bunklung
Independent Sound HDMI0 and HDMI1
Sun Aug 18, 2019 9:20 pm
Are there any updates on support for independent sound between the two HDMI interfaces? It seems like it was just limited to software. Is this tracked internally or a public means of a feature request on this.
6by9 and jamesh:
https://www.raspberrypi.org/forums/view ... 7#p1493187
https://www.raspberrypi.org/forums/view ... 6#p1493196
Thanks.
6by9
Re: Independent Sound HDMI0 and HDMI1
Mon Aug 19, 2019 7:28 am
Merged https://github.com/raspberrypi/linux/pull/3100
Should be available via rpi-update.
bunklung
Mon Aug 19, 2019 10:08 am
Thank you very much! I will give it a go. This will make multi-seat audio work without an external USB device for sound on the second seat.
Now, we just need a full KMS driver that has two devices :) 3D acceleration doesn't work on multi-seat, yet.
6by9
Mon Aug 19, 2019 10:30 am
AFAIK Full KMS won't expose two framebuffers either, as that is part of the DRM core framework which is used by both drivers.
The KMS device exposes the CRTCs and encoders, and then the drm_framebuffer layer is what glues those devices together on top of them to emulate a /dev/fbN device. This is generic across all Linux systems be it x86 or ARM. At the moment I haven't the time to go googling to see if anyone has solved this problem already, but it sounds like it should be plausible to fix. A question on the dri-devel mailing list may well be in order.
emilfr
Mon Aug 19, 2019 10:45 am
Waiting for this feature as well.
RPI Zero W || RPI 2B || 2x RPI 3B || 2x RPI 4B4G
6by9
Mon Aug 19, 2019 11:01 am
Do a bit of Googling yourself then. This is now standard Linux DRM/KMS stuff.
David Airlie's blog from 2010 https://airlied.livejournal.com/72187.html. May need a few tweaks for 9 years worth of development, and it is patches to the (radeon) kernel driver that appear never to have been accepted upstream, and would need porting to vc4.
Querying the status on dri-devel would be worth it as plans may have changed since. David is still active in kernel development though, so it might have been picked up again.
bunklung
Mon Aug 19, 2019 11:09 am
You all seem to be great at community questions and following up responses.
Should I create a new thread or bug report in regards to 3D support in a dual seat environment?
incognitum
Mon Aug 19, 2019 11:21 am
The problem is that standard Linux DRM/KMS is too x86 centered.
People in the x86 world generally do not see this as such a big problem, as it can be simply solved by spending 20 bucks on a basic extra pci-e video card to use for the 2nd seat.
However plugging in a second video card on the Pi is not a realistic option...
And yes, there has been a way created since to share a single DRI device (not really to solve the multi-seat problem though, but because a VR glasses vendor needed the functionality as well).
xlease, which does not have a website. Do "git clone git://people.freedesktop.org/~keithp/xlease" to read the instructions.
But you will likely need to patch lightdm (which is responsible for starting up the X servers in the Pi eco-system) to get things to work with that, which is not great either, and may be more work than patching up kernel.
bunklung
Sun Aug 25, 2019 4:48 pm
I will start a new thread on the dual seat/device DRM discussion. (https://www.raspberrypi.org/forums/view ... 3&t=249870)
Has anyone got the second audio channel working? I don't see it available. Do I need to configure it on config.txt to be exposed?
Mon Aug 26, 2019 8:07 pm
You should be able to play on different hdmi channels, using aplay, but I cannot remember the exact runes right now.
bunklung
Mon Aug 26, 2019 9:34 pm
Okay, I see the device, however it plays to HDMI0
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
  Subdevices: 7/7
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
  Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
  Subdevices: 1/1
card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
When I play the first three files they all play to HDMI0 (HDMI), The third *should* play to HDMI1. The 4th plays to my USB sound device.
[email protected]:~ $ aplay -D plughw:0,0 /usr/share/sounds/alsa/Front_Right.wav
Playing WAVE '/usr/share/sounds/alsa/Front_Right.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
[email protected]:~ $ aplay -D plughw:0,1 /usr/share/sounds/alsa/Front_Right.wav
[email protected]:~ $ aplay -D plughw:0,2 /usr/share/sounds/alsa/Front_Right.wav
[email protected]:~ $ aplay -D plughw:1,0 /usr/share/sounds/alsa/Front_Right.wav
I am using the latest rpi-update firmware. Do I have to enable anything in config.txt?
bunklung
Mon Aug 26, 2019 11:34 pm
I also tried:
"hdmi_preferred=1" in /boot/config.txt to shift audio (and CEC) to HDMI1.
(https://www.raspberrypi.org/forums/view ... d#p1495438)
and:
"I looked at other threads and the following line brought back sound over hdmi:
add "hdmi_drive=2" to /boot/config.txt in raspbian."
(https://www.raspberrypi.org/forums/view ... d#p1524440)
Still always plays on HDMI0
Tue Aug 27, 2019 8:57 am
Are you running an rpi-update'd Linux? The changes for this were very recent so might not be in apt yet.
bunklung
Tue Aug 27, 2019 10:35 am
I am using rpi-update.
[email protected]:~ $ sudo rpi-update                                               *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
 *** Your firmware is already up to date
[email protected]:~ $ uname -a
Linux raspberrypi 4.19.66-v7l+ #1253 SMP Thu Aug 15 12:02:08 BST 2019 armv7l GNU/Linux
I am surprised hdmi_preferred=1 doesn't work, but I think that wasn't widely documented anyhow.
6by9
Tue Aug 27, 2019 5:00 pm
This is my first poke around with ALSA and this driver - slightly icky to say the least!
Fully updated Raspbian and rpi-updated kernel/firmware gives a drop down list of destinations from the volume control plugin on the taskbar. The odd thing is that all the devices are routed through the same data channel, and it is using the PCM Playback Route control to switch where that goes. I've not found a way to have two outputs active simultaneously, however the audio does route to whereever is specified.
The kernel module (snd_bcm2835) does have a couple of parameters which seem to switch the mode of operation.
Add
snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_compat_alsa=0
to /boot/cmdline.txt (do NOT add any line breaks) and reboot.
aplay now reports
[email protected]:~ $ aplay -l
card 0: HDMI [bcm2835 HDMI], device 0: bcm2835 HDMI [bcm2835 HDMI]
  Subdevices: 4/4
card 1: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
  Subdevices: 2/2
card 2: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
  Subdevices: 2/2
[email protected]:~ $ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
default
sysdefault:CARD=HDMI
    bcm2835 HDMI, bcm2835 HDMI
    Default Audio Device
dmix:CARD=HDMI,DEV=0
    Direct sample mixing device
dsnoop:CARD=HDMI,DEV=0
    Direct sample snooping device
hw:CARD=HDMI,DEV=0
    Direct hardware device without any conversions
plughw:CARD=HDMI,DEV=0
    Hardware device with all software conversions
sysdefault:CARD=b1
    bcm2835 HDMI 1, bcm2835 HDMI 1
dmix:CARD=b1,DEV=0
dsnoop:CARD=b1,DEV=0
hw:CARD=b1,DEV=0
plughw:CARD=b1,DEV=0
sysdefault:CARD=Headphones
    bcm2835 Headphones, bcm2835 Headphones
dmix:CARD=Headphones,DEV=0
dsnoop:CARD=Headphones,DEV=0
hw:CARD=Headphones,DEV=0
plughw:CARD=Headphones,DEV=0
And
aplay -D hw:CARD=Headphones,DEV=0 foo.wav
aplay -D hw:CARD=HDMI,DEV=0 foo.wav
aplay -D hw:CARD=b1,DEV=0 foo.wav
all do the expected thing, and are available simultaneously. The Raspbian volume plugin gets totally lost with the multiple devices though.
As to why this driver has two ways to configure stuff, I have no idea!
6by9
Tue Aug 27, 2019 5:25 pm
A quick poke in the git history reveals that it was upstream that mangled this and added the module parameters.
We could change the defaults, but that will break some userland handling of audio devices (Raspbian's volume plugin for one).
bunklung
Tue Aug 27, 2019 5:51 pm
Add
aplay now reports
  Subdevices: 4/4
  Subdevices: 2/2
  Subdevices: 2/2
null
default
hw:CARD=HDMI,DEV=0
sysdefault:CARD=b1
dmix:CARD=b1,DEV=0
hw:CARD=b1,DEV=0
And
I am running latest and the three items have no effect on aplay -l/-L
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
6by9
Tue Aug 27, 2019 7:14 pm
Add
Read what I wrote (hint, NOT config.txt)
bunklung
Tue Aug 27, 2019 7:40 pm
Add
Oh man, sorry about that, total brain fart there :(
We are good! Now I just need to figure out the udev rules :)
bunklung
Tue Aug 27, 2019 8:53 pm
Hmm, this might not work after all as with dual seat. When I add a USB device, the Raspbian volume plugin has no issues with the added sound device. If I can't get the sound to be exposed in X, this isn't a realistic solution for everyone.
You mention the phase mangled. Does that mean a fix is planned?
Tue Aug 27, 2019 8:58 pm
We are still getting used to this dual stuff, and the audio has taken a bit of a back seat to the video side. It took me quite a bit of digging to get the ability to select 0 or 1 going (although it was a relatively small change in the end), and its all rather a can of worms. As for fixes, nothing is scheduled, but we do a lot of bug fixing which isn't scheduled anyway,
bunklung
Tue Aug 27, 2019 9:12 pm
Okay, if I only set: snd_bcm2835.enable_hdmi=1
I can get the sound to play simultaneously and I can set the default within X. Perhaps it's due to the headphone option or the the other switch?
I will mess some more and see if I can assign the channels to each seat and play nice in X.
bunklung
Tue Aug 27, 2019 11:26 pm
UDEV rule for seat 1/hdmi1:
TAG=="seat", ATTR{id}=="b1", ATTR{number}=="2", SUBSYSTEM=="sound", KERNEL=="card2", ENV{ID_SEAT}="seat1"
Assumes you have:
snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_compat_alsa=1
So snd_bcm2835.enable_compat_alsa=0 is the problem, if you set it to snd_bcm2835.enable_compat_alsa=1 or leave it out, you have control within X.
However, I can not control the volume, which is aligned with your observation of the shared PCM Playback Route.
So how does that go about getting it's own PCM playback Route for HDMI1?
bunklung
Wed Aug 28, 2019 12:05 am
It's progress so that's awesome. Hopefully we can get to a point where the dual seat setup is seemless, intuitive, and turnkey.
When you say video side, are you all working on a one GPU split between two seats? That's high on my wish list :)
Keep up the great work.
Wed Aug 28, 2019 7:28 am
Not working on dual seat at all. Just general dual output stuff, ie dealing with the fallout from having two displays.
