Not sure if this is off-topic exactly, but I saw your comment and I'm interested in this "alternative" approach. Is this possible to get a Lakka image running off a USB drive if I use an SD card as the boot partition?ddurdle wrote: ↑Mon Aug 26, 2019 1:33 pmI use the alternative approach on all my pi devices. I confirmed this weekend that the same approach works on the pi 4b 4GB. I'm in the more complicated situation because I use BTRFS. So, on the SD card I'm storing a boot partition for the purposes of loading an initramfs that has BTRFS support so that I can then boot the USB BTRFS partition. I don't mind the added complication because it still gets me to the end goal of running the OS off USB.
