evanjerry1234
Re: Yet Another Bare Metal Tutorial for the RPi3
Sun Aug 18, 2019 6:08 pm
I'm trying to use Geany on the Pi to learn C++. When I use the 'execute' command, the terminal window that opens is blank. I've not changed the default execute command - it is still set to "./%e". I have tried this on 2 different Pi's with the same result. Is this is a known problem? How can I fix it?
Thanks for Great Tuts
Johnbeaumont
Fri Aug 30, 2019 8:15 pm
Will this tutorial work on rpi4?
bzt
Mon Sep 02, 2019 6:53 pm
I didn't had the chance to get an RPi4 yet, so I couldn't test them. I believe you only have to change the MMIO_BASE define in gpio.h, and they should work. As far as I know, all the devices those tutorials use are available on Rpi4 too.
Cheers,
bzt
