloom
Thank you for your answer.
Simply to connect it, without doing anything before, like some Setting/Driver?
Mon Sep 09, 2019 8:32 am
Hi fruitoftheloom
Simply to connect it, without dong anything before, like some Setting/Driver?
Just plug it in, Raspbian will recognise a USB device has been inserted, lsusb will inform what device has been plugged in, that information is what is needed to ascertain if any drivers / firmware may be required for it to function.
spaceman5
Mon Sep 09, 2019 9:32 am
Terrific.
Thank you very much,
will report here after the Zero and Zero W arrive..
drgeoff
Mon Sep 09, 2019 4:22 pm
Terrific.
The Zero has one USB port. The other micro-USB socket nearest a board corner is just that. Only its power pins connect to anything on the board.
spaceman5
Mon Sep 09, 2019 4:31 pm
I know that..
And it's not only the Zero, also the Zero W..
You get 1 USB Host port, and the corner one is power..
Return to “Beginners”
