PeterO
Fan overlay working with Pimoroni fan shim
Fri Aug 23, 2019 9:58 am
I now have a Pimoroni fan shim fitted which uses pin 18 , so I added
 dtoverlay=gpio-fan,gpiopin=18,temp=65000
and it just works :-)
Now I'm sitting here wasting time watching it start and stop 8-) :lol:
PeterO
Andyroo
Re: Fan overlay working with Pimoroni fan shim
Fri Aug 23, 2019 11:18 am
PeterO
I was going to ask if you where having a bad day but then I thought this would be more entertaining than the tripe on TV most days. Neat solution and bookmarked - thanks for the solution.
Fri Aug 23, 2019 11:19 am
Does Pimoroni document that on their website? If not you may want to tweet this to them.
PeterO
Fri Aug 23, 2019 11:38 am
Already done so Dougie...
PeterO
clicky
Fri Aug 23, 2019 4:22 pm
PeterO
I've got a complaint to file: why didn't you post it sooner! LOL
Thanks - I'll do it asap, too! :D
itsmedoofer
Thu Aug 29, 2019 11:39 am
First class, I'll give that a go tonight !! The python tools currently used look nice with the bright lights but there are a lot of dependencies and I'm sitting here with top running looking at it using 2%CPU :)
alphanumeric
Sun Feb 09, 2020 1:01 pm
Missed this thread some how. Anyway, I've been running mine this way for a while. I've posted it once or twice on the Pimoroni forums.
I have also added a 10K pull down resistor between GPIO 18 and ground. On shutdown now my fan turns off, no having to unplug my power supply to make it stop. I have also added the following to my config.txt
 dtoverlay=gpio-shutdown,gpio_pin=17,active_low=1,gpio_pull=up
This lets me shut down and boot up my Pi by pressing the button on the fam shim.
will also work as the Fan shim button grounds GPIO 3 and GPIO 17 when pressed. If you enable i2c though it stops working and you have to use GPIO 17 instead.
PeterO
Sun Feb 09, 2020 1:12 pm
If you are not using any Hats, you can restore the original power down behaviour with the bootloader configuration.
See https://www.raspberrypi.org/documentati ... _config.md
I don't have any shutdown/boot buttons so it may not work with your setup.
PeterO
alphanumeric
Sun Feb 09, 2020 1:28 pm
I do believe if you do that, the Pi will no longer boot up by grounding GPIO 3. You have to ground the reset pin or the global_en pin.
With my current setup pressing the Fan Shim Button will boot it up if it was shut down and left powered. And after the config.txt edit it will do a proper shut down when the button is pressed. And with my pull down resistor mod the fan turns off on shut down. It has to be commanded on once you do the mod though. It will not start up all on its own anymore.
alphanumeric
Fri Mar 13, 2020 7:41 pm
Sorry to bump this thread but I have more info to add. If you add the following to your config.txt the fan will turn off on shut down. The downside is grounding GPIO 3 will no longer boot it back up. It is easier to implement than going back to an older firmware though. Just a FYI post.
dtoverlay=gpio-poweroff,gpiopin=18,active_low=1
Return to “Device Tree”
